Question about HP Photosmart R507 Digital Camera
HP Photosmart R 507.
I had connected my camera to its charging cord. While it was still charging, I switched it on by mistake. It is hanged now. Any key I pressed is not working. When I connected it to my computer by the USB cord, it still cud not get detected. I cant even switch off the camera. Kindly reply to my problem as soon as possible. Thank you.
    Problem Solver:
  • 32 Answers
It should not make difference by switching on camera while it is charging. The problem may be in button which you switched on let meknow whether is switch to other options or jammed? One thing You do please remove the battery camera will get off then again place the battery and hopefully if it really hanged the problem will get solved. kindly let me know what happened. Thanks Sangita
Posted on Jul 08, 2007
HP photosmart 725 battery is not charging
This camera takes a lithium battery and if it is left to fully discharge then you may never be able to charge it up again. Your answer may be another battery. Find a cheap third party battery to try it out.
Feb 22, 2015 | HP Photosmart R725 6.2 Mp 3x Optical Zoom...
Why wont my HP photosmart R967 turn on battery is new and docking station is fine but it will turn on if connected to docking station
It is likely the battery is not making contact properly or is not getting fully charged.
Check the instructions on battery connection on page 9 and confirm the lights are blinking correctly to show battery is charging.
http://h10032.www1.hp.com/ctg/Manual/c00717663.pdf
Aug 03, 2014 | HP Photosmart R967 10MP Digital Camera,...
Camera doesn't seem to accept a charge Camera
Yes. You need a new battery. I would assume the same. Have the battery checked or try charging it in the battery charging cradle overnight.
Dec 13, 2010 | HP Photosmart R727 Digital Camera
HP Digital Camera R717 Charging Flash Error
Try to run self-diagnostics test - press flash button while switching the camera on. One of them tests the flash functionality.
Nov 29, 2009 | HP Photosmart R717 Digital Camera
HP Photosmart M437 not establishing connection
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Apr 20, 2009 | HP PhotoSmart M437 Digital Camera
Error Message
Have you tried resetting your camera? To reset your camera, open the battery cover and you should see a small hole inbetween the SD card slot and the battery release switch. Then use a small narrow object (i.e. mechanical pencil with its lead extended) and press into the hole. You should feel it "click" and then hold it for about 3 seconds. Try restarting your camera.
Note: Please backup all the data on your SD card before doing this.
Hope this helps
Aug 14, 2008 | HP Photosmart R727 Digital Camera
Battery Won't Charge
Hey Guest9,
You can try resetting the camera by removing the memory card and the battery, pushing a straightened paperclip into the reset switch inside the battery compartment, and reinstalling the battery. If this works put the memory card back in. Another option you have is to try formatting the memory card.
Sincerely,
Allan
Go Ahead. Use Us.
Apr 16, 2008 | HP Photosmart R727 Digital Camera
HP Photosmart 507 with defect cardreader
If the camera is still functioning- let it be. Generally there are no parts or manuals for self repair.
Aug 05, 2007 | HP Photosmart R507 Digital Camera
HP Photosmart R507 Digital Camera Logo
109 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Marvin
Marvin
Are you a HP Camera Expert? Answer questions, earn points and help others
