Question about Kwikset Professional Door Lock installation Kit
Loose Kwikset Chelsea Deadbolt
My deadbolt is loose - I think it needs to be tightened inside the lock mechanism - tightening the face place does nothing. I cannot figure out how to get inside the mechanism. How do I get to it? The only screws are on the face plate on the side of the door.
I just had the same problem as samrpetrich with a loose kwikset deadbolt. Here's how I fixed it - on the inside of the door, take off the latch that flips the deadbolt in and out using a very small allen key. There is a round plate cover that is snapped on top of the inside deadbolt mechanism. If you look on the bottom aspect of this round plate you'll see where it snaps on; once I saw where to apply pressure it came off easily - taking off this plate exposed the two screws beneath that were loose. Once I tightened these, I snapped the plate cover back on, but the dead bolt latch back and everything is tight again. Hope this helps.
Posted on Jan 31, 2010
  • cheri_yancey
    cheri_yancey Jan 22, 2014
    Thanks for the info. Your instructions worked perfectly.
How do I tighten a deadbolt lock with no visible screw? It has key on both sides. Inside plate has 2 holes in it that I thought would rotate to expose screws. It does not. How do I proceed?
On the inside of the door, the lock has a trim ring around it. Look for a slot on the ring, place a flat screw driver into the slot and twist the screw driver to remove the trim ring.
Jul 19, 2014 | Kwikset Locks & Locksmithing
How to tighten up a loose face plate of a Kwikset Deadbolt door lock. This specific deadbolt lock doesn't have screws on either side. The face plate is so loose that I can spin it clockwise but it never...
The exterior faceplate is not the thing that fastens to the door, it just supports the lock cylinder and covers the hole in the wood. Inside the door the cylinder has a thin plate with two screws going from the inner door surface into the back of the part you put the key into. Removing the big nightlatch block you will see a metal tang on the inside sticking out. The two screws will be just to the left and right of the tang and so you can draw the lock cylinder inward from there, which will squeeze the outside faceplate bezel into the front door surface. These are great locks, I am installing one from the 1940's which even opens up to let you reverse the bolt angle and make the door open outwards if you want to for big industrial shop doors.
Mar 28, 2011 | Garden
I have a front door Kwikset "lever opening" front door key/deadbolt lock system which has come very loose, almost falling off. How do I tighten it up\?
on the inside of the door look on the bottom of the lock cover. There should be a hole with a screw or allen head screw. Remove the screw and you can access the the rest of the lock.
Feb 25, 2011 | Kwikset Professional Door Lock...
Deadbolt lock is loose and needs tightened. How do I open to get to screws?
The main attachment point is the door edge--usually two larger screws. If you want to take the whole mechanism from the door, you need to remove the inside latch button from the door face. That should also release the outside lock part. Hope this helps!
Aug 13, 2010 | Garden
Deadbolt loose,lock has no screws showing on the outside.how do i tighten deadbolt?
Usually the screws are on the inside by the thumb turn. If there aren't any screws there either... then you need to turn the lock case clockwise to tighten.
Hope this Helps,
RSMITH972278
P.S. PLEASE RATE ME
Nov 04, 2009 | Locks & Locksmithing
Won't unlock, handle is loose
Tighten all screws on lock to a firm tightness. DO NOT OVER TIGHTEN as to bend the lock casing! Snug only. Use powered graphite to inject into lock and add to key working it back and forth into the lock.
Jul 08, 2009 | Kwikset Brz Sgl Cyl Deadbolt
Loose top lock
tighten the two screws on the inside of the door phillips screwdriver
Jul 04, 2009 | Kwikset Brz Sgl Cyl Deadbolt
Need to disassemble deadbolt with concealed screws
If it's like my deadbolt, pull the inside faceplate off. It's just pressed in place and the screws are behind it.
May 30, 2009 | Kwikset Powerbolt/Electronic Deadbolt-...
Tighten the outside faceplate of a qwikset dead bolt.
The inside face plate snaps on. To remove it remove the T handle and use a small flat head screwdriver to genty pry it off. Behind the cover you will find 2 screws to remove the lock halves.
Don't forget to rate
Mar 12, 2009 | Kwikset Professional Door Lock...
Kwikset deadbolt
use the proper size alan wrench to tighten or loosen face plate . That is if you have not stripped that hole by putting the wrong tool to it. Under that plate is the 2 main screws to hold the hardware tight to the door.
Oct 27, 2008 | Kwikset Professional Door Lock...
Kwikset Professional Door Lock installation Kit Logo
4,735 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
J.D. Browning
J.D. Browning
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
