Question about Toshiba Tecra M1 PC Laptops
Cursor moving erratically
Everytime i hit the spacebar, my cursor flies to the top of the screen then starts moving on its own.. what can i do.. i tried using an external mouse but it still does the same
  • Anonymous May 22, 2009
    I have totally disabled the touchpad through BIOS on several laptops and the problem still occurs.
  • 35 Answers
Sounds like your internal mouse maybe be malfunctioning and due to the pressure on the spacebar is causing the erratic movement.
To fix this you can enter your BIOS with the F2 key at startup.
Continue through until you find some input options to disable the internal mouse.
Posted on Jan 23, 2009
HOW DO I REDUCE SCREEN TO SHOW UP=DOWN TOOLBAR ON RIGHT SIDE
when on google top right corner of page tools icon 1 left click zoom to page size required
Mar 04, 2015 | Compaq Computers & Internet
Problem with spacebar key
I don't quite understand why this would happen after pluggin in a USB mouse - but I've seen it numerous times after a liquid has been spilled on a keyboard.
Sounds like you need to replace the keyboard. Best way to test this is to plug in an external usb keyboard and see if you can type normally on it.
If the laptop keyboard exhibits this behavior, and the external keyboard doesn't - you should replace the laptop keyboard.
Dec 30, 2012 | Dell Computers & Internet
I get ERR: DOMAIN everytime I try to inverse a matrix
  1. First, Press the "MATRX" button
  2. Next, enter a matrix into the calculator. To enter a matrix, press the arrow that points to the right two times when the cursor highlights letter "A." This moves the top cursor to "Edit." Press "Enter" to select the "Edit" option.
  3. Next,, enter the matrix's numbers into the matrix on the calculator. Press "Enter" to move the cursor over one column. Press a button that has a dash symbol within parenthesis [( - )] to move down one row. Repeat the steps until the matrix is completed.
  4. Next, Press "2nd" then "Mode" to go back to the home screen. Press "MATRX" to enter the matrix screen again.
  5. Finally, press "Enter" when the cursor highlights matrix "A" then press "[x^ -1]." Your screen should read "[A]^ -1." Press "Enter" again to display the inverse matrix.
    I got this information from eHow.com
Dec 07, 2010 | Texas Instruments TI-83 Plus Calculator
ACER ASPIRE 5517 Notebook computer. Erratic cursor
i have seen this problem in other laptops and the mousepad had to be replaced.
Apr 27, 2010 | Acer Aspire One PC Notebook
Cursor on my keypad jumps around
If your cursor moves erratically on the screen (for example, if it jumps around the screen, moves at varying speeds, or selects items on its own), perform the following steps:
1. Clean the surface of the touchpad with a dry, soft cloth to remove grease, sweat, moisture, or other liquids.
2. Adjust the sensitivity of the touch pad:.
a. Click the Start button and click Control Panel.
b. Click Printers and Other Hardware.
c. Click Mouse.
d. When the Mouse Properties window appears, click the Pointer Options tab.
e. Under Select a pointer speed:, click to move the slider bar closer to Slow.
f. Click OK.
g. Check to see if the touch pad still behaves erratically.
3. If the touchpad still caused the cursor to behave erratically, attach an external mouse to your computer and restart your computer. Use the external mouse to see if your cursor still moves erratically.
4. After connecting an external mouse, uninstall the touchpad driver from the Device manager listed under the "mice and other pointing devices" category and restart the Computer.
5. Download the Touchpad driver compatible to the Operating System installed on the Computer from the manufacturer's site and install it after restarting the Computer.
Good luck!!!!!!!!!!
Sep 18, 2009 | Dell Inspiron 6000 Notebook
Frustrating problem with spacebar causing skip
did you tried to clean the inside of the keyboard coz sometimes the dust is the cause why some characters not working properly.
Sep 16, 2009 | Computers & Internet
Whenever im typing and hit the spacebar the cursor skips. its driving me nuts. pelase help me.
Could be something wrong with the spacebar on your keyboard. Try another keyboard and see what happens.
Hank
Aug 04, 2009 | HP Computers & Internet
Menu bar moves up off screen
Just hit F11 to take it out of full screen mode.
Please rate this solution.
Jan 14, 2009 | HP Pavilion dv4000 Notebook
Erratic cursor
It happens with both? Sounds like it may be a driver or motherboard issue.
Check the HDD for errors with Checkdisk (Start -> Run -> cmd -> Ok -> chkdsk /f
Try redownloading the touchpad/mouse drivers from the Toshiba site
Oct 22, 2008 | Toshiba Tecra M1 PC Laptops
Cursor jumps around
    1. Click the Start button and click Control Panel.
    2. Click Printers and Other Hardware.
    3. Click Mouse.
    4. When the Mouse Properties window appears, click the Pointer Options tab. (Figure 1)
      Figure 1: Pointer Speed
    5. Under Select a pointer speed:, click to move the slider bar closer to Slow.
    6. Click OK.
    7. Check to see if the touch pad still behaves erratically.
Aug 14, 2008 | Computers & Internet
Toshiba Tecra M1 PC Laptops Logo
498 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
