Question about Volvo Vehicle Parts & Accessories
I've got a Volvo 120E Wheeled loader with it gear shift solenoid s tripping to neutral
Outofworkjoe
  • 216 Answers
SOURCE: volvo won't shift to second,third or 4th gear
Try to flush out you old trans fluid,see if this helps first.If its brown,that's bad it needs to be red.
Posted on Mar 16, 2009
toneman2121
  • 775 Answers
SOURCE: 2001 Volvo s60 D5 very difficult to shift gear
if you have a hydraulically assisted clutch, check the reservoir. it's located on the firewall in the vicinity of the brake vacuum booster. if it's low/empty, fill it. you may have air in the system which will require bleeding. what is the mileage? you may be due for a clutch. if you google, "hard shifting manual trans" you will gain more insight on the matter.
Posted on Apr 13, 2010
ftw1952
  • 10319 Answers
SOURCE: first gear drives fine but
the symtoms all refer to a sticking piston it the valve body
Posted on Jan 06, 2011
SOURCE: E40d trans will not shift into 3rd or 4th gear, only rev. 1+2
check or replace your thottle position sensor tps that trans needs to know where the throttle is to shift if it is bad it will do as you say wont shift to third
another telltale is it will act like it goes into lockup when shifting into reverse and stall the engine
Posted on Feb 19, 2011
SOURCE: 2001 Kia Sephia automatic trans seems to be stuck in second gear, when manually shifted into first, starts off perfectly fine. When in drive, very sluggish on the take-off and does not shift out of th
Alot of people have the same problem, including me. Changing the transmission fluid is not going to help this problem. THe transmission filter is not something you change as much as you clean and reinstall, its just a metal screen. Call Kia and ask for an "OVERDRIVE SHIFT SOLENOID" they will need the last 8 digits of your VIN, vehicle identification number, to locate your part. I am in the process of changing mine. The part number should be something like 46313-39051. That number is for a 2001 Kia Optima, with the 4 cylinder. There are three shift solenoids bolted to the bottom of your transmission should. I'll let you know what the difficulty level when I am finished.
Posted on May 05, 2012
Shifts hard from 2nd to 3rd recently changed fluid and filter also down-shifting
Transmission Harsh shifting - YouTube
? 3:59
https://www.youtube.com/watch?v=aAoiL4vR8Qw
Jan 13, 2013 - Uploaded by James Burns
hi i have a 2004/05 misubishi lancer just recently the neutral light keeps ... Should I just change the fluid and ...
Why is My Transmission Shifting Hard? - BlueDevil Products
gobdp.com/blog/why-is-my-transmission-shifting-hard/
Jan 2, 2014 - Is your automatic transmission giving you trouble or shifting too hard? ... It was a great idea to get your transmission fluid and filter changed and to keep .... I have 2014 chevy traverse, when you down shift and at the end of a gear ...... It mayalso be due to the 3rd gear shift solenoid going bad so that may be ...
Transmission Will Not Shift Properly : Volvo S80 Common ...
repairpal.com > Problems > Volvo > S80
Jan 01, 2016 | Cars & Trucks
My 1999 Volvo s80 2.9 would not shift out of 3rd gear for about 500 miles. After a 3 1/2 highway trip upon exiting the freeway the trans no longer worked. Engine runs fine but no power to wheels. Is this a...
Most likely an electrical issue. If driving so long in third didn't blow it. Most common issue I have came across are shift solenoids. Did any codes/ lights come on the dash? Shop time for replacement is around 7- 7.5 hours. Not easy to get to. And worth changing all at once, assuming that's the issue. Did the car shift into neutral after third and then drop back to third?
Jan 27, 2015 | 1999 Volvo S80
Trail blazer gear shift button
Could be the brake switch or the shift lock solenoid. You may be able to turn the key lock to the unlock position, move the shifter out of park, then start the engine in neutral.
The shifter and the shift lock solenoid would need to be inspected.
Jun 19, 2013 | Cars & Trucks
Gear shift solenoid or transmission problem?
You needed not pay $4000 for any transaxle,you got taken big time
They cost about $2500 tops to rebuild
The shop never diagnosed the original issue,new trans needed or not
Dec 03, 2012 | 2000 Honda Prelude
I have a 1998 Dodge Dakota 3.9L/6CYL. I noticed a weird noise when I was driving and switching gears. My truck started acting weird in 1st gear going into 2nd. I added some ****** fluid since it was a
yeah, it does sound like dirty fluid or even that solenoid, which is usually the shifting culprit, you might want to stay away from changing that valve tho, it is very involved, and the valve body has to come off, which there are two bearings which govern the direction of fluid flow, so stay away from that, just do what you can do which is the filter and the solenoid. you'll be fine.
May 23, 2017 | 1998 Dodge Dakota
Loose stick shift
I've experienced this on a Volvo and it was the linkage bushings. Stiffened it up nice!
Jan 10, 2012 | 2002 Dodge Stratus
1992 volvo 960 there are 3 buttons next to shifter W,S,E What are they for?
The three buttons are "W" - Winter is where it shifts straight into third gear so that you do not spin your tires in water or snow. "S" - Sport is for higher speeds such as passing, bad on mpg; and "E" - Economy is for daily driving. You can go into any of them on the fly, it's not like shifting into four wheeled drive.
Hope this helps (remember to rate this answert).
Apr 14, 2011 | Volvo 960 Cars & Trucks
Vehicle Parts & Accessories Logo
23 people viewed this question
Top Volvo Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
bosy1
Are you a Volvo Vehicle Part and Accessory Expert? Answer questions, earn points and help others
