Question about Comtrend CT-507 Router
What's your problem?PCI\VEN_8086&DEV_27D8&SUBSYS_75291462&REV_01\3&11583659&0&D8
I need drivers for PCI\VEN 8086&DEV 2E32&SUBSYS
I need drivers for PCI\VEN 8086&DEV 2E32&SUBSYS 04051025&REV 03\3&11583659&0&10
Aug 23, 2013 | Compaq Creative Sound Blaster PCI 128...
Pci\ven 8086&dev 24c6$subsys
That is a hardware ID for the Intel AC'97 Modem Controller. Source: http://pci-ids.ucw.cz/read/PC/8086
Mar 17, 2013 | Intel Computers & Internet
Did a clean install of windows xp SP2 and am unable to connect to the LAN connection between the NIC board and the broadband modem. Error message tells me simple communications controller is missing. What...
Hello.
When you performed the Windows XP install, not all the drivers were available and installed.
To find and install the driver for the simple communications controller:
Go to Device Manager and click on the pci simple communications controller
Go to Properties and then Details. You will see a code like PCI/VEN_8086&DEV_27D8&SUBSYS...
The VEN code means vendor and the DEV code means device: in the example the vendor is 8086 and the device is 27D8.
Once you have the two codes, go to www.pcidatabse.com. Enter the two codes and you should get the name of your hardware.
From there, you can search for a driver download for your hardware.
Hope this helps.
Dec 21, 2009 | Office Equipment & Supplies
I cannot use internet for my modem driver has ? i need driver for pci simple communication controller. please help me.. so that i could use internet again. i'm using windows xp.
Look for the brand name of your modem and model. You can find it in the box of the modem. If you have it then go to there website in the internet and download there the driver.
Nov 29, 2009 | SimpleTech SimpleStation (STI-PNPR/PCI) PC...
I recently formatted a second harddrive on my dimension L933r to download windows 7 all works fine but i can not change screen resolution and now i can not find the drive for the pci simple communications...
Hello.
Not certain if you still need this, but ...
Hope this helps.
Nov 17, 2009 | E-Machines eMachines W2686 PC Desktop
My device properties is pci/ven 8086 dev 24c6 subsys c0051631. what driver it needed to run?
Get the motherboard driver from the manufacturer site and run it on your pc it will surely work
Oct 24, 2009 | Smartlink All 56K Modems: V.92 PCI Chipset...
I need drivers for PCI Simple Communication Controller for a older computer running xp
download 50000 pc drivers for xp from torrentz/mininova make sure u have either bitlord or utorrent installed on ure system 1st when download is done move folder from in downloads to your desktop now open up device manager goto the pci device needing driver should have yellow question mark at it and tell the pc to search your desktop and it should hopefully find it in the folder when done delete folder and make sure your not running utorrent/bitlord as you will be shareing this file with others
Oct 09, 2009 | Computers & Internet
Motherboard Simple PCI Communications Driver Code 28 for modem
Hello, Mike.
In case you still need this:
Hope this helps.
Mar 29, 2009 | Gigabyte GA-7VA Motherboard
Comtrend CT-507 Router Logo
614 people viewed this question
Top Comtrend Computers & Internet Experts
Julie Endres
mathur_1
Advaith Ganesan
Are you a Comtrend Computer and Internet Expert? Answer questions, earn points and help others
