Question about Canon Pixma MP450 All-In-One InkJet Printer
Paper wont feed all the way through the printer.
The paper goes in about an inch or so, then goes sideways and crumples. I have looked for something stuck in the printer, but have not seen anything. I have carefully turned the printer upside down, hoping something would fall out, but nothing. Is there a way to get the paper feed to open so I can check for foreign material stuck in there?
I had the same problem and suspected that there was something stuck in the printer. I could not find maintenance manuals for free so I messed around with it for a while and found a temporary solution. There is a lever inside the printer and if you turn it to envelope setting it seems to give more allowance for the paper and it goes through okay. I think it is not a permanent solution because there is a screw missing and I suspect that it is stuck inside somewhere but the lever trick works. It is where the paper comes out after it is printed; at the front, bottom of the printer. If you find the instructions to open the printer, I'd appreciate them!
Thanks, Helen
Posted on May 19, 2009
Ink cartridges move back and forth, paper feeds and half way goes sideways creating a paper jam
check closely where the paper is moving sideways.. there is something obstructing the paper path, piece of paper a staple or something.. look closely
May 03, 2014 | HP Photosmart C3180 All-In-One InkJet...
Paper mismatch officejet 6500 crumples
There could be a foreign object or torn piece of paper that's stuck further inside the printer mechanism path. Try using a flashlight and inspecting any access or clean out hatches. Sometimes something will be caught inside and cause the paper you feed in to crumple and create a jam. I watched a video on youtube giving different ideas on how to fix this problem. Fixing Paper Pick-Up Issues
May 27, 2013 | HP Officejet 6500 Wireless All-in-One...
Hi my name is Lecette. I am having some trouble printing on my lexmark x5470 printer. When I print the paper slides in 3 inches and starts to crumble up and jams. Is there any way you can assist me with...
if the paper is crumpling up then something is stopping the paper from moving check the paper path for obstructions. if your first set of feed roller are moving and the second set is not then this will happen also
Dec 04, 2009 | Lexmark X5470 All-In-One InkJet Printer
The paper will not feed in all the way. it starts
The paper feed roller needs to be cleaned, you will have to take the printer in for a service.
Aug 04, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Paper feed problem-wont go through- crumpling up as it tries to go through
You probably have a piece of paper stuck at the place where it's crumpling. Take a good look and carefully extract it. It may be small, so look hard.
May 01, 2009 | Office Equipment & Supplies
Printer wont feed paper says out of paper
you "may" have something stuck on one of the feed rollers - a ripped piece of paper or something. See if you can examine the rollers, and look very carefully, particularly on the side that the paper keeps jamming.
In all honesty though, printers are pretty disposable these days. They're not worth getting fixed, and if you can't do quick maintenance on them, getting a new one is your best solution.
Mar 19, 2009 | Lexmark X4650 InkJet Printer
The paper wont go through the printer
Hi there ok Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jan 23, 2009 | Canon Pixma MP450 All-In-One InkJet...
Paper gets crumpled and wrinkled and won't feed.
is printer new i would take it back if u can if not go download ther latest driver ok may fix it up best u can do try feeding paper throw it fe w times train it
Oct 09, 2008 | Lexmark X2600 InkJet Printer
Canon i9950 feed issues
  1. Turn the printer off and open the access cover.
  2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
  3. Turn the printer on, load some paper, and press the Form Feed button.
  4. Watch the paper as it feeds through and try to determine where the jam is occurring.
  5. Check to see if all the rollers are turning.
    If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
    If not, there is probably a feed motor or a gear problem and the printer may require service.
  6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
  7. Turn the printer off.
  8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
  9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Apr 26, 2008 | Canon BubbleJet i9950 InkJet Photo Printer
Paper jam
If it is getting crumpled in the tray, there is something blocking the paper path.
What I would suggest is taking out the toner and drum cartridge, then remove the paper tray. Tip the machine on it's back and look into the paper feed area for something blocking the paper path.
When it is crumpling the paper like that, the feeder is working fine, just something blocking the paper path.
You can take a minela folder, and gently push it through the paper path to dislodge the obstruction.
Mar 31, 2008 | Sharp AL 1631 Copier
Canon Pixma MP450 All-In-One InkJet Printer Logo
139 people viewed this question
old marine
old marine
