Question about Dryers
Beaumark dryer model 66461t5ww not starting
Does not start at all. \power to unit ok
3 Suggested Answers
kdgrayson
  • 195 Answers
SOURCE: my beaumark dryer model # 640504191 has a motor issue
Sounds like a tension device came loose alowing motor to move into bad spot and cant run now
Posted on Aug 23, 2009
rylee_smith
  • 8619 Answers
SOURCE: Whirlpool dryer model LEB6300 series..
Hi
Thanks for using FixYa. If you have already checked all these things including the thermostat & thermal cut off and it still won't start then the issue is with the electronic control going bad and should be replaced. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 17, 2010
Dryer will not run
though there is power supply to the unit but don't start you have to check the door switch. if switch is ok and still unit don't start check the starting capacitor if equipped. replace if bad. if unit won't start even with a good capacitor and good door switch , then check the motor switch. if motor switch is bad replace the whole motor. switch and motor are sold together.thanks.
Mar 01, 2016 | Whirlpool Dryers
Beaumark model 660504191 - makes a noise drum off
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 13, 2011 | Kenmore Dryers
Frigidaire dryer model FDE336RES2 won't run when you push the button. How to troubleshoot? I check power to unit and its OK. could it be the thermal limit part?
There can be many reasons why your dryer will not start orturn...
heatman101
Sep 21, 2010 | Frigidaire FDE336RE Dryer
My beaumark dryer model # 640504191 has a motor issue
Aug 23, 2009 | GE Dryers
Beaumark washer model 57751h1ww no start no filling water. jb
Check line voltage plug, make sure there's power. check timer or water inlet solenoid valve, that's where you connect your water inlet hose. unless machine is fill, it won't start. but check power first. make sure there's electricity to machine.
Aug 02, 2009 | Maytag Neptune MAH5500B Front Load Washer
Beaumark washing machine model 57751h1ww not
hi, check power, make sure you got power, check water solenoid valve at back of machine, check for clogging, or put machine on and listen for hum, on water valve, if there's no hum, possible need new valve, normally they burnt out after a while, especially if you are in an area with low water pressure, or sometimes they get stuck, give it a tap. good luck.
Aug 02, 2009 | GE Washing Machines
Kenmore gas dryer model 75291. The gas dodes not start
first, check to make sure gas present to unit, and power to the ignitor. if no power, replace timer, if power, check the ignitor for continuity, if open, replace. If ok, check to make sure none of the thermostats are open, if they are, replace. If ok, check gas valve solonoids, they should not appear melted or stuck, if so replace. If still no function, replace gas valve.
Jun 30, 2009 | Dryers
Dryer won't start
ck your thermal fuse on rear of unit first, depending on model it might stop all function. (part number 3392519) whote maybe 2 inch thermastat located on rear wall of dryer. and yes the bnlower is LFT if needs removing
Mar 08, 2008 | Dryers
Dryer not turning on
most likely its the timer it has electrical contacts built on the timer that allow it to start its cycle if the timer has bad contacts it wont allow dryer to come on
Jan 21, 2008 | Dryers
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
