Question about Haier HLP140E Electric Portable Dryer
Temperature lights keep blinking and dryer won't run
The light on my whirlpool duet dryer keeps blinking on all settings, won't start
push power button on push any cycle button hold down 3-5 seconds release push 4-5 times . if that don't fix it unplug for 30 min try that. let me know if it works might check lint trap also
Mar 18, 2013 | Dryers
Copier won't run. it blinks the letter H and the number 4
H4 Trouble Description
The set temperature is not reached within 90 sec after turning on the power (the heater lamp lights up after 1 sec from turning on the power relay).
After reaching the specified temperature, abnormal temperature is detected.
Cause:
- Heater lamp open
- Defective installation of thermistor
- Thermostat open
Hope helps.
Sep 20, 2011 | Sharp AR-M205 Copier
Kenmore 70 Series Dryer won't turn on. I don't think it is a door switch problem because when I hold down the door switch to make the dryer light turn off, the dryer still won't start. I...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 19, 2011 | Kenmore Dryers
My dryer won't work! The light works and the lint
Hi
I believe that everything else is fine rather it is the thermal fuse that is located inside the rear panel to the exhaust duct that is bad and should be replaced. If you want you can test this fuse for continuity and if it is bad then it should be replaced, as it cannot be reset. If the fuse is fine then it can be due to the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 27, 2011 | Kenmore Dryers
Kenmore model 665.13243 normal wash light is blinking and won't start the new cycle
heatman101
Jul 07, 2011 | Kenmore 65924 Electric Dryer
I have a fridgedaire front load dryer (Model AEQ6700FS0) and it will start up, run for about 30 seconds and then it stops tumbling and the 3 lights on the far right (drying, cooldown, extended tumble)...
This is just a guess in a way, as I don't have specific knowledge about your particular model, but could it be a wrinkle prevention feature? I know some dryers have a feature which will cycle the dryer on for an occasional short tumble if the regular cycle ends and the clothes have not been removed. Opening the door might be all it takes to cancel the function.
Jun 30, 2011 | Dryers
Won't run. Selecting mode and pressing start results in beeping and time remaining display blinking.
heatman101
Jun 25, 2011 | Dryers
Haier HLP140E Electric Portable Dryer Logo
Top Haier Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Bill Long
Are you a Haier Dryer Expert? Answer questions, earn points and help others
