Question about Hitachi 53UWX10B 53" Rear Projection Television
Colors overlap on left third of screen!
Hello this my first time posting anything on here, I'm looking for some help. When facing the TV the colors on left third of the screen are overlaping. I'm not sure if it's the convergence or something I can correct in the settings. It was a huge headache just getting it into the house, I'd rather fix it myself than trying to lug it to a TV repair shop. Thanks in advance, Frank
  • Francis Kashat Jul 08, 2007
    Thank you very much for the reply, I actually just received the set from my uncle. It was like that when he gave it to me. There aren't any speakers or anything like that near the TV.
    It's almost as if there are two screens and they aren't lining up on the left side.
    Do you know of anything I could try and do to fix it?
    Thanks in advance,
    Frank
Yes it is convergence, but the first things to think about are. Did the set get bumped when you moved it? If so likely one of the guns is out of alignment physically due to jarring. However the other next best thing to look at, is if the set is near any type of magnetic object, mainly like a stereo speaker (larger ones) so if that is true, try moving it away slowly while the set is playing to see if it clears up. Lastly that the screnn itself is off or broken again a physical problem to resolve.
Posted on Jul 08, 2007
SOURCE:
What is convergence IC problem
Convergence has to do with how different colors are displayed on a screen or monitor - typically the rear projection and some other types. When colors are overlapping to create unexpected combinations, or leave gaps between areas where overlapping is expected that results in a shifted red, green or blue image strip or edge - that is an indication of a convergence issue. They can look like this in severe cases:
Colors will drift, so manufacturers often include a utility to help you nudge the colors back in the right place. Most times this utility is buried in the Set Up Menu and when activated, produces a screen like this:
You will need to adjust the red, green and blue colors for each cross so that only a white cross is displayed. Keep red, green and blue fringing to a minimum. When you're done, the screen should look black and white, symmetrical and straight - like this:
Problems arise when you are no longer able to coax the utility to give you these crisp, B&W results with no red, blue or green ghosting. This is often due to a failing convergence integrated circuit ("Convergence IC"). Many times, replacing it will solve the problem, but other times it can be the result of failing components either ahead or after this IC. If you're attempting to replace this IC, please make sure the TV or monitor has been *unplugged* for 24 hours or more to allow the dangerously high voltages to dissipate.
Sep 08, 2014 | Hitachi 50VS810 50" Rear Projection HDTV
Samsung lcd tv with double image on screen
T'Con board should be suspected. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1300 posts to different brand TVs now. Pull up older posts there.
Nov 26, 2012 | Samsung LN46B610 46 HDTVReady LCD TV
I HAVE A TOSHIBA 37AV502U, THE PROBLEM I'M HAVING IS THAT THE COLOR ON THE PICTURE IS WRONG, IT'S A BIT HARD TO EXPLAIN BUT IT LOOKS LIKE THE PICTURE WAS TYE-DYED OR SOMETHING, YOU CAN SEE THE CABLE...
IF THE MENU LOOKS CORRECT THEN IT WILL BE A MAIN BOARD FAILURE IF THE MENU LOOKS GOOD THEN IT COULD BE T-CON BOARD FAILURE. CHECK ALL CONNECTIONS BEFORE AND AFTER THE PARTS ARE REPLACED.
Dec 17, 2010 | Toshiba 37AV502U 37 in. LCD HDTV
Screen words are overlaping??
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 20, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Colors arched and overlapping
if the option for convergence is still listed under the setting section of the on screen menu, then you need a convergence power supply board. If the convergence option is missing from the menu you need the ITC222 convergence missing repair kit. You can get either one at the following link they include instructions for the repair.
http://www.tvrepairworld.com/
Jul 13, 2009 | RCA R52WM24 52" HDTV Projection Television
Samsung HCN4727W Rear Projection TV, green screen, audio works
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 10, 2009 | Samsung HL-R4667W Rear Projection...
Blue and red overlap shadowing
convergence ic's are your culprit. they are responsible for aligning the 3 colors your tv projects onto your screen..
Mar 15, 2009 | Mitsubishi WS-65807 65" Rear Projection...
2 separate colors on screen
sounds like your convergence IC's have finally gone bad.. they seem to last 5 years on average.. have a look here: http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 19, 2008 | Sony KP-53V75 53" Rear Projection...
Blurry shadows in red and teal.
Just click below for convergence repair kit;
http://servicemanuals.vstore.ca/
Picture look double and the colors red come out the bottom of the screen on the lower left symptom is for busted convergence IC,you must replaced this IC in order that will works better again.STK 392-xxx ICs and it's associated resistor,this resistor automatically change value,can caused truoble even though you change the ICs.If you bring this to a service center they cost you $600 to $700,but if you buy the repair kit you can save more,don't wory it is very easy because there is intallation guide including in the repair kit. Feel free to ask whatever the result... click the link for sample picture guide step by step installation;
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Sep 25, 2008 | JVC AV-48WP30 48" Rear Projection...
Colors don't line up on left third of screen!
try going into your options menu and do a convergance it should be pretty easy there might even be a auto converge hope that helps
Jul 11, 2007 | Hitachi 53UWX10B 53" Rear Projection...
Open Questions:
See all Hitachi 53UWX10B 53" Rear Projection Television Questions
Hitachi 53UWX10B 53" Rear Projection Television Logo
42 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
