Question about Oregon Scientific TP329 Two Way Radio
Do not start
No light and
My Holden barina won't start and check engine light is flashing
Check Engine Light On - Auto Diagnosis Repair Help
www.aa1car.com/library/mil.htm
The Check Engine Light (which is actually the Malfunction Indicator Lamp or ... you can assume the fault that is causing the Check Engine Light to come on is probably minor and won't hinder your ability to continue driving. ... When the ignition is turned on (don't start the engine yet), the tool will .... flashing check engine light ...
What Causes the Check Engine Light to Come on in a Car?
www.wisegeek.com/what-causes-the-check-engine-light-to-come-on-in-a...
Nov 7, 2015 - When the check engine light comes on, take the car to a reputable mechanic .... I went to go home. the check engine light was blinking and it won't start. ... I looked in my manual book for 2001 holden barina car to see what the ...
Car cranks but won't start, Check Engine light blinking ...
www.evolutionm.net/...engine.../424408-car-cranks-but-won-t-start-chec...
Jun 1, 2009 - I tried to turn it back on but it would only crank and not start, the check engine light is also being really weird, it's blinking on and off pretty quick.Missing: barina
Check engine light flashing car won't start - RX8Club.com
Dec 09, 2015 | Holden Cars & Trucks
Tip
How to reset AIRBAG SRS Light on 2003 - 2006 Infiniti G35 Coupe
Hi, on most vehicles, the airbag light should come on for at 6 seconds, and then go off if the system is working properly. If there is a fault or a problem in the system, the light will remain illuminated, or flash continuously. If the airbag light does not work properly, some vehicles have an audible tone that sounds indicating a problem with the airbag light system. When the light is on (or the tone is sounding), the airbag will NOT deploy, even in an accident. <br /> The flashing light on your car is telling there is a problem. <br /> <br /> <b>How to reset AIRBAG SRS Light on 2003 - 2006 Infiniti G35 Coupe </b> <br /> Ignition Key Method: <br /> <ul> <li>Turn IGNITION on (but don't start car).</li> <li>After the AIR BAG warning lamp lights for 7 seconds, turn IGNITION off within 1 second.</li> <li>Wait 4 seconds.</li> <li>Turn IGNITION on (but don't start car).</li> <li>After the AIR BAG warning lamp lights for 7 seconds, turn IGNITION off within 1 second.</li> <li>Wait 4 seconds.</li> <li>Turn IGNITION on (but don't start car).</li> <li>After the AIR BAG warning lamp lights for 7 seconds, turn IGNITION off within 1 second.</li> <li>Wait 4 seconds.</li> <li>Turn IGNITION on (but don't start car).</li> <li>Wait 3 seconds.</li> <li>Turn IGNITION off.</li> <li>Wait 2 seconds.</li> <li>START Car (the light may be blinking slower than before).</li> <li>Wait 3 seconds.</li> <li>Turn IGNITION off.</li> <li>Wait 3 seconds.</li> <li>START Car.</li></ul> <br /> <b>This is a little easier</b> To reset the light simply turn the iginition to the on position, (you dont need to start it). All the lights should stay on for thier diagnostic check. As soon as the airbag light goes off, before it starts flashing, immeditatly turn the car off. Repeat this 3 or 4 times (turning to on then off) and the light should go away
on Dec 07, 2010 | Infiniti G35 Cars & Trucks
Blinking lid locked light and green sensor light on machine won't start cycle
The good ol' Whirlpool Lid Lock Flashing Light Problem - ApplianceBlog
www.applianceblog.com/.../42456-The-good-ol-Whirlpool-Lid-Lock-Fl...
Dec 11, 2013 - 10 posts - ‎3 authors
Red Lid Lock light flashing intermittently when you try to start a cycle. ... I'm going to post what SENSING does first, then you will need to locate your tech. ... start with thelid lock on and blinking, or the unit will not start and spin. FIXED Sense light on light humming noise won't start ...
Aug 9, 2015
Whirlpool WTW4950XW not working
Nov 2, 2013
Stacked GE washer/dryer lights Blinking doeent start at ...
Feb 20, 2012
More results from www.applianceblog.com
Washer Sensing led (Green) on with the lid locking led (Red ...
www.shopyourway.com > Manage My Life > Questions
... this: Sensing led (Green) on, the lid locking led (Red) blinking with a clicking noise ... red led light goes off green led light stays on and the washer does not start.
Oct 27, 2015 | Washing Machines
Intermittent management light comes on at start up.
try having a scan toll read the faults then reset the ECM program
Mar 28, 2017 | Cars & Trucks
1998 terrano immobiliser fault wont start
hi, i have nissan terrano wen i switched on engine light flash and start engine its start then go of.nissan terrano patrol engine
Sep 06, 2012 | Nissan Sentra Cars & Trucks
I have a Frigidaire front loading washer LTF 2140FS2 that will not start. I press the Start button door locks, press again the Wash Cycle light comes on. Then after a few seconds all the cycle lights...
Hi
Press and HOLD the Start/Pause and Cancel buttons simultaneously. As long as the buttons are held, the failure code will appear in the display as an E followed by two numbers, a number and a letter or two letters, please post back with the error code for further assistance.
Daniel
Sep 25, 2011 | Frigidaire Washing Machines
The vehicle won't start!
It wouldn't start is the problem.
If it had started you wouldn't have noticed the lights.
Bad Battery?
At 37 degrees "F" I hope, a battery should start any car. Did you maybe flood it out while trying to start it?
Dec 14, 2009 | 2004 Buick Rendezvous
The start button will not light up. Other lights
are you getting water into the machine? if not it will not start up. you may need the water inlet valve replaced.
Oct 15, 2009 | Jenn-Air Dishwashers
CHECK ENGINE LIGHT
Any time the Service Engine light comes on the remote start is disabled for the engines safety. As far as the SES light, your dealer should be able to help you with the diag.
Nov 17, 2008 | 2008 Chevrolet Hhr
Battery and replace tail light indicator
The tail light warning could be the brake light on the rear parcel shelf.
Oct 29, 2008 | 2000 Toyota Camry
Oregon Scientific TP329  Two Way Radio Logo
22 people viewed this question
Top Oregon Scientific Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you an Oregon Scientific Radio Communication Expert? Answer questions, earn points and help others
