Question about Maytag MFI2569VE Bottom Freezer French Door Refrigerator
Handle set screws came out of freezer door - Maytag MFI2569VE Bottom Freezer French Door Refrigerator
3 Suggested Answers
  • 152 Answers
SOURCE: My freezer door handle is coming loose. How do I
The handle should slide to the left using the handle release card
Posted on Feb 17, 2010
rjgebauer
SOURCE: handle on bottom freezer door
Thanks to Dana; it was a 5-star screwdriver, which I was fortunate to find one in my collection of tools and solve the problem. 30 minutes to figure out it was a 5-star screwdriver and find the tool; 3 minutes to fix the handle!
Posted on Aug 15, 2012
How to tighten loose set screws on freezer door handle on ken more fridge with bottom mount freezer, model no. 269-76353019
I think that the handle is attached either to the door edge or the face. In either case the screws are usually hidden behind a small trim panel. This needs to be removed to expose the screws. I don't know what type of screws have been used. They're usually cross heads but occasionally they require an allen key to remove them.
Jul 19, 2015 | Kenmore Refrigerators
How do I reattach handle on freezer door pull that has come unscrewed on French Samsung refrig
Many times the handle is slid on from one side or the other onto the screws. Try sliding the handle off by gently putting a screwdriver or putty knofe under the handle on the side that is still attached and pushing the handle sideways. This should remove the handle so you can remove the mounting screw and get it back on the door. then you can slide the door handle back on after getting the screw attached on the door again.
Oct 04, 2014 | Samsung RF265AA Bottom Freezer French Door...
GB2FHGXB01
Are you sure of the model number? I don't see a Whirlpool GB2FHGXB01 ; I do see a model GB2FHDXWB01.
For this model, there are several different door handles. One has a Philips head screw hidden under a trim piece. To expose the screw firmly push the trim away from the center of the handle. (This is for a standard Whirlpool fridge door handle.)
The French door style refrigerators have slightly different door handles. One uses Allen screws as set screws to secure the handle. (This screw needs a 3/32" Allen screw (hex key) and you can access it through a small hole in the underside of the handle on the loose side.) Be careful not to overtighten the screw or you may strip the threads and have to replace parts.
The other option has the handle mounted on brackets on the door. To access the bracket, grasp the freezer handle and pull it to the left. Then pull the handle away from the refrigerator.
For pictures of the handles, see pages 9 and 10 of the manual. It's available here: https://www.whirlpool.com/digitalassets/MLPDF/User%20Instructions%20-%20W10366204.pdf .
I hope this helps. If you do have the GB2FHGXB01, check if any of these directions help. Most refrigerators use one of the above door handle designs.
Apr 28, 2012 | Whirlpool GB2SHDXP Bottom Freezer...
I have a 2006 kenmore elite trio refridgerator wirh french doors and bottom freezer. on of the door handles is loose. what tool do i use to tighten handle. each handle has a screw at top and bottom. The...
There is two allen set screws for each hand at both end and they are facing each other on the handles.. Remove the allen screw and put a very minute speck of jelly on each screw---small-small amount. This will kept the set screws from loosen up. GB...stewbison
Aug 31, 2011 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
I have whirlpool A CLASS fridge how do i reverse the door
  • I cannot confirm weather your fridge had reversible doors as you listed no model but the standard for fridges that can reverse the door swing are changed by doing this -
  1. You will see little plastic covers on the opposite side where the hinges and handles are currently located now.
  2. There are some little clips that hinge the screws on the top and bottom of each handle.
  3. Remove these little covers with a small flathead screwdriver.
  4. Now remove the screws holding the freezer and refrigerator handles on.
  5. Now pop the screw hole covers on the side of the frig/freezer you will using.
  6. Now place and fasten with screws the handles on the other side of the frig/freezer door.
  7. Now remove the top freezer hinge first by removing the 3 screws on top.
  8. Now pull up on the hinge (save the spacer).
  9. Now pull up on the freezer door.
  10. Now remove the screws on the middle hinge.
  11. Now pull up and remove the middle hinge while holding the frig door steady (save the spacer).
  12. Now pull up on the frig door and set to the side.
  13. Now remove the screws on the bottom hinge (save the spacer).
  14. Now put the screw hole covers you removed from the other side in the screw hole exposed from the screws you just removed.
  • The switch
  1. Start with the bottom hinge and place it on the opposite side (don't forget the spacer).
  2. Place the frig door on the bottom hinge and the place the middle hinge in the hole at the top of the frig door.
  3. Fasten the middle hinge.
  4. Place freezer door on the middle hinge.
  5. Put the freezer door in it's natural position to make putting the top hinge on possible.
  6. Screw the top hinge in.
  7. Job complete.
Regards, Tony
Apr 30, 2011 | Whirlpool Refrigerators
Maytag Ice20 freezer door handle fell off on one side
I had the same thing happen with my freezer door on my Ice20 as well. You need to look inside the hole on the inside of the handle on the end that has come off. There will be a loose screw head sitting in there. You need to get that out and screw it back into the hole in the freezer door. Then, place the handle back on top of the screw that you just put in. Make sure the screw head is sitting properly inside the hole in the handle and the handle is flat to the door where it should be. Now, using a small set of allen keys, find the one that fits in the tiny hole on the underside of the handle. There is a little thread in the hole and you need to use the allen key to turn the thread until it puts pressure on the screw. This keeps the handle on. I was able to fix my door with a 40 cent allen key. Hope this helps!
Mar 18, 2011 | Maytag Refrigerators
Loose freezer door handle
There is a "set screw" on the underside of the posts that connect the handle to the mounting posts on the face of the door of my Jenn-Air bottom freezer. Use an Allen wrench to loosen the set crew, which is very small (my Jenn-Air requires a 3/32" Allen wrench), and then tighten the bolt on the mounting post on the face of the freezer door. Position the handle over the post, then tighten the set screws with the Allen wrench. Cynthia
Jul 21, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
The door handle on the freezer of my GE Profile Bottom Freezer Refrigerator came off.
Hi, Please get me the model # from the label inside the refrigerator and I will look this up for you. Most handles have a set screw that tightens down.
Vic
Jul 11, 2009 | General Electric Profile PFSS2MIXSS...
I nee to tighten up the freezer door handle on a sub zero 650?
There are different handles depending on serial number. The older of the two is at the top of the door. The screws are covered with a magnetic trim piece. You can remove this by putting tape on the chrome and pull up. You can then tighten the nuber two phillips head screws. The newer model is on the door itself. These are held on with small set screws accessed from the bottom of the handle. You may get by just tightening the set screws. If not you need to remove the handle by removing the set screws. You can then tighten the standoff and reatach the handle. For the 632 same procedure except it will be on the side.
Apr 12, 2009 | Sub-Zero 650 / O Bottom Freezer...
The ahndle on the freezer door is off can i fix it
most of these units have set screws that are tightened with an allen wrench the screw is on the bottom of the handle on eihter end of the handle hope that helps. if this doesnt answer your question if you would post a complete model number off of the unit I could look it up and be sure. thanks Peyton
Mar 09, 2009 | Amana ABB2527DES Stainless Steel Bottom...
Maytag MFI2569VE Bottom Freezer French Door Refrigerator Logo
19 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
