Question about Proform 350 Treadmill Walking Belt
How to lube proform 350 - Proform 350 Treadmill Walking Belt
Proform xp threadmill immediately shuts down and flips the breaker
see the video and LUBE, this happen because the lack of maintenance schedule of lube.However if the problem persist after you did lube, see my persosnal TIPS for motor helps, and test it. a) main motor b) control board. c)old board deck too.God bless you8eec0b2b-b4e5-480b-a21f-11224625d652.jpg7ee45112-69c5-41ab-86a0-1794a9d3376d.gif
Mar 27, 2013 | Proform Exercise & Fitness
Proform 860 competitor motor wont run
Lube the deck belt with 100% siicone or wax
2) Lube the rollers bearing
3)test tbe drive belt for worn
4) Test the input voltge motor, if there are the motor need repair, see my personal TIPS for motor help
5) Test the the output board, for input voltage motor if there are Not the board is faulty.
God bless you
Dec 05, 2012 | Proform 860 Competitor Treadmill
Loud clunking noise in rear roller of proform 580 treadmill
You must LUBE the deck belt first, this happen because you do not lube maintenance schedule, Do it every week from use.Maybe you have a WORN deck belt.
2) LUBE the rollers bearing front and end, use WD-40
3) Test the drive belt motor, for cracking or worn, and replace.
God bless you
Nov 29, 2012 | Proform XP 580 Trainer Treadmill
Proform 780cs motor is very loud. Funtions properly just suddenly loud.
1) LUBE the deck belt, the lack of this produce enough frictiona and loud, maybe you have a WORN deck belt.
2) LUBE the rollers bearing too.
3) Test the input voltage motor, if there are the motor is faulty, repair.
4) Test the output voltage board, for input voltage board, if there are NOT the board is faulty.
God bless you
Nov 24, 2012 | Treadmill Doctor Proform 780 CS Treadmill...
My proform 345 stops almost every time i get on it. i usually have to let it warm up 10 minutes before it runs ok. whats going on?
1) you must LUBE THIS Happen because the machine has special design for to protect the electronic system. Maybe you have NOW WORN deck belt, time to replace.
2) Lube the rollers bearing too
3) test the bearing for the main motor. and repair
God bless you
Nov 14, 2012 | Proform Crosswalk 345s Treadmill Walking...
Proform 540 treadmill stopped working
1) Lube the deck belt, this is problem by possible deck worn.
by that reason produce enough friction, causing to the electronic system shut down for protect.
3) Measure the input voltage motor, if there are the motor need repair.
4) Measure the output voltage board, for input voltage motor, if there are NOT the board is faulty.
5) Try to RUN the sofware calibration for diagnose and troubleshootign
God bless you, See the block diagram
Jun 13, 2012 | Proform Exercise & Fitness
I replaced the belt on the Proform 530x and it still sticks. I have also tried to silicone spray the deck,. Help ?
You must LUBE very well the deck belt. 2) adjus the roller bearing and LUBE very well 3) Motor can be LUBE follow the instruction manual for LUBE. 4) Adjust the deck belt see the diagram.
sincerely. God bless you.
Apr 23, 2012 | Proform 530 Treadmill Walking Belt
Proform 400gi runs 2 seconds and just stops
Dear Sir:
This problem is by lack of LUBE in according with the instruction manual, proceed inmediately. RUn the software calibration for diagnose and trouble.
3) The Shut down is for protecting the electronic system components.
Produce enough friction and by that reason shut down.
4) See the deck belt is worn.
Apr 22, 2012 | Proform Exercise & Fitness
How do I best maintain the belt on a Proform 525?
read your manual- there is a small section that states NOT to use silicone/wd-40 on your item. You can use only the lube the manufacture(ICON) reccommends. Sears Parts store or parts on Phone 1-800- FON PARTS your part # is 06-831-135855 it is called walking belt lube The retail store does NOT sell this lube, they do sell the silicone spray-but its for the OLDER treadmills I know this I work on treadmills for the company!!!! with a little work, bypass the retailer, go to the source- they charge less...
Jan 07, 2010 | Proform 525C Treadmill Walking Belt
I have a proform j8 treadmill when you run on it for a half mile to a mile it kicks off then you have to wait awhile flip the breaker next to the on off switch. and it happens again
Check out treadmilldoc.com The very best free information and help you can get to fix your treadmill yourself. I would say off hand the belt needs lubed (at least once a year) with special lube. Do not use ordinary household lubricants. Or the breaker switch is bad. About $8 to 15$. It's tripping for a reason, clean and lube and then go from there.
Oct 12, 2009 | Proform Exercise & Fitness
Proform 350 Treadmill Walking Belt Logo
29 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
