Question about Philips Magnavox MWR20V6 DVD Recorder/VCR
Recording dvd's can my vhs/dvd player record my vhs movies on to a dvd?
    Habit-Forming:
  • 108 Answers
As long as the tapes do not have a copy gaurd on them they should record to the dvd. Home moves, tv shows that were recorded or unprotected tapes can also be dubbed.
Posted on Feb 17, 2009
pseudonym
  • 15 Answers
SOURCE: Samsung R155 Recording from VHS Issues
The reason why you are having this problem is because you haven't finalized the disc. In able for you to play that Burned DVD that you have you need to Finalized the disc. Finalizing a recordable optical disc means writing the disc's lead-in (the Table of Contents or TOC) and lead-out information (blank data that fills up the unused space at the end of the disc) so that a DVD player will know where the various tracks begin and end. Without the TOC, a conventional DVD player will not be able to read the contents of the disc. Once the disc is finalized, no more information can be written to it. Finalizing takes about two or three minutes. To finalize a DVD-RW/DVD-R: 1. Press the Menu button with the disc stopped. 2. Select Disc Manager and press Enter or the right arrow. 3. Select Disc Finalize and press Enter or the right arrow. You will be asked twice if you are sure that you want to finalize the disc. Select Yes and press Enter. Once the disc is finalized, you cannot delete entries from the record list. After being finalized, the DVD-R/DVD-RW (video mode) operates in the same manner as a DVD-Video. Recorded discs must be finalized in order to play back in non-Samsung DVD players. A DVD-RW disc that has been recorded by DAO (disk-at-once mode) in a PC cannot be unfinalized. A DVD-RW disc that has been recorded in Video Mode on a non-Samsung recorder cannot be unfinalized by a Samsung recorder. A DVD-R disc cannot be unfinalized. Note: Finalization does not apply to DVD-RAM. If you cannot finalize a DVD-R or DVD-RW disc, make sure that Disc Protection is turned off. If you are still having difficulty, you may try calling technical support of SAMSUNG. Note: Do not turn the recorder off while it is finalizing the disc. Data on the disc will be damaged if the finalization process is interrupted.
Posted on Sep 18, 2007
  • 1003 Answers
SOURCE: INSIGNIA DVD Recorder/VHS Recorder NS-1DRVCR
yes it has to be finilized use very compatable media by memorex DVD-R this wil solve everyones problems
Posted on Feb 02, 2008
SOURCE: recording from vhs to dvd
Direct copy VCR to DVD:
- Insert VHS tape you want to copy
- Insert a recordable DVD disc
- Press DVD copy button on front panel or remote control (to DVD).
- To stop recording press the stop button.
IMPORTANT: If attempting to copy copyrighted material the Samsung DVD-VR320 will detect the encoding and will not allow the copy to be made.
Posted on Apr 05, 2008
  • 4 Answers
SOURCE: go video dvd recorder vhs combo vr3845 - won't read discs - says unknown disc
FIRST UNPLUG THE UNIT FROM POWER !!!!! The problem is dirt/dust/****/crud/stuff on the tiny, little ***** laser lens. Remove the case screws ( 2 on each side, some in the back) with a correct size driver. The cover must be pulled open at the bottom, side to side a tiny bit ( use a hand on each side) to allow the cover to lift up at the rear, it must come up quite a bit as if it is hinged at the front and THEN pulled back out of the front panel. Set the cover to the side. The DVD reader/Burner is covered with a small black cover, it is held on with two TINY screws, STOP!!!! Get yourself the CORRECT size driver at Fry's or Radio Shack, DO NOT get cheap here!!! Remove the two screws and find the two plastic grip tabs, push them to release and lift the cover. There is the laser! It is a tiny blue lens about the same diameter as the tiny screws. find a very, very well washed CLEAN 100% cotton T-shirt. The softer the better, get 70% or higher rubbing alcohol, pull the fabric over the tip of the finger and wet with the alcohol. VERY GENTLY wipe the lens 4 to 5 wipes and the 3 wipes with a dry spot. That should clean the lens. USE NOTHING ELSE!!!!!! The lens tracks back and forth on two tiny bars. The stuff I use is WD-40 wet on a Q-tip swab. Go to a safe place to spray the WD-40 on the Q-tip. The lube should drip. With the Q-tip apply the lube to the tiny bars at the ponts of rider contacts and wipe the bars too. Put the top of the burner back> BE CAREFUL!! Use a magnet driver and then repower and try to read a known good dvd. You will have to do this more in the future, you understand, dist dirt etc in the air. Put the top back on. Enjoy.
Posted on Sep 26, 2008
SOURCE: panasonic dmr-es45v
The disc drive motor is burned out, its junk...if you didn't finalize the discs, they're junk too unless you buy another Panasonic DMR.
Posted on Feb 10, 2009
How to record dvd from vhs
There are some units that can do this, but if you are trying to copy commercially recorded VHS movies to DVD you will have issues. The VHS tapes have copy protection on them and all manufactured hardware to record these have been required by law to support the protection. Thus, you will get poor copy reproduction when copying. If they are home-movie style VHS tapes, no such issues exist. You can either get a unit that has both devices integrated and has copy capability, or you can you a VHS player and send the outputs to a DVD recorder.
