Question about Hobart A200 Stand Mixer
No power in 1 2 gears 3 runs great
Is there a shear pin for 1,2,gears
  • 640 Answers
Yes,but they are key's.I'm a hobart tech is the mixer apart?
Posted on Feb 12, 2009
  • Ed Hunley
    Ed Hunley Mar 03, 2014
    The only one shearing is on low speed gear. The beveled gear (under low sp. gear) part of the key isn't shearing. I had it apart, put it back together. Didn't see any broken teeth, or worn bushings. I don't know how to check the clutch(roller)bearings, or the metal springs that go with them.
  • Ed Hunley
    I can take it apart if you tell me what to look for. Your help is GREATLY appreciated.
Kitchen aid mixer will turn on but not rotate
If the motor is turning and the planetary is stationary then the 3 most likely causes in order of most likely are; 1) Broken fuse gear; 2) broken planetary pin; 3) broken fuse gear pin.
Sep 28, 2017 | Food Mixers
RESET A HOBART 140 QT MIXER
The V-1401 has a power bowl lift that is belt driven by the same motor that is used to mix. Remove top cover to check the belt. If belt is good and not slipping, is the operator handle working on /in the bowl lift gear box? If not, could be broken shear pin on handle or worn out parts in gear box. Next thing to check is the output shaft of the bowl lift gear box. If it is turning when the operator handle is engaged and the bowl lift jack shaft is not turning there is a broken shear pin between the output shaft and jack shaft. If everything is good to this point the bowl lift yoke has a large brass nut on back side of it that the jack shaft goes through. If the nut is worn the bowl lift yoke will slip, fall and/or jam. to unstick and lower the bowl , one can turn the jack shaft by hand. WARNNING : if the nut is worn enough the yoke can drop suddenly and it is very heavy.
May 06, 2015 | Hobart 140 qt Mixer Model V-1401 Used Mint...
Runs but doesn't turn. Worm gear is not broken.
Something must be broken if the motor is turning and the planetary is not. It will be one of the following, we will start from the first point of contact with the armature
1) Worm gear broken (fuse gear) you say no teeth broken
2) Worm gear not broken but whole unbroken plastic part not gripping aluminium boss
3) Pin through worm gear broken or missing
4) Pin through centre (or bevel) gear broken or missing
5) Pin through small gear in planetary broken or missing
6) Pin through planetary hub centre shaft broken or missing
The most common ones in order of likelihood are, 1, 2, 3 and 6
Dec 29, 2014 | KitchenAid KSM90 Ultra Power Series Stand...
Hobart A200 mixer. 1st gear has no torque, I can stop it by hand. I found the key sheared on the low speed gear(flat gear, beveled gear part wasn't sheared). I replaced the key, & it sheared it again...
Ed, if you continue to do it yourself, the end result will be tossing good money out. Have a professional check the system and save the unit from permanent damage. Chipping parts of a gear off means a serious resistance force or action has occurred. One force is slowing down as the other is speeding up. Gear alignment can be moved off center, or a sudden application (sudden stop or start) can damage the least resistant parts. For example, when a hook turns within the mixing chamber and the resistance of the content is too great on the turning shaft and gears, which ever part is weakest will break. Complicated I guess.
Mar 01, 2014 | Hobart A200 Stand Mixer
Hobart 20QT guessing old a200 motor runs fine removed top cover to see but gears not working and mixer does not spin Any diagnosis Help greatly appreciated
The first vertical shaft has a brass gear that runs off the rotor. The ancient models had a spring loaded slip clutch built onto the gear. Upgrade it with a worm shaft kit which gives you a complete new shaft and fixed gears. I think it includes the upper and lower bearings. Maybe replace the grease if it has not been done. Or look for a sheared key on the worm shaft.
Feb 19, 2014 | Food Mixers
Motor runs, beater stopped rotating. Some gear sounds heard before it stopped. Beater will not turn at any speed setting.
drive gear or shear pin stripped. Common on this model. Return to repair centre. Expect to pay approx $150.00 to repair, sorry.
Sep 14, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Clicking noises. Mixer doesn't have enough power to mix.
You have a drive gear that runs off the motor gear. That gear has a problem. It has either broke away from the weld or you have a pin or key sheared.
Oct 28, 2008 | Hobart N50 Stand Mixer
3rd gear spends at 1st gear speed with clicking noise
A key is most likley sheared on the center shaft.Take the gears off the center shaft.
Oct 15, 2008 | Hobart A200 Stand Mixer
Hobart a-200
HI CHECK ALL GEARS FOR A SHEARED KEY. IF IT HAS A ROLLER CLUTCH, COULD BE WORN ROLLER CLUTCH OR SPRINGS MADE OF SPRING STEEL BEHIND EACH ROLLER IN CLUTCH FATIGUED. YOU CAN CAREFULLY RUN MACHINE JOGGING ON OFF SWITCH WITH GEAR CASE COVER OFF AND CHECK GEAR ROTATION FOR SHEARED KEY. IT'S ONE MESSY JOB!!! SOMETIMES NUT ON TOP OF MAIN SHAFT UNDER CAP OUT OF ADJUSTMENT. SHOULD BE APPX. 1/2 TO 1 TURN FROM TIGHTENED. HOPE I GAVE YOU SOME ASSISTANCE, JOE
Aug 11, 2008 | Food Mixers
Slips in all gears
you have no speed 1,2,3 right?first thing to do is drop the planetary (this is the bottom with the beater shaft)undo the bolt and it will drop down.you will see 1 gear,that gear should not spin without the shaft spinning too.if it does you have a sheared key on the gear.if you have access to the transmission check the worm gear attached to the motor it has a roll pin through it make sure its not sheared.then look at the top left gear assembly and check for sheared (broken)keys.clean up all the parts,if you dont you could miss something.let me know.
Aug 22, 2007 | Hobart D300-6036 Mixer
Hobart A200 Stand Mixer Logo
117 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
