Question about Car Audio & Video
Xr-700 wd pionner - Car Audio & Video
My 1998 land rover discovery i replaced the stock cd player with a pionner after market cd player everything is hooked up properly but cant get sound
Oh... Pioneer may be bad. I had a new tape player that was broken the day I bought it. Pioneer did replace it.
Apr 28, 2013 | Cars & Trucks
2 broken front spokes shortly after truing.
Is this a case of fixing something until it's broke?
Not only does a wheel have to be true and round, the individual spokes must be properly and semi-equally tensioned or there will be problems.
I use the Park TM-1 and have had no issues on many sets of wheels since I set them up with it.
http://www.parktool.com/blog/repair-help/wheel-and-rim-truing
As far as obtaining replacements, start looking around or find a Local Bike Shop. Try these guys online to start...
http://store.icyclesusa.com/wheelset-xero-road-bike-xr-1-700-clinch-black-shimano-p862.aspx?utm_medium=cse&utm_source=googlebase
Sep 03, 2011 | Formula Brakes Xero XR-1 Aero Road...
I have problem starting my xr 250(enduro)getting good spark plenty compression,fuel getting thru and carb all clean, ?? have changed cdi unit(original duff) but it was off mtx 125 but gives good spark,...
If you are getting gas than you have an air leak somewhere between your carb and the head. When the bike is ideling take a can of wd-40 spray slowly around every possable connection. ( rubber boot & where it bolts to the head ) When it sucks in air and wd-40 it will speed up and reveal the air leak. The boot itself could have a crack in it.
Oct 13, 2009 | 1990 Honda XR 250 R
Pionner Bluetooth problem
Hi, does your Pioneer has USB port? If so then download the update to your PC then transfer to USB stick and connect to your radio. You wont be able transfer the update from your Nokia.
Aug 25, 2009 | Nokia N95 Cellular Phone
Run a sub woofer to a peavey board
I would recommend using a separate active crossover such as the Peavey 23XO and a separate amp for your subs.
Jun 20, 2009 | Peavey Pv 2600 Power Amplifier
I have the pionner 1000 but the cue dont work wen
hi,
Micro switch of your cue button, need to be replaced.
djajay
djajay@inbox.com
Mar 07, 2009 | Pioneer CDJ-1000 CD Player
Will this lense fit on my camera?
You can have the 28-300 temron lens with beynout mount of pentax it will deffinaitly works like another lens manually , because af lens has a option of manual also so it will be suitable
Oct 01, 2006 | Tamron AF28-300mm XR Ultra Zoom for Pentax...
I CANNOT USE MY DVD(dvd pionner 120s/2).
Are you trying to read or burn a dvd?
And please don't type in all caps.
Keep me posted.
Sep 06, 2006 | Pioneer DVD 120S (DVD-120S) Internal DVD...
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
