Question about Jandy Digital Lite2 Lj325 Btu Heater, Propane
Pool heater leakage
Pool water pipe going into Jandy LJ lite 2 heater froze. Made the mistake of turning on the heater. Made cranking noise with in seconds gave a profuse leak. The pool guy tells me that I need a new pool heater. I think heat exchange tube is busted. Do you have any repair suggestion.
  • 1 more comment
  • zraufs Jan 29, 2009
    Thanks for your suggestion & info. I'll check it further over the weekend. I have also called another pool guy for estimate.
    Z. Rauf
  • Anonymous Mar 16, 2014
    I have FAFCO solar collectors for my pool. It seems every spring there are 2-4 leaks that have developed. plugging seems to be inefficient as you then lose one more heating tube, is there a way to simply patch so you do not lose that tube?
  • Anonymous Mar 28, 2014
    Not heating! Can not tell if value is op or closed?
Chances are that the header or manifold is cracked. usually the heat exchanger themselves are not damaged from freeze, but either the rear manifold (header) or the front header (the one that pipes go in and out of). Sometimes both. Replacing the entire heater is not necessary, about $200 in parts usually. We have a schematic diagram of the LJ heater here: http://www.poolcenter.com/parts_heaters_lite2_lj_2003-present_pg1.htm
Rob Cox
POOLCENTER.com
Posted on Jan 28, 2009
Jandy LJ Pool Heater
temp sensor might be going bad but you can go into menu and calibrate up to 4 degrees each way
Mar 24, 2014 | Jandy Laars Lite2 Lj 250,000 Btu Heater
Heater tuns off and pilot goes off
Feel the Outlet Water Pipe when the unit is burning and see if it is Getting very Hot, Should only be a little warmer than the water Inlet Pipe. If it is Getting really Hot, You may have a water flow problem and it may be going out on Hi Temp, Knocking out the Pilot..
Jun 25, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
JANDY LITE2 LJ HAS A FL-2 CODE WHEN HEATER STARTS
check gas flow, check for cobwebs in gas orfices also check if 24 volts ac to the brown gas lead if not check safety circuit if so bad gas valve
May 31, 2010 | Jandy Lite 2 Natural Gas Pilot Light...
Heater turns on and off
not rectifid the flame let me guss jandy LJ need new parts the ignator kit and the rectification kit if LJ
Sep 12, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Looking to buy pvc pipes to fit Jandy pool heater in and out flow pipes live in slough uk
jandy in and out pipes are 2" schedule 80 cpcv and should beavailable at any plumbing supply house. buy on 16" nipple and cut in half.Thread into headers then pvc cement the unthreaded end to tie into pump/filter system
Aug 21, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
Solution for Jandy Lite 2 Pool Heater display flashes on & Off ..
Can a model LJ250P Propane 2005 model be installed indoors . The rating plate says it can. But manual says it cannot. What the hell????
Jun 06, 2009 | Jandy Laars Lite2 Lj 250,000 Btu Heater
Jandy, Lite 2 Pool heater wont kick in
3/4 pipe line will work and will keep heater from sooting up.
Feb 15, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
Jandy Digital Lite2 Lj325 Btu Heater, Propane Logo
346 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Bill Jordan
Craig Butler
Craig Butler
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
