Question about Beam Industries 2775 Serenity Plus Central System Vacuum
My built in beam vacum cut off soon after turning it on why?
Is there a cost to sign up?
  • 91 Answers
May have over heated. i'd check for clog in hose before i did anything else
Posted on Jan 14, 2013
MY DYSON SHUTS ITSELF OFF IN THE MIDDLE OF A CLEANING TASK
REMOVE FILTER UNIT ON RIGHT HAND SIDE OF VACUM HAS A COULOR BUTTON PUSH IT BACK GENTLY AND LIFT OUT THE FILTER UNIT YOU WILL FINDA YELLOW FILER UNIT IN SIDE REMOVE IT AND UNDERNEATH YOU WILL SEE A BLUE FOAM INSERT REMOVE IT AND WASH OUT IN COLD WATER UNTILL WATER RUNS CLEAR DRY PROPERLY REFIT AND YOU MAY FIND YOUR DYSON WILL WORK PROPERLY IF NOT YOU MAY HAVE A FAULTY THERMAL CUT OUT BLOCK INSIDE THE MOTOR HOUSING USALLY HAPPENS WHEN FILTERS ARE CLOGGED AND CONTIOUS USE OF CLOGGED FILTER AVERAGE REPAIR COST £35 -£50
Aug 10, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
BEAM VACUM DOSE NOT WORK GOOD BECAUSE SOMETING SUCKED IN THEIR
Check to see if you have suction at the outlet, if so
the plug is in the hose or wand. If no suction at the wall, check at the vacuum. If you have suction at the vacuum then the line from the vacuum to the outlet
that you were connected is where the plug is.
Try a plumbers snake to try to get plug out.
Tom
Oct 22, 2009 | Beam Industries 2900 Serenity Plus Central...
The vacuum wont **** up anything anymore, and a rubber belt is now visible. What can I do to fix it?
i presume the vacume is a upright type. if the belt is visible i am also presuming the belt has broken, so turn the vacume up on its end so you can see the roller, you may have to take out a few srews to tak the base plate off which is covering the roller, take this off and you should see how the system works, the belt attaches to the moter spindle and then around the brush to turn it. take the brush out you should only need to pull it clean it and then go toyour local spares shop with the model number of your vacume and get a new belt, they cost about £1.00 each, put it back together and it should work....good luck.
Aug 22, 2009 | Vacuums
I have to reset my Beam Central vac quite often!!!
Check to see if there is a clog in the system. Something is causing stress on your motor causing it to switch off. Or it could be the motor itself failing.
First check for a clog, if you can't find anything wrong, call Beam for assistance
Aug 21, 2009 | Vacuums
When I hit the power switch it turns on, but it will not stay on.
If this were mine I would take the old switch off and put a toggle switch from Home Depot in it. Make sure it's rated for 110 volts and the wattage of your machine or at least 100 watts. It should cost no more than 2-3 dinero or about 1/200th the cost of a new one.
May 04, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Beater bar not engaging,
The belt is in tact, but the beater bar will not rotate
Jan 25, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Hair around wheels
No. I have 3 women and 2 dogs under my roof and have the same problem. My wife uses a Eureka vacuum that cost $140.00 and it seems to handle this better than our old Kerby.
We take a broom and swiffer and collect what hair we can from the bathroom areas, etc, before sweeping to avoid this problem.
Jan 11, 2009 | Kenmore 31913 Progressive Direct Drive...
The belt is broken of my dirt devil
Remove brush roller and black caps at each end of the roller. Clean and oil the bearings.they must turn freely.
Dec 10, 2008 | Dirt Devil Vision Turbo W/Bonus Upright...
Beam Industries 2775 Serenity Plus Central System Vacuum Logo
75 people viewed this question
Top Beam Industries Vacuums Experts
Thatvacguy.com
Jerry Kramer
Jerry Kramer
Are you a Beam Industries Vacuum Expert? Answer questions, earn points and help others
