Question about Schiller Cardiovit At 1 Ecg Machine
I have a problem with Schiller AT-101, the problem is "check paper".. can u help me out ?? thanks
Ekg machine keeps beeping out of paper --- it has paper !
Check is the paper is properly installed or not. Here i have added a video wich will help you to proper installation of paper in the try. keep in mind the you have to use Schiller orginal paper.
Ajin
May 29, 2012 | Schiller Welch Allyn Cardiovit At 2...
I Have a Schiller AT-102 ECG The problem is that the paper wanders out the paper sensor area and i get out of paper signal. The paper tray is 211 mm the paper size is 209 mm and no matter what i do the...
Hello!
I have the same model (Schiller AT-102) and unfortunately the same problem. I've tried almost everything with the hope of solving the problem: I changed the tightening springs which push the printer thermomatrix to the roller. Also replaced the optosensor. And so on... But nothing changed the situation. I would ask you to tell if you already have found the cause and the cure. Thank you in advance!
Jan 29, 2011 | Schiller Welch Allyn Cardiovit At 2...
Trying to refill paper and when i do that it stills says refill paper
hi,
use only paper for schiller AT1 . also check the paper sensor. slide the paper cover then look at is printer head side , u can see a small black square portion in the side . clan it with an ear bud. do not use any solution. after cleaning put the paper back and test again. use paper with black spot on the side. machine counts the black spot.
ok
Dec 22, 2010 | Schiller Welch Allyn Cardiovit At 2...
The schiller at-1 ran out of paper, I put some more in. Now it will not print any suggetions?
HI,
check the paper u have inserted. it should be Schiller original paper with page marking. also clean the paper sensor. u can see the paper sensor near the side of printing head. a small square portion. clean it with an ear bud, don't use any solution for cleaning only ear bud.
ok
Nov 14, 2010 | Schiller Cardiovit At 1 Ecg Machine
The schiller At-2 we have in the office is acting up. Model number 021-02609. Office number is 480-889-0508. The paper feeds and doesn't stop were needed and the ECG being preformed on a patient are not...
HI,
ok
Oct 13, 2010 | Schiller Cardiovit At 2 Light Ecg Machine
Schiller AT-1
check paper alignment
maybe papermark sensor problem also
Oct 16, 2009 | Schiller Cardiovit At 1 Ecg Machine
The schiller at 2 plus ecg machine not printing ecg
Does it work in auto mode ? are you putting paper correctly means , there is a black mark on paper which is sensed by paper sensor .If you put paper up side down then paper sensor won't be able to sense any paper & gives you error for rifilling paper .If this doesn't help you then You need to replace battrey . Thanks
Jul 15, 2009 | Schiller Welch Allyn Cardiovit At 2...
SCHILLER AT 2 EKG ISN"T PRINTING ON AUTO PRINT I NEED TO KNOW HOW TO RESET IT. I'M LOOKING FOR A MANUAL.
my machine now printed 2 paper in auto print mode, i want this print one paper .Can you help me solve this problem?
hoanghung_hoanghung24@yahoo.com
Apr 07, 2009 | RTO Schiller AT-2i Electrocardiograph -...
Schiller Cardiovit At 1 Ecg Machine Logo
93 people viewed this question
Top Schiller Medical Experts
Jim Goldsmith
Jim Goldsmith
Andrew Taylor
Andrew Taylor
Are you a Schiller Medical Expert? Answer questions, earn points and help others