Jul 09, 2016 | Televison & Video
I have Magnavox DVD player/vcr DV225MG9, does it record from vhs onto dvds? And if not, what do I need to get so that I can copy all of these old vhs movies to dvds?
it won't record dvd's its only a dvd player. only the vcr records
if the vhs movies your trying to record are movies like star wars and stuff like that it's copy protected and no worth the trouble. if it's home movies or something you recorded from tv they might work. if you get a dvd recorder/vhs player.
Jul 20, 2015 | Magnavox Televison & Video
Green tint on TV screen when playing DVD's or Videos 2nd problem and can't record anything
1: Hi i would recommend trying the recorder on a different tv to check if the problem continues. If the green tint is gone then its the tvs inputs. If it is still green then its the player or the cord. Try a different cord if the green tint is still there then the player has a problem.
2: Now for the VHS to DVD. There are general a lock out encoded on the VHS if it is a store bought movie. This is to protect the content on the VHS from piracy and that would case the DVD to be blank. The VHS to DVD are made for converting your home videos like family vacations and stuff you record your self and not for commercial movies like the ones you bye at the store. If you want to convert old VHS movies to DVD you would have to get another VHS player and another device in between the VHS player and the VHS to DVD recorder.
Mar 19, 2014 | Televison & Video
I have a Magnavox Digital Video Disc Recorder & Video Cassette Recorder. Model# ZV427MG9 A. When recording from a VHS home movie tape to DVD there is a high pitch squealing sound. When playing the DVD...
U play another movie like a Hollywood movie DVD disc play on it have no squealing noises wright?Yes,than the blank DVD discs batch u have is bad.Tries buy another batch DVD blank discs,tries recording again should solved this problems.
Mar 16, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
I have old home movies on these tapes.. I am looking into buying the Pinacle Dazzle DVD Recorder (convert) will this convert my tapes to DVD? Does anyone know?
You already have Movies on TDK E-HG 120 VHS tapes; All you want is to Transform the media on the tapes into another record Media or on DVD.
The following process would make possible the project
1. A DVD Recorder device would transform the movies already on one media to another media.
Note: The recorder that would be acquired should have a feed area for the VHS tapes on one hand, to be played, while on the other hand, a DVD disk area from which disk medium would be recorded.
Important Notes.
The devices required to make the process achievable includes
1. The DVD Recorder or Player alsoo known with multi perpose functionality for signal convertion capability
2. The DVD recordable disks on which to record a movies onto.
Caution
The process of recording would require selection features determinable on the recorder device else would produce movies with undesireable features
For example; VHS movies are appear in decodeable formats integral when displayed on VHS players. The caution is to select a signal conversion format suitable for movies that have to transform between recordable media.
1. A DVD disk medium has formats as design specification and on which requires consideration when attempting to transfer multi media or motion pictures.
Type of formats of decodes
NTSA standards
PAL standards
Mescem standards
NOTE;
Whenever the option is available, select NTSA or PAL for appropiate code transformation
Your DVD RECORDER DEVICE SHOULD HAVE THE OPTION TO RECORD CONSIDERING MOVIES ACROSS MEDIUM TYPES
REMEMBER;
consult professional advise before acquiring an devices and mediums
If any consultation is required, refer to user guides or manuals of the devices in question.
Consult a technical expert when the need requires it.
Dec 02, 2010 | TDK E-HG 120 VHS Tape
CAN I RECORD A MOVIE FROM VHS TO DVD?
Not if you mean recording within that 1 unit from VHS to DVD.You would need a second unit DVD recorder which normally requires a digital input of some sort such as a cable box or a self-contained digital scanner but I am not sure if that would even work.It would depend on what the media input was recorded on the VHS.
Sep 25, 2010 | Sanyo DVW-6000 DVD Player/VCR
I would like to know if it is possible to copy two vhs movies onto one dvd disk.
Yes, this should be possible, as long as the VHS movies are not copyright protected. Just make sure that the recording mode on the dvd is set to allow enough time for both movies. Just remember: the more you record onto a single disc, the quality of the dubbing (recording of VHS to DVD) is decreased.
Sep 09, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I want to put my VHS movies onto DVD's.
It will copy VHS to DVD. Provided that it is a home movie and not a copywritten movie from the store.
Jan 11, 2010 | Samsung DVD-V4600 DVD Player/VCR
I have a Magnavox ZV427MG9. I follow all directions in manual for dubbing VHS home movies to DVD but when I try to play the DVD back there's nothing on them.What am I doing wrong?
Depending on the procedure you may be pressing the record button instead of the D.Dubbing or Dubbing button. When recording from VHS to DVD you must first, load the blank DVD and VHS home movies, then play the VHS movies, then PAUSE the VHS movie when you want to START recording... then the only the you have to do is pressing the D.Dubbing button or the Dubbing button. If your VHS tapes starts to play after the Dubbing button is pressed you have been successful in Dubbing.
Aug 13, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Connect DVD recorder to Video player/recorder- transfer VHStodisc
hook the video output from vcr to dvd input at rear, then hook output from dvd to tv input. note; you can not record protected vcr movies you can only record tv shows from sattelite to vcr or dvd recorder. its best to record straight from sattelite to dvd recorder for picture clarity.
Jan 27, 2009 | RCA DRC8300N DVD Recorder/VCR
Philips Magnavox MWR20V6 DVD Recorder/VCR Logo
157 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
