Question about Canon BubbleJet i550 InkJet Printer
BJC 4550 Couldn't find a page for my printer hence it is on this model's page. Printer won't print. Paper feeds Ok.Print head moves across the platen as if it were printing but nothing appears on paper. Have done the usual, changed print cartridge. Checked paper thickness lever on print head, did a complete strip down to access the circuit board, cleaned (contact cleaner) all connectors and the both surfaces of the PCB. Still no print on paper. Two computers are hooked up to this computer (one is a Mac) and the result is the same. Has been printing fine until a couple of days ago. Any suggestions? Cheers, Maui
  • Stuart Fife Jul 15, 2007
    Packed the print head by approx.1.0mm.Made no difference. Print head still went through the print motion but failed to print anything on paper.
    Problem Solver:
  • 5 Answers
Chech if the ink cartrades are plugged in tight in they are check if all the chords are plugged in if that doesnt work go to a tech man or get a new printer
Posted on Jul 11, 2007
SOURCE:
BJC-85 Not printing. New BC-10 and BCI-10. Paper loads normally
The problem you are having is with the print head and not the printer. Unfortunately, with these canon print heads, they are not dated, so it is possible to install a print head that was bought new and sealed, but is still dried out because it is old.
Try running the print head through one deep cleaning cycle, this sometimes will start to get an old print head flowing.
Deep cleaning cycle can be found by going to PRINTERS , right clicking on the BJC icon, selecting PROPERTIES from the drop down menu, and then selecting the MAINTAINENCE tab.
Check to make sure that the ink tank in the print head isn't dry. Even a new print head can have a dry tank if it's old.
Jan 10, 2010 | Canon BJC-85 InkJet Printer
Paper feed fault
Check the printer lens and make sure the paper is probely inserted. Hope this helps...
Jan 28, 2008 | Canon BJC 3000 InkJet Printer
Prints have a thin white line across all the images printed. Everything else works and prints are ok outside of the thin white line running horizontal across the 5x7 prints.
  • Thermal head — generates heat; prints on paper
  • Platen — a rubber roller that feeds paper
  • Spring — applies pressure to the thermal head, causing it to contact the thermo-sensitive paper
  • Controller boards — for controlling the mechanism
I think that you may need to replace your thermal head, A line means there is a place that the head can not head or it cannot recieve data
http://www.youtube.com/watch?v=LWs74J7EfjM
How to matinence it and clean the head
Oct 21, 2009 | Sony UP DR100 Thermal Photo Printer
Printer keeps printing over the =same line, paper is not moving
Theirs a small gear in the gear train on the left hand side that turns the paper roller(Platen).
It has lost a couple of teeth. Has the paper is no longer feeding the print head simply keeps printing on the same place.
You need a service repair.
Cheers
DeJudge
Aug 11, 2009 | OKI MICROLINE 521 Matrix Printer
Streaking during printing
Well laser printers don't have print heads they print with a combination of a laser and toner. So I wouldn't buy a car from that person. And rollers are only problems when the paper does not feed, hence the term rollers..
If you are getting white lines across the paper then the toner is not being distributed properly. You can take the toner cartridge out and shake it a few times to spread it out.
If you are getting dark stains, then the print drum is not being cleaned properly by a blade on the inside of the printer. After a page prints a blade goes across the print drum to clean off the excess toner. You would have to get that repaired somewhere that repairs printers.
Hope this helps. Please rate this solutiion.
Mar 21, 2009 | HP Color LaserJet 2600n Printer
Orange lights (3)
Three orange flashes between green indicates a paper jam on this model. Look closely in the paper feed area and the paper exit area for any torn scraps of paper. Also open the top and check in the platen area (where the print head moves back and forth). If you don't see anything, it's possible that a sensor has broken or gone bad.
