Question about Dell Inspiron 8100 Notebook
How do i replace network adapter
It says theres no network adapter
  • Dell Master
  • 5,660 Answers
Driver: Small piece of software that allows the Operating System to communicate with a device
It could be that Windoze in it's esteemed wisdom lost the address to the driver file.
Suggest you try downloading AND installing the network adapter driver, then replace Wireless Adapter
Dell Support > Inspiron 8100 Notebook PC > Drivers & Downloads page,
http://www.dell.com/support/drivers/us/en/19/Product/inspiron-8100
Scroll down. Click on the blue Down Arrow to the left of -
Network (9)
There are 9 network driver files listed? How to know which one you need?
As you notice under the blue title headings, are descriptions of the adapter.
One such as the Manufacturer, and what type of file.
Driver is the one you want.
So now it's narrowed down to three driver files.
A) Dell-Driver:
Applies to True Mobile 1150 Series Mini-PCI Card
B) Dell - Driver:
Applies to True Mobile 1150 Series PC Card
C) 3Com - Driver
Applies to 3CCFE575CT 10/100 MB Ethernet Cardbus PC Card
You can go into Device Manager, and look to see the manufacturers name, and possibly the model number.
Start > Right-click on My Computer > Left-click on Properties > Hardware tab > Device Manager
When Device Manager loads click on the + sign to the left of -
Network adapters
What is the manufacturer name? What is the model number after the name?
No Network adapter title listed?
http://www.bay-wolf.com/geforce4-1.htm
Top photo shows Bottom view of laptop. Panel door all the way to the Right, with a K on it. Remove the single Philips head screw, lift panel door up on screw side, remove.
This is where your network adapter resides.
http://support.dell.com/support/edocs/systems/ins8100/en/sm_en/remove.htm#1050760
What is the manufacturer name, and model number?
Can you match it to one of the driver files?
Downloading and installing driver:
I'm going to use WinXP as the O/S, and the 3CCFE575CT 10/100 MB Ethernet Card as the network adapter, for an example.
Click on the blue p-> 3Com - Driver , name.
You'll see the file's name is R36933.EXE
Click on the blue - Download File - to the right.
Under the bold heading - Choose Download Method, make sure there is a Green dot in the small circle, to the left of -
Single-file download
If not; left-click once in the small empty circle, to the left of -
Click on Continue in the blue oval 'button'.
A small window will come up -
Opening R56933.EXE
Click on Save File.
A small download window will come up.
Allow the file to download all the way, then DOUBLE-click on it.
If a Microsoft 'squawk box' comes up, just click on Yes.
Another one? Click on Run.
At the bottom of the next 3 small windows click on -
Next, Next, and Finish.
If you are not asked to restart your computer, do so.
[Close all windows, go back to your desktop screen.
Click on Start > Turn Off Computer > Restart ]
Still no?
After Windows completely loads, let it run for a couple of minutes.
No "Found new hardware", and maybe, "Found XXXX network adapter" ?
Shut the computer off normally.
Remove the AC adapter (Charger), and Battery.
Open the panel again. If there is a wired cable, see if it can be plugged in any tighter.
If there are two terminals on the network adapter, and two wires going to them;
1) Make a mark on one cable, and a matching mark on the terminal of the network adapter it is connected to.
Remove both wires.
See of you can take a pencil eraser, and clean the terminals.
The only method I use the terminal ends on the wires, is to re-connect them to their respective terminals on the network adapter, and gently turn them back, and forth a little.
AFTER the terminals have been cleaned.
Everything back together, and panel reinstalled?
Reinstall the Battery, and AC adapter. THEN plug AC adapter into power.
WAIT 30 seconds, turn the laptop on.
Still no?
Suggest the network adapter is bad. Replace.
Regards,
joecoolvette
Posted on Jan 14, 2013
  • Dell Master
  • 32,281 Answers
Try installing the LAN driver.
