Question about Broan-NuTone CV750 Central Vacuum
Nutone CV-750 stops during use
Unit shuts off during operation, secondary filter has been cleaned when bag is repplaced. Cleaned it again but no difference. Unit acts like it is overheating. Seems to be getting worse. Is there another filter which could be dirty?
  • Rick Berk May 11, 2010
    Finally got around to replacing the brushes, lower motor brushes were ~ half the length and upper motor was about 3/4 the length. I expected them to be shorter and worn out but they were not. I put the new brushes in but the problem still remains but it seems to be less frequent. It seems to be thermal related but that is just my impression. It happens after the vac is on for around 10 to 15 minutes. Is there something else I can check into?
    Problem Solver:
  • 5 Answers
This was one of Broan/Nu-Tone's beginning attempts at lower-decibel machines. Like so many of their competitors, they choked the motors in dense foam in the head unit and made it too difficult for them to cool. Make sure that you're not blocking or suffocating the ventilation, but don't be surprised... a plethora of makes and models like this one have had to be pulled and discontinued because of the overuse of muffling foam snuffing out good machines before their time.
Chalk it up to a design flaw and start yanking that foam out. The specs on this puppy make it far too good a machine to pass on just becuase of the manufacturer used you as a beta test before they should have relaeased it from proto. If the increase noise irritates you, read up on sound waves, frequencies and subsonics and get creative in how you isolate the parts that bother you. Chances are, though, you'll be just fine.
Lastly, if you can tell me the age of the machine and get me the numbers off the motors I'd love to know more about this situation you're in. You're running dual 2-stage bypass 12.5 amp motors. That puts you roughly in range of a Lamb 472, one of our industry's most hardy motors. If THOSE are what you're running and they're over-heating, you've got a firehazard in your vac that *somebody* never should have put certification on for marketing.
Posted on Jul 12, 2009
    President:
  • 1,214 Answers
Make very certain that all panels, covers, and seals are in place to assure there are no air leaks into the system. Check all the piping runs to make sure none are broken and that all the ports in each of the rooms is closed. An excess of air reaching the motor will cause this, as will -
The type of motors they use in these things have a life of about 200 hours before they need servicing. And servicing amounts to brush replacement, assuming the motor has not run so much so as to cause damage to the commutator within the motor.
Reply back your findings so I may help you further.
Posted on Jan 23, 2009
How do I remove and replace the inverted bag filter?
Inverted filter bags can be tough to remove. The best way is to grab the bag closest to the top portion where it attaches to the canister. The bag is locked in place by a metal rings that presses out. You want to grab a portion of the bag (some bags have a holder tab) and pull towards the center. The goal is to make a C shape of the ring that is holding the bag in place. Once the bag collapse into a C shape, the bag can be removed and cleaned or replaced. The same technique is best for re-installing the new or cleaned bag.
Check out our website if you need replacement parts or you have more questions.
NuTone Central Vacuum Systems and Replacement Parts
Don't forget to visit and like our Facebook page https://www.facebook.com/QualityHomeSystems
Nov 05, 2015 | Broan-NuTone CV570 Central Bagless Central...
Have a nutone CV-450. Suction is gone at the
The first thing to do is to disconnect the pipe coming into the unit. If there is suction there than you probably have a break in the line. If there is no suction when you disconnect the pipe coming into the unit than it is most likely the motor gasket. This gasket can sometimes get sucked into the motor causing problems. Remove the lid to the central vacuum, than disconnect the motor, you should be able to tell if maybe the gasket has been off center or if it has been sucked up in the motor.
Dec 13, 2009 | Broan-NuTone CV450 Central Bagged Central...
The CV750 stopped working. It will come on sometimes but most of time it will not work. I installed new bag and cleaned filter. Green light on side of unit is on. Switch on side of unit will not make it...
The motor may have a sticking brush or a dead commutator segment. Turn off power to the unit to check for sticking brushes. Reapply power, does it now run? If not, shut it off, physically turn the motor a few degrees, and reapply power. If it still doesn't run, look for loose wiring around the motor. If it does run, replace the motor armature or the entire motor if the armature is not available as a separate part.
Oct 18, 2009 | Broan-NuTone CV750 Central Vacuum
My cv 353 start but is no succion could be the filter, how i replace it? there is a diagram?
this filter is a white dounut shaped one that is directly above the bag. this filter should be cleaned every time the bag is changed. there also may be a clog somewhere but unlikely.
May 25, 2009 | Broan-NuTone CV353 Central Vacuum
Motor noise CV 353
its not that bad to take apart and blow out the motor with a compressor, but if that dust got into the bearings of the motor it could be ruined.
Apr 19, 2009 | Broan-NuTone CV353 Central Vacuum
Nutone CV-750
You need to determine if this is a problem with the hose or the unit. I would recommend plugging my hose in the wall sideways. This should make your central vacuum run continuously. If the unit doesn't cut on and off it is the hose. If it still cuts on and off it is probably the relay.
Jan 06, 2009 | Broan-NuTone CV353 Central Vacuum
Power Unit VX475 Stops
Checked and found that motor is definitely overheating for unknown reason. Since power unit is still under warranty, solution was to contact local service company for NuTone power unit and have them come out and fix/replace it free of charge.
Jun 27, 2008 | Broan-NuTone VX475 Bagged Central System...
Nutone CV 450
If the top comes off, it will be by the motor and exhaust. Just replace it with the new one, make sure you don't mix up any wires. Also unplug it from the AC first.
Jun 22, 2008 | Broan-NuTone CV450 Central Bagged Central...
Broan-NuTone CV750 Central Vacuum Logo
260 people viewed this question
Top Broan-NuTone Vacuums Experts
Roger Potts
Gerry Harvey
Gerry Harvey
Steve
Are you a Broan-NuTone Vacuum Expert? Answer questions, earn points and help others
