Question about Refrigerators
Sanyo fridge model SR1282-2 troubleshooting - Refrigerators
I recently purchased a used apt sized Sanyo fridge (freezer on top). The problem I'm having is the light comes on & motor sounds like it's running but it won't get cold. Neither fridge nor freezer...
Is there a light inside? If so, maybe, the light isn't going off, when the door is closed. Just food for thought. I'm not an expert with this equipment. Check the thermostat. Is it set correctly? Go all the way one way, and see, if it makes a difference, if not, go the direction. Good luck.
Aug 15, 2014 | Refrigerators
Sanyo mini refridgerator won't get cold
This sounds to me like your fridge might be in defrost mode. There should be a switch up toward the top of the fridge near the cold setting. It's not always very visible, but feel around for a little round hole. There should be a small, plastic rod sticking out. Push it back in. (If it's out.) If this is the problem, you should hear the compressor turn on and the fridge should start cooling off again. If you still have the owners manual, it'll probably point you to its exact location.
I hope this helps! :)
Jul 23, 2010 | Sanyo Refrigerators
Thermostat switch comes on but fridge does not cool
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
May 28, 2009 | Sanyo SR-3660S Compact Refrigerator
Refrigerant line
how did this go for you? i am getting the same fridge for the same reason and wondering what you did with the freezer?
May 17, 2009 | Sanyo 4.4 cu. ft Counter-High...
Sanyo sr-1013w not cooling
sounds like it has a refrigerant leak somewhere in the unit.
Feb 20, 2009 | Sanyo BC-1206 Commercial Beverage...
Sanyo Mini Fridge
Same problem - When defrosting and moving away frost had a spray come from the left side of fridge. Can I repair - if a leak and how to add more freon?
May 03, 2008 | Sanyo SR-4910M Compact Refrigerator
Refrigerators Logo
51 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
