Question about JVC TH-C50 System
I have the TH-C50 but I lost my system cable(the 8 pin din cable,connects the subwoofer to the unit). I just wonder may I buy any 8 pin din cable as a replacement or I must buy the exact one from JVC
I found a lot of on Amazon,but I am not sure can be used.like this one: http://www.amazon.com/HDE%C2%AE-Replacement-Male-8-Pin-Cable/dp/B009D0NLFO/ref=pd_sim_sbs_e_8
2 Suggested Answers
s4u311
  • 813 Answers
SOURCE: JVC TH-A9
1st u need to covert stereo cable with stereo conversion pin which avelieible in electronic consumer store after u got this cable u able to connect ur speakers directly to play station or a tv
Posted on Feb 19, 2008
I have a jvc th-m606 receiver and I don't have a subwoofer for it, is there a different way for me to get audio output or a different subwoofer I can use?
You would have to make a cable that goes from the 8 pin mini din of the jvc unit to each individual speaker. A wiring diagram can be found online each pin on your 8 pin goes to a speaker , and one is for power. Find a wiring diagram and find a cheap electric store that can make the cable for you. I had the same problem...
Aug 10, 2012 | JVC TH-M606 System
WHERE CAN I BUY A SP PWM505 CABLE THAT GOES FROM MY RECEIVER TO THE SUBWOOFER? ITS A HOME THEATER
  • Here is a list of cables for your unit from Crutchfield's.
  • If your looking for the s pin DIN cable from the sub you can get that anywhere. The 8 pin DIN is a standard cord the same across the board. Here are a couple to choose from.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Oct 11, 2011 | JVC TH-M505 System
I CANT FIND A SP PWM505 CABLE
Regards, Tony
I have a Th-C50 home theater and lost my subwoofer system cord, can I use a regular s-cord to make that connection? or is it useless with out the cord?? Please help!
Yes you can use any 2-core cable to carry the bass signal to the subwoofer. As the bass speaker cone is the largest cone in your speaker set I would recommend a good quality cable of decent gauge (thickness) to carry the bass signal.
You just need to make sure you have the right connectors for the amp and sub and make sure you connect positive to positive and negative to negative.
Hope this helps,
Chris
Mar 02, 2011 | JVC TH-C50 System
SUBWOOFER WON'T TURN ON
hello the most common reason for those subs not turning on is the din jack on the back of the sub where the 7 pin cable plugs in is worn --to confirm simply wiggle it while the dvd is on it will pop and possibly startle you but 9times out of 10 its just the jack
Sep 08, 2010 | JVC TH-C50 System
Digital Optical port to 8-pin din
Optical digital cables can't be magically wired to copper inputs. NO digital signal can be magically connected to an analog interface and work.
Even if you could do what you propose, how would you control volume?
Why don't you just connect the BluRay to the JVC system and let IT handle the audio to the sub and satellites?
Run an optical cable to the JVC TH-C60's Optical In port. Make sure there are no tight bends in the optical cable as that will degrade its ability to transmit a signal.
Jan 30, 2010 | Audio Players & Recorders
Is the system cable wired as a serial connector
u can get one from cablesondemand.com 8 pin mini din male/male
Oct 19, 2009 | JVC TH-M303 System
JVC 8 pin pinout - speaker cable
Looking at the connector, there are 3 rows of pins.
Starting with the first row closest to the alignment mark:
[Power On],[Center Speaker],[Sub Woofer]
[Surround Right],[Speaker Ground],[Surround Left]
[Right],[Left]
If you are trying to connect two JVC units, you will need an 8-pin cable that has the SAME pins connected on each side. You will need to test this using a multimeter set to ohms or 'connectivity'.
There are other 8-pin cables out there like the one for apple networking, but they use a crossover pinout where pin 1 on one end = pin 3 on the other end. This is bad. JVC needs pin 1 to = pin 1.
This is a standard connector/pinout setup that JVC uses, so connecting a TH-C3 to a TH-C50 works fine. There is a bunch of intermixing that you can get away with. The only thing to keep an eye on is the power in watts that one unit sends and the other recieves. Worst case is that the speakers are quiter than expected or that you can turn the volume up so high that it can damage the speakers. In all cases, you should get desired volume somewhere on the dial.
If you are trying to wire the speaker set custom, then you will need to take note that an '8-pin' connector is actually a 9-wire connector. Along with the above pinout, you will need to add Case Ground, which is the metal circle that surrounds the pins. To make the speakers turn on, you will need to apply 12v to the Power On pin and ground the 12v source to the Case Ground outer ring.
The system takes 3 to 4 seconds to fully turn on after this connection is made. Speakers should be wired using the center pin for speaker ground and each other pin respectful to each speaker.
Apr 01, 2008 | JVC TH-C50 System
JVC TH-A9
Feb 19, 2008 | JVC TH-A9 System
JVC TH-C50 System Logo
35 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
