Question about Toshiba Satellite (K000004080) Motherboard
WHERE CAN I GET A MANUAL FOR A TOSHIBA PSAG8U-04001W
I have a toshiba psag8u-04l023 the keyboard lights up but screen wont power on
try the windows key and P to change alternative screen. If not plug in an external monitor if this displays your Screen for the laptop needs replacing.
Sep 27, 2013 | Computers & Internet
Reset current password
You can remove or change the Window's User or administrator's password. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
Aug 20, 2012 | Toshiba Satellite A305-S6902 2GHz Intel...
I have a Toshiba Satellite model: PSAG8U-04001W, I have no power. I have checked the voltage on the dc side of the ac charger and its fine. there are no status lights and the computer won't turn
This is an obvious board issue if your not getting any lights at all battery blink or HD lights no screen BIOS board is dead, you may want to check to see if power is going from the plug in plastic pin on the board as well the plastic input pin may be solder split or cracked and not connecting.
So the obviously fix for this is take it in to a tech and have them test the board out to see if your getting power to the power button. If your not getting anything showing with even the battery charge indicator and all black out. Board replacement is inevitable, I dislike being the delivery person for the bad news. This does happen...............John
May 14, 2012 | Computers & Internet
Toshiba PSAG8U-023019 xp install problems
The reason is that Windows XP doesn't come with SATA hard drive drivers. You have two options. The easiest being go in BIOS and check for IDE compatibilty mode or IDE emulation. Enable this and XP will install just fine. Your other option is to use a program called nLite and download SATA drivers from intel's website and you can incorporate them into a Windows XP slipstream install disc and it will install no problem.
Nov 21, 2011 | Toshiba Satellite A305-S6883 Notebook
How do you format the hard drive (full system wipe) on a toshiba psag8u-023019
make sure you have a working backup first
boot up off your recovery disks and choosing advanced options when you get to the point on selecting the drive for the installation, and erase the existing partitions, then choose the empty drive for yuor installation.
Feb 26, 2011 | Toshiba Satellite A305-S6883 Notebook
Hello,I have a Toshiba Satellite laptop Model No. PSAG8U-02E018, Serial No. Y8733118Q and I have recently been having trouble with the web camera. When I go to use it in the upright sitting position, the...
If the camera works when the screen is more to the closed position then chances are that the cabling from the camera to the laptop has been pinched or worn from the opening and closing of the screen.. There are other issues that may take part in this type of an issue - But The first one is the most logical from the information given.
If the laptop is with in 1 year of age - Contact Toshiba for Warranty that is current with in that first year.
OK - Looks like the laptop has expired from this Manufactures warranty. To get this fix could prove costly.
Thank you for your visit to Fixya.com
Dec 06, 2010 | Toshiba Computers & Internet
Toshiba A305 hotkey
Try re installing your operating system (genuine windows xp or vista suggested)
If the problem still persists contact me at
Deepuunni1985@gmail.com
Jul 10, 2009 | Toshiba Satellite A305-S6863 Laptop
Toshiba Satellite (K000004080) Motherboard Logo
56 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