You can download the LAN and device drivers from Dell WEB site, the support download page. Make sure you select your model desktop or laptop, better still, type in the Service Tag number, it is printed on the label on the bottom of the laptop and on the back or sides of a desktop. (If the Service Tag label is missing then go into the BIOS setting and on one of the BIOS pages, the Service Tag number will be displayed). This will open the page where the specific drivers for your model computer are located. Also make sure you select the Windows of the drivers for your Windows operating system. Click on this link to download the drivers: - http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
Problem with Network Adapter? Replaced hard drive, now can't connect to Internet. Diagnose problem says problem with Network Adapter Driver.
you might have a port for your ethernet adapter but the software that is needed by that port could be faulty. there is a need to re-install the software for your network adapter.
May 07, 2012 | Dell Computers & Internet
Verizon fios says i need to replace my network adapter can i do that myself or should i have a technician
You can replace your network adapter by yourself by following the instructions in the manuel of the new network adapter.
Best regards,InJ3cTor
Aug 05, 2011 | Dell Computers & Internet
Resetting the adapter
Use the computer you are on to download the updated driver for the network adapter from the Toshiba Website. After you have the updated driver install it on the computer your having a problem on. Reboot the computer. If the problem is still there and you have a cable connected to the network connection and to the router, uninstall the network adapter from the device manager and reboot the computer. That should detect and install the adapter and resolve the problem. If it doesn't there is a problem with the network adapter and you will need to use the wireless of get a PCMCIA card to use for networking. Toshiba does use a replaceable Network card in some laptops, if nothing else above works and you don't want to get another card to plug in you may want to look into purchasing a new card from Toshiba to replace the old one.
Jul 22, 2010 | Toshiba Satellite A100-S8111TD Notebook
Do I need two wireless network adapters? I looked in the device manager folder in network adapters and there are 2... Intel (R) Pro/1000 PL Network Connection #2 and Intel (R) Pro/wireless 3945ABG...
You should have only 1 wireless adapter, the other 1 is the ethernet adapter. If you experience low signal strength even after updating the drivers, you need to customize wireless settings on the router.
You need to change the wireless mode to "802.11b and 802.11g" or "802.11g", whatever you have in your router. If this is the same with all wireless networks, wherever you go, then its an issue with the adapter, you should get a replacement.
Feb 05, 2010 | Intel PRO/Wireless 3945ABG Network...
Lightning struck and took out my dell ethernet card adapter? Is there anywhere I can buy one to replace it?
Yes you can buy a replacement Ethernet card from any electronic or computer store near you and they are pretty cheap now...
Dec 16, 2009 | Dell Ethernet Card Network Adapter
On my wireless network adapter for the xbox the light is red
The adapter is inoperable. You'll have to send it in to Microsoft for replacement or get a new one.
Sep 22, 2009 | Microsoft Wireless Network Adapter Xbox...
Replaced hard drive on HP dv4000. Install XP Pro and drivers from recovery disk. Updated to SP3. Do not have 1394 net adapter listed in network connections. Connected external hard drive to firewire port...
I would check in device manager (control panel) and see if the network card is listed. It probably has a yellow exclamation point next to it. If there is an exclamation point there, then right click the card and click uninstall. Next, using your wifi to access the internet, download the latest network card driver from the PC vendor website / Motherboard vendor site / discrete network card site.
Install the network card driver and you should be back in business.
Jul 09, 2009 | HP A6795A#0D1 Network Adapter
Network adapter
1) The first step you can try by checking from device manager whether its showing the device over there or not. Just click on Start and type there "devmgmt.msc". Under network adapters or in other devices if you are able to see any device which state as network adapter it means its getting detected. If not!!!
2) Check by changing the slot of the adapter and insert it any other slot in your computer..
3) If it still doesnt work then if posibble can check this adapter with any other computer as well
May 31, 2008 | ASUS PCI-L3C920 Network Adapter
About laptop ethernet...
First figure out whether your hardware is ok and driver is installed properly. In Windows XP, click Start , right-click My Computer , and select Properties .
