Question about Zanussi WJS1265W Front Load Washer/Dryer
Nottaking the fabric conditioner
Zanussi washer dryer wjs1265w there is a mix of water and conditioner left at the end of the wash
  • Zanussi Master
  • 744 Answers
This video will show you how to keep your soap draw clear and how to service the parts.
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question..
Posted on Aug 06, 2013
  • Zanussi Master
  • 3,463 Answers
Remove soap draw, and remove internal parts and thoroughly clean all parts. Get a piece of wire, form a right angled bend in it , and poke it in all the holes at the top of soap drawer compartment, this will clear any blockage there .
Plz rate my solutioin.
Thanks.
Posted on Jan 23, 2009
Washer/dryer smells like a dirty disclothe. I dont' use fabric conditioner and I have serviced was at 90 deg with no clothes in and biological powder but it still smell. I have only used the dry cycle...
Hello
What did the guys say the did the service on your washer? I recommend you add 3 scoops of dishwasher powder and set your washers temp to 90 deg and let it run the problem is that your clothes washing powder dose not remove any build up or smell.
Thanks
Jun 15, 2011 | Zanussi WJS1265W Front Load Washer/Dryer
Can wjs1265w be connected to hot and cold water supply using Y connector - or must it be cold fill ONLY?
If there is only 1 inlet connector at rear of washer, then you must connect to the cold supply.
All current washers and washer dryers are cold fill only now.
If it has 2 connectors, then you must still connect to cold using a Y piece to make the final connection to washer.
Hope this helps.
Please rate my solution.
Thankyou.
Jan 26, 2010 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi ZWD1470W fabric conditioner compartment won't drain
fabric conditioner is dispensed during rinse cycle, if it does not work then either, try pouring hot water into dispenser, as conditioner tends to get goopie when dry, thus may have clogged up
Dec 11, 2009 | Zanussi ZWD1470W Front Load Washer / Dryer
Wont take fabric conditioner clothes dont smell nice machine smells yucky
poor a bottle of bleach in the washer .....run the washer with no clothes...the blead should kill any mols or mildew causing the yucky smells......boil some water and poor it in the fabric conditioner hole, this should loosen anything clogging it...thanks
Nov 05, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
E10 code on a zanussi jet system washer
Is it a washer-dryer? E10 relates to a fault with the inlet valve.....usually the valve itself going open circuit.
Feb 26, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi washer dryer jet system does not work
Hi, this problem is caused by the recirculation pump which has either gone faulty or has been clogged up by to much washing powder/liquid! you will need to strip the machine top off first then the rear and the pump is located at the rear of the machine (depending on model ) it is easy to spot as it is the only one that has the hose attached to the pump which leads to the door seal. take it off check for blockages in the pump and pipe and hose if no blockage then replace pump. It will then work like new.........!
Good luck...................
Nov 20, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
ZANUSSI ZJD12191 WASHER/DRYER
Washer dryers often have cold water valves with 3 separate solenoids. One for the main wash and rinses (which is clearly ok) and one for the condition rinse (to take the fabric conditioner down) which is probably ok too, and the 3rd one is for the dryer. It's possible this 3rd solenoid has failed.
Washer dryers need on a steady trickle of cold water running into the condenser chamber to convert the steam into water, which then gets pumped down the drain.
Jul 19, 2008 | Zanussi ZWD1470W Front Load Washer / Dryer
Zanussi WJS1265W
Problem 1,
You can remove the entire drawer to clean it out it might be blocked.
Problem 2
Once again this might be the mother board, we had the same problem, easily replaced by a qualified engineer, it now works fine.
Oct 29, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi WJS1265W Front Load Washer/Dryer Logo
120 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
