Hi ya,
Replacing the belt on some whirlpool Washing machines.
remove lower access
panel. remove the 3 screws securing the pump and remove pump from motor
shaft. The pump should drop low enough that you will not need to remove
the pump hoses. Once the pump is removed, the belt can be installed
around the motor pulley and idler. Replace pump.
Web site and schematics below. You can open them into the whole window and buy parts there too!
thank you Huuum
Please leave a solved rating before you sign out
What is the problem with your washer, because looking at the model of your washer.. it a gear driven system not belt..