  1. In Windows 98 and Me, right-click My Computer , and select Properties .
  2. In Windows XP, click the Hardware tab, and then the Device Manager button. In Windows 98 and Me, click the Device Manager tab.
  3. If the Network adapters category is present with a (+) sign , then skip to Step 6. If Network Adapters has a (-) sign , continue to Step 5. Disregard adapters that do not reference an Ethernet Adapter .
  4. If a network adapter is not listed inside, do one of the following items based on the condition of the networking hardware:
    • Networking hardware is not installed. Install a new network card (desktop computer) or a new network PCMCIA card (notebook computer) per the card manufacturers' suggestions. This does not apply to on-board networking hardware.
    • The network card is not seated fully into its socket. For Desktops, remove the side-case, reseat the network card, and replace side case. For notebook computers, remove and reseat the network PCMCIA card. This does not apply to on-board networking hardware.
    • If the computer is older, it may need to have jumpers on the network card set to an IRQ and address range that is not already being used by another device. Remove the side-case, set the jumpers on the card, and replace the side case. Replacing the older network card with a newer Plug and Play network card is probably a better option.
    • For desktop PCs with on-board networking hardware, reset the BIOS:
      1. Restart the PC.
      2. Press F1 repeatedly when the first screens appear.
      3. Press F5 and Enter to reset the BIOS to default settings.
      4. Press F10 and Enter to save the settings and exit BIOS setup .
      5. Restart the PC.
      6. Check Device Manager again for the presence of the Networks adapters category. If the network adapter name is still missing, the on-board network adapter may be damaged. The motherboard should be replaced, or a PCI network adapter should be installed.
  5. If the network adapter is listed, but has a yellow exclamation mark over its icon c00060708.jpg , do one of the following:
    • Software drivers and supportive files may be missing or corrupted. Remove the device from Device Manager and reinstall the software by restarting the computer. See Step 5: Reinstalling network adapter software drivers .
    • If the computer is older, it may need to have jumpers on the network card set to an IRQ and address range that is not already being used by another device. Remove the side-case, set the jumpers on the card, and replace the side case. Replacing the older network card with a newer Plug and Play card is probably a better option.
  6. If the network adapter listed has a green adapter icon c00060709.jpg , the networking adapter is probably functioning correctly. If the PC still cannot connect to the Internet, make sure to complete the following steps before continuing:
    • The cable or DSL hardware may have stopped responding. Reset the cable or DSL hardware using the manufacturer suggestions.
    • There still may be a connection problem. Recheck the cable connections and replace any cables that have been pinched or that you suspect are bad.
    • The Internet Service may be down at your provider. Most Service Providers have a telephone support number. Call the ISP support number. If an outage is occurring, an automated response about system wide service outages will probably play. In this case wait until the service comes back.
    If the network adapter icon is listed without problems, and the connections, service, and modem are working properly, then refresh the networking drivers.
Thanks
Iqbal
Mar 16, 2008 | HP Pavilion ze2000 Notebook
Can't set up wireless connection
  1. Check in your system: Click Control Panel, then double click System. On the Hardware tab click Device Manager. Click the (+) sign besides the Network Adapter. See if the Packard bell wireless adaptor is there. If its is not there, right click the Network Adapter and click Scan for hardware changes, and reinstall the network adapter.
  2. If the Packard bell network adapter is already there, click Start and click My Network Places. On the left side of the Network Connection, click View Network Adapter. The wireless network adapter should be there. Right click the wireless network adapter and choose properties. Give check mark on Show icon in notification area when connected (to show you if there is wireless notification), and give check mark to Notify me when this connection has limited or no connectivity (to show if the wireless network is disconnected). and click OK
  3. Turn on the orange broadband livebox. And right click the the wireless network connection (on Network Connection) and choose View Available Wireless Networks. And the click the Orange broadband Livebox to use this wireless Network connection.
I hope this solution is helpful to solve your problems
Best Regards
Blackrobin
Nov 16, 2007 | Computers & Internet
Dell Inspiron 8100 Notebook Logo
64 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
