SOURCE: XO Vision XOD1740BT in dash dvd player bypass code
I solved it By connecting the pink wire to a constant ground this acts as a bypass so the unit plays anytime.
SOURCE: xo vision dvd player
hi there
it shouldn't be to hard to install this but it does require cutting a hole in your interior part of roof........a install like this could take anywhere from 30 mins - 1hr for a installer to put it in. to do it yourself it could take 1-3hrs to complete (note for your first time doing this take your time and follow the install manual that will be provided)
SOURCE: no owners manual in box when I bought the XO Vision 1736
It does not look like the manufacturer provides a download link to the manual. I would suggest either calling them or emailing their support and requesting a copy be sent to you. Their contact info can be found by clicking the below link.
http://www.xovision.com/contactus.php
SOURCE: help me with back up camera for xo vision xod1740bt
I am just giving a suggestion. I too need to know how to wire this. From what you posted it sounds like you hooked the wire to a constant +12v that is always on. Forgive me if I am wrong. Anyway, Did you connect this wire to rear reverse light power. I think from what you say it is supposed to be connected to the positive side of that light. If this solves your problem can you PLEASE let me know the full details of everything else you hooked up on the circuit to make the backup work. For instance what is the label of the orange wire. TIA.
SOURCE: is there an adaptor to receive the digital tv
the analog to digital converters are for home based TV systems not mobile, you can try contacting the maker of the unit and seeing if they have a solution for you
