Question about Motorola Mobility RAZR V3
My motorola V3 heats up like crazy
My v3 heats up like flat iron when the battery was placed i think the battery terminal is grounded. Is it repairable? where can i find parts?
As ive said its very very hot. i tested the terminals, its shorted
Posted on Jul 09, 2007
Thats normal for the phone to do that. Don`t expect it to remain cool when its charged. It is going to get a little hot.
SOURCE:
My motorola v3 not charge
Check the adaptor and the battery, if there is no voltage on the battery terminal the phone circuit can be faulty. Also a faulty battery will nott charge and needs a swap to confirm.
Jul 22, 2011 | Motorola Mobility RAZR V3
Motorola V3 does not hold charge. I have replaced the battery with 2 new ones. I have used 3 different chargers. Low battery indicator comes on after 4 hours even with no use of the phone.
Sounds crazy but have you cleaned the connection area for your battery? Don't use a lot of it but I use hydrogen peroxide to clean mine... just dampen the end of a q-tip and rub the terminals with it. If it fizzles, you have corrosion there... it won't if you don't. This also works for ANYTHING that uses a battery.
Dec 07, 2009 | Motorola Mobility RAZR V3
Put it in washing machine for 5 mins by mistake lg
This is going to sound crazy but it will most definitely dry out your phone by morning.
Remove the battery cover and battery.
place phone and battery in bowl of white rice. The rice will absorb all of the moisture that is inside of the phone.
Sep 30, 2009 | Motorola Mobility RAZR V3
My phone doesn't charge. I don'y know what to do.
i think u r battery is damage u have to change u r battery.
Jun 28, 2009 | Motorola Mobility RAZR V3
Motorola V3 not showing Display
do a master reset by 000000 it will take it back to factory default cheers !!!!
Mar 26, 2009 | Motorola Mobility RAZR V3
Bluetooth Problem???
ok here's what you gotta do, this may solve u'r problem, go to menu, settings, initial set up, master clear Code ( 000000 )w8. phone boots, then go again to menu, settings, initial set up, master reset, Code ( 000000 ) then the phone will boot...and your fones restored to it's original settings, but the problem you had with this heating up thing, cant resolve, your phone is grounded, or your batt is no good... if you have multi tester put the pins on both side put to 0 value, in the battery terminal. then switch it both terminals again on both outer side of terminals , and if both after swicthing, cursor moves u'r fone is grounded, go to service center and they will replace yoour p.a. ( power ampli ) gud luck!
Apr 25, 2008 | Motorola Mobility RAZR V3
Motorola v3 unlocking code
I can send you to the right place to explain what to do, because you have a locked phone.
http://blog.dotkam.com/index.php/2007/04/01/100-tested-unlock-motorola-v3-razr/
I hope this helps you, it did for me....:)
Dec 01, 2007 | Motorola Mobility RAZR V3
My v3
you have overcharged your battery and need to get a new one and then you should get a charger with an IC smart chip that stopl charging once the battery reaches full. Motorola Phones in general have a problem with thier batteries.
Apr 07, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
128 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
