Question about Magellan Roadmate 1200 Car GPS Receiver
I cannot get a satellite signal on my roadmate 1200
I haven't used it in a while. It will not give current position - acts like mapquest- will give you directions but won't track your position.
3 Suggested Answers
  • 6 Answers
SOURCE: Where can I download free maps for my Magelllan RoadMate 1200?
go here //downloadanystuff.org/ put your download query and search
Posted on Jun 08, 2009
  • 4090 Answers
SOURCE: Magellan Roadmate 1200 won't lock onto any
check that your battery is fully charged use an AC charger if you have one.
Check Baud rate and port are set in accordance with manual
Posted on Jul 26, 2009
Magellan Roadmate 1412 won't track satellites
It might mean that the signal is disrupted. Might be a software glitch. Try going outside, get a clear view of the sky. Then reboot/reset the unit. Hold the switch to the reset position or off position for 10 seconds, it will shut off. then switch it back on. It should reacquire a signal within 2-5 minutes, then it will fix on your position. If that doesn't work, try updating your software. Call Magellan Tech Support for instructions.
Dec 29, 2011 | Magellan RoadMate 1412 Car GPS Receiver
I want to use the gps and navigator on my nokia 5800 can you please help
The Nokia 5800 has a built-in GPS satellite navigation receiver, which can tell you where you are anywhere on the planet. The 5800 also has cell-tower-positioning technology, which finds your location using the position of the nearest phone network mast if a satellite signal is unavailable. GPS is more accurate but can take a while (from 10 seconds to a few minutes, depending on how obstructed the sky is) to find your position ('Assisted GPS' is also present, to download the expected GPS satellite positions from the Internet and help speed up your fix.)
The 5800 also has a built-in mapping application called Nokia Maps, which shows you your location on a street map, tells you exactly how to get to another location by driving or walking, and can give details of nearby amenities such as shops, fuel stations, museums, etc. Nokia Maps uses both GPS and cell tower positioning to tell you where you are: the latter gives an instant rough position, while GPS data is used after the phone has locked onto enough satellite signals calculate its position. You'll know the phone is locked onto a satelite as the lock indicator at the bottom of the screen will turn green.
Other phone applications can also use the GPS receiver if required. For example the camera application can optionally "geotag" photos with your current location using the GPS receiver to work out where you are (click here to see our camera tutorial and find out more about geotagging). If you switch to the standby or menu screens while an application is using the GPS receiver, you'll see a little satellite icon in the top right corner of the screen to indicate that GPS is active.
How does the 5800's GPS work? Like all satellite navigation systems, the 5800 receives signals from many different GPS satellites in the sky, and calculates your position based on those signals, using a combination of triangulation, signal delay calculation and a lot of very heavy maths that you really don't want to know about.
Important Note: Satellite signals cannot penetrate buildings, so GPS satellite signals will be difficult or impossible to receive if you are indoors and away from windows. If you want to speed up the process of GPS showing your location, take the phone outside or place the phone next to a large window with a good view of the sky.
The 5800's GPS aerial is inside the top left side of the phone. If you want to get a good GPS lock make sure this part of the phone is uncovered
May 11, 2010 | Nokia 5800 XpressMusic Smartphone
Need an update for magellan roadmate 1200
Magellan® RoadMate® 1200 Software Update Version 1.50/3.12 - Release Notes This update applies to Magellan RoadMate 1200. It includes the following features, fixes, and improvements:
Improvements:
  • Point of interest (POI) Search Improvements reduce POI search times
  • Map Draw Improvements improve zooming, panning, and time to display the map
The software update version corresponds to your current software version:
  • If you have software version 1.46 or 1.48, your software will be updated to v1.50.
  • If you have software version 3.10, your software will be updated to v3.12.
You can locate your software version by following these steps:
  1. Start at the Main Menu.
  2. Press the arrow on the bottom right of the screen.
  3. Select "User Options"
  4. Select "System Settings"
  5. Select "Next"
  6. Select "Product Information"
  7. Your software version is on the line titled "Firmware Version"
Download Update: (Click here:)
I WANT TO DOWNLOAD THIS UPDATE
Feb 07, 2010 | Magellan Roadmate 1200 Car GPS Receiver
Magellan Roadmate 1200 won't lock onto any satellites. Satellite tracking is zero. Worked two days perfectly, day three, nothing. Brisco
Jul 26, 2009 | Magellan Roadmate 1200 Car GPS Receiver
I have a Tom Tom GPS and all of a sudden it says searching for satellite signal but never picks one up. Any suggestions?
To pinpoint your location, you need to get signals from at least 4 satellites. If you receive signals from less than 4 satellites or the signals are not strong enough, the Driving View stays grey and one of the following messages is shown in the bottom right corner of the Driving View:
  • Waiting for a valid GPS signal…
  • The GPS signal was lost … sec ago
Note: In previous versions of the TomTom application the message may vary.
If you see any of these messages, try the following:
Finding a GPS signal
In the following cases it can take up to 5 minutes to find your current position:
  • You use your TomTom device for the first time.
  • You haven't used your TomTom device for a longer time.
  • Your TomTom device has been relocated without using it (e.g. after travelling by plane or train).
If it takes longer than 5 minutes, make sure that you are in an open place without tall buildings or trees around you.
Once your TomTom device has located your current position, the Driving View is shown in full colour and shows your position on the map.
Tip: Most TomTom devices can use QuickGPSfix™ to locate your current position faster.
Clear View
Your TomTom device must be outdoors to locate your current position.
Try repositioning your device in your car; ideally, try to position it at the lowest possible point directly on the windscreen.
Some vehicles have a heat reflective shield embedded in the windscreen, which may prevent your device from locating your current position. If this is the case in your vehicle, use the TomTom External Antenna Kit (available as an accessory).
Tip: As a reference, place your device outside your parked car to see if it can find your current position.
Make sure battery is fully charged before use
Reset your device
Jul 24, 2009 | Tomtom XL 330 Car GPS Receiver
Worked for a year, now says not charged when plugged in
Try to use a wall adapter and charge it for 4 hrs before you plug it in the car because it is much better if you use a wall adapter it gives more power.
Jun 09, 2009 | Magellan Roadmate 1200 Car GPS Receiver
Jun 08, 2009 | Magellan Roadmate 1200 Car GPS Receiver
Magellan 760 no satellite signal
I got a Roadmate 760 from my employer to use. It won't pick up my current location and is not working right. Help!
Jun 14, 2008 | Magellan Roadmate 760 GPS Receiver
Unit will not acquire the satellite signs
FYI ....My Roadmate 760 would not aquire a signal, I went to diagnostic screen and found it was detecting/tracking 0/0 satellites. Held the plugged in unit out the window and within 10 seconds was tracking 7 satellites! Turned out my 1999 Olds Silhouette Van has a anti-glare filter inside the factory windshield that blocks GPS signals.My wifes 2001 Chevy Impala also has same type filter. Check your windshield, filter is visible inside glass to within about three inches of edges of glass. Worth a look.
Dec 29, 2007 | Magellan Roadmate 760 GPS Receiver
Keeps seeking but no GPS positioning
get a new unit like any magellan mastreo series or roadmate 800 ,i had a 700 they start having alot of problems after i did my research on here.
Sep 06, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan Roadmate 1200 Car GPS Receiver Logo
93 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