Jun 11, 2008 | Canon BJC 3000 InkJet Printer
Error light & 7 beeps
geez, going back in time,but it is a print position fault, head is not traveling correctly , make sure rail is lubed and carriage can move back and forth without obstruction,
Oct 26, 2007 | Canon BJC 80 InkJet Printer
Canon BJC 4300 InkJet Printer
i assume the cleaning method that you perform is offline (taking the cartridge our and clean them). I suggest you clean the head during the printer on.. try to perform below steps per the manual Cleaning the printer Printing the test pages Cleaning the print head I assume you do not have the manual anymore (no DVD) i list down the step below Its a bit long manual I suggest you download them from the canon website.. if you still have problem I can send to you the BJC 4300 manual Cleanning printer Make sure the printer is turned off before cleaning it. It is a good idea to unplug the AC adapter also. Do not clean the exterior of the printer with volatile liquids such as thinners, benzine, or any spray-type or chemical cleaners; doing so will damage the surface of the printer. When cleaning the printer, avoid the area near the print head on the BJ cartridge. Do not touch the print head. Ink may leak out and cause stains. Clean the printer regularly to avoid printing problems. Remove any ink mist or paper debris from the interior of the printer using a soft cloth moistened with water. Clean especially well around the platen area. If the rollers become dirty, you can clean them using a small soft brush. Clean the exterior of the printer with a soft cloth moistened with water. Clean away smudges and dust. Do not use paper products (such as paper towels or tissues) to clean the inside of the printer. Printing the Test Pages You can print these test pages to check the operation of your printer and your print quality. Test A This test prints a repeating pattern of characters. Demonstration This test prints a sample page describing the printer's features. Printing the Test Page From Windows You use the Test option on the Control tab in your BJC-4300 Printer Driver for Windows to print a self test, demonstration page, or a nozzle test pattern. Before selecting a Test option, make sure paper is properly loaded in the sheet feeder (see Automatically Feeding Paper starting on page 3-7). Click on the Test option and then click on the Print button. Printing the Test Pages Using the Operators Panel To print a test page, make sure the printer is turned off and paper is loaded. Press and hold the POWER button until you hear the number of beeps that correspond to the test page you want to print. Test Page Number of Beeps Pages Printed Demonstration 1 Continuous Printing Status Information 2 1 Page Test A 3 Continuous Printing Nozzle Test 4 1 Page When you release the POWER button, the test page starts to print. *All self-test prints require Letter or A4 size paper. Using a smallersize paper for a self-test print will result in parts of the printoutbeing printed directly on the platen. All self-test prints are printed in accordance with the current printing settings (font, printing mode, etc.) *Red- Information for technician not included in the user manual Cleaning the Print Head Your printer is equipped with a print head cleaning function to ensure constant high quality printing. Cleaning the Print Head From Windows If you are using Windows, you can execute print head cleaning from the Control sheet in the printer driver. Simply click on Clean Ink Head. 4300 Chapter 4 Page 6 Cleaning the Print Head Using the Operators Panel If you want to clean the print head from the operator panel, follow these steps: 1 Make sure the printer is turned on. Make sure the green POWER light is on. 2 Press and hold the RESUME button for at least two seconds until the printer beeps twice. The POWER light will blink for several seconds while the print head is being cleaned. Perform the print head cleaning only when you encounter a print quality problem. Unnecessary and repetitious cleaning will waste ink. If you execute the print head cleaning while paper is manually loaded, the printer will eject the paper and then perform the cleaning. 4300 Chapter 4 Page 7
Aug 24, 2007 | Canon BJC 4300 InkJet Printer
Paper feed
sounds like print head is not engaging home switch or sensor. open the printer and look for any such switch to sense print head at home position.
Jun 01, 2007 | HP PSC 2210 All-In-One InkJet Printer
Canon bjc-80 - no print appears but cartridge & paper move normally
I had this problem too. It turned out there was old dry ink in there clogging up the printerhead and it was fixed after I ran the cleaning programme several times. However I can't for the lifeof me remember how to do that now. I know I found it online but it has since vanished. Maybe check your manual?
Nov 12, 2006 | Canon BJC 80 InkJet Printer
Canon BubbleJet i550 InkJet Printer Logo
88 people viewed this question
Clive
Clive
old marine
old marine
Ekse
