Question about Whirlpool GS6SHEXNL Side by Side Refrigerator
No ice production
My Kenmore Elite (106.50592003)Side by Side Refrigerator stopped producing ice. Water dispenser on door works fine. Freezer temperature is fine. Was getting no Status LED light - replaced emitter and receiver boards and now get normal Status LED light indications - but no ice is filling up bin after 24 hr wait. Slide switch is in ON position. Also, don't hear any water filling into icemaker. Don't have any diagrams or schematics. Will purchase service manual to get some additional insight, but any recommendations anyone has would be greatly appreciated. Thanks, Barry
    President:
  • 878 Answers
Http://www.fixya.com/support/t158377-ice_maker_sotp_making_ice_red_light Barry, check out the above post, it will give you instructions on how to jump start it. Reply back if you cant get to it. Catriver.
Posted on Jul 08, 2007
2 Suggested Answers
  • 159 Answers
SOURCE: Whirlpool Side By Side not making Ice, but water dispenser works
check to see if the water outlet tube in the freezer is blocked with ice. That is a common problem and there is a fix kit out to solve the ice problem. if the tube is not blocked you need to check the water valve for the ice maker and make sure its good. you will need a volt meter to check it. so check these two things out. And to check to see if the water tube is frozen ,stick a small screwdriver in it and check for a blockage.
Posted on Aug 07, 2007
Water won't dispense
The part of the=> 2188542 Water Inlet Valve may be defective while you may be getting ice from the ice maker side of the=> 2188542 Water Inlet Valve Let me know iof you have questions, Thanks Sea Breeze Questioins?38124827-761f-4fe9-a92b-e27c07b1020b.jpg
Jan 06, 2014 | Kenmore 57029 Side by Side Refrigerator
Kenmore side by side refrigerator Ice maker not working
Found out we still had a warranty/service contract on it. Contacted SEARs and I explained problem to technician. Scheduled house call is Friday.
Apr 14, 2009 | Kenmore Refrigerators
Replaced icemaker with new one but still not working
The ice maker has a problem The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
The ice maker has completely stopped producing ice
The ice maker is producing ice poorly
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs
Apr 01, 2009 | Kenmore 57029 Side by Side Refrigerator
I just resolved an issue with my kenmore elite side by side refrigerator icemaker (model 106).
It was expensive because I took the long road to fixing the unit myself.
My problem: No water going up to the freezer water dispenser into the icemaker but the water in front of the door working just fine.
-first thing i tried was the simplest. The Internet is clogged with this miracle fix of using a hair dryer to melt the frozen water line going to the dispenser output. This is highly unlikely for our model since the water line is protected within the refrigerator frame.
-2nd thing I replaced my water filter (thinking that there wasn't enough water pressure to trigger the solenoid valve. $40, and still no luck.
-3rd thing was I tested for voltage going to the solenoid. No voltage going to solenoid, so I wasted $30 for a new solenoid.....still no water.
-4th thing was I ordered a new IR sensor and receiver (since the reciever end is where the relay that sends the voltage to the solenoid to turn on and allow water to go up to the dispenser).
My IR sender and receiver appeared to be working flakey.
Installed, still no water. $58 BUCKS ON EBAY (EVERYWHERE ELSE $100+)
-I finally removed the freezer front little white door, I TURNED OFF THE FREEZER SWITCH SO NO VOLTAGE WAS PRESENT, removed the release latch underneath the freezer unit and disconnected, and removed the freezer unit to inspect it further.
When I removed the protective white cover that covers the mechanical wheel, I had a few parts come flying out of it. Turns out that the wheel accessories were damaged. THERE ARE NO REPAIRABLE PARTS ON THE FREEZER UNIT. I FOUND ONE ON EBAY FOR $39 BUCKS + $9 SHIPPING! $48 BUCKS, SWAPPED THE HARNESS AND BOTTOM COVER, AND IN 20 MINUTES, I WAS BACK IN BUSINESS. STARTED MAKING ICE IN ABOUT A HALF HOUR!!!!!
when in doubt, replace the freezer unit for $48 bucks! 7 out of 10 times it will fix your problems. All techs replace the IR set at the same time too which will set you back another $58 bucks.
Good luck! ;)
Mar 15, 2009 | Whirlpool ED5VHGXM Side by Side...
Water Dispenser Temperature not acceptable
This is a brand new refrigerator - I cannot solve the problem and I am returning the refrigerator to the dealer. Thank you, but I am not paying $ to fix a new refrigerator. I have tried everything.
Feb 02, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Internal water dispenser stopped working
I lowered the temp on the freezer to 4 overnight, by morning water dispenser is working fine. I think that when we changed the temp to 7 (in order to make more ice ) it froze the water pipe going to the dispenser. I am going to keep both fridge and freezer at 5 ,and hope this will not happen again.
Dec 31, 2008 | Amana AFD2535FES Stainless Steel Bottom...
MY ICE MAKER WON'T WORK
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 19, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Refrigerator stopped dispensing water
Either your water tank in the fridge froze up, the waterline that goes up the freezer door from the bottom hinge froze, or the switch that your glass hits is damaged. Do you hear any humming or noises when you put your glass up to get water?
Oct 27, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
New Kenmore Elite ice dispenser not working but water is
Should be no longer than 24hrs. Is the freezer good and cold.. has to reach a certain temp before icemaker activates. Might take little longer if you put a lot of warm things in freezer or refrig. when you made the change. Is there any water or ice in the icemaker itself? Water may not be getting to icemaker call them back out if it dont work soon thats what warrantys for :0)
Sep 02, 2007 | Whirlpool ED2FHEXN Side by Side...
We had the same problem with ours. We held a hair blow-dryer to the end of the water tube for about four minutes, and the little ice plug just fell right out.
Aug 06, 2007 | Whirlpool GS6SHEXNL Side by Side...
Whirlpool GS6SHEXNL Side by Side Refrigerator Logo
196 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
