Question about Epson Stylus DX6050 All-In-One InkJet Printer
The ink light is on red I have changed the cartridges but it is still the same
  • AFnorwood Feb 20, 2009
    The same thing. All the cartridges have been changed, but are shown as empty in the status display.
  • 63 Answers
Are they original epson ink? refill?
What does Epson status monitor say?
Let me know...
Matt
Posted on Jan 23, 2009
Red ink light blinking, won't feed paper. Have
this is hp security error, for ink cardtridge,(the ink cartridge has internal/acess counter), you need to try change cartridge, if contuinue send to hp service center
Nov 27, 2009 | HP DeskJet 940c InkJet Printer
Red Flashing lights
Hey,
Remove the cart ridges, restart printer, does the lights still flash? restart printer, place cartridges back in, make sure the tape is removed from the cartridge. also you can try cleaning the contacts.
So after you have connected the carts again, restart printer. how is it?
Thanks,
Ekse
Sep 08, 2008 | Epson Stylus Photo R220 InkJet Printer
Red light on after changing ink
Perform the following procedure:
n Press the ink cartridge replacement button until the print head has moved to the change cartridge position
n Lift the lid that holds the cartridge (do NOT remove cartridge) and press down immediately. Then press the ink cartridge replacement button and allow the cartridge to charge the print head. Do NOT switch the printer off until the printer has finished charging.
Does this solve the problem?
Yes: Solved
No: Go to Checkpoint 2
2. If you have printed between 100 and 300 pages, and it is your first ink cartridge, or it has been installed for at least 6 months, replace the ink cartridge.
Yes: Solved
No: Go to Checkpoint 3
3. If you have printed more than 300 pages, and it is your first ink cartridge, or it has been installed for at least 6 months, replace the ink cartridge.
Yes: Solved
No: Further help required
If red light again you must download resetter software from internet to reset your printer.
Aug 21, 2009 | Epson Stylus Photo 1290 InkJet Printer
Red light constantly on and not printing. changed
do you print CD or plain paper, red light is mean jamed paper or change cartridge. Open the top door >press drop ink symbol> look at printer head show on ink ink tray.
Aug 01, 2009 | Epson Stylus Photo R200 InkJet Printer
The red light on my epson printer wont turn off and it wont print,ive changed both ink cartridges and still no change.
Hi
Which button has the red light or which LED light? Is it flashing or steady red light? turn it off and check for any obstruction and double check if you installed ink cartridges properly.
Hope this helps
May 13, 2009 | Epson Stylus C40UX InkJet Printer
Epson C46, changed coloured ink, won't print flashing red light
If the red light is flashing by itself, it means the printer thinks a cartridge is low on ink. Have a look at what the Status Monitor thinks (right click the printer Icon in the bottom Right-Hand corner and select Ink Monitor). This will show which cartridge it is. If it's the new colour cartridge, it means the cartridge is faulty (then replace it), or it is a refilled cartridge that hasn't had it's chip reset to "full". For this you will need a chip resetter, available on E-Bay very cheaply. If it's the black cartridge then replace it.
If both green and red lights are flashing, it usually means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. You can restore your printer to a working condition immediately by using the SSC utility - download from:
http://www.ssclg.com/epsone.shtml
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type (C4x), then close the ssc window. Now right click the ssc icon in the sytem tray and choose Protection Counter. You should see that the current count is above the limit; then choose reset to set it to zero. You will need to fib about having changed the waste ink pads! Turn the printer off then back on again. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help. It is a pretty simple job once someone explains how to get the case apart!
Mar 11, 2009 | Epson Stylus C46 InkJet Printer
Cartridge holder won't move when i press button to change ink
Hi, it's not ready for a replacement cartridge yet, the printer is only LOW on ink not OUT of ink. continue to use the printer until the flashing red light remains on solidly, then the head will move to the replace cartridge poswition when you press the button.
Feb 12, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epsonstyluscx3810printer
try reseating the ink cartridges
if you still get the red ink error light - call EPSON with the date&place of purchase of the said inks
Dec 30, 2007 | Epson Stylus CX3810 All-In-One InkJet...
Epson Stylus DX6050 All-In-One InkJet Printer Logo
35 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
