Question about Sharp R-408J Microwave Oven
Microwave blew up after cooking an egg
Hi there, We were cooking what it was not supposed to be cooked in a microvawe: an egg. Of course the egg blew up. The microwave door opened because of the explosion, and it never turned on again...any ideas, do you think it might be a fuse ? Thanks Brand: Sharp R-404jk
    Problem Solver:
  • 18 Answers
Yes the internal fuse will have blown. I would also think the door latch switches and monitor switch will also need re adjustment
Posted on Jul 10, 2007
SOURCE:
My microwave starts running when you open the door how can i fix that
It is supposed to. It is designed that way. It put the light on and the extractor fan to remove steam and cooking smells. Some have a timer that continues to run for a few minutes after cooking. It is not emitting the cooking radiation when the door is open. The are at least three safety devices to stop that.
Oct 06, 2017 | Microwave Ovens
Power it stays at 100% want 50%
Most microwave ovens I am familiar with have adjustable power levels.
Sep 11, 2016 | Panasonic NN-H765BF 1250 Watt Microwave...
We own a Panasonic 1100 watt Inverter microwave. It has worked fine until recently - it has now started to "turn on" whenever the door is opened. Now, when you open the door the light...
HI:
You have a faulty door switch, the unit is not supposed to come on when the door is opened only the light.This unit may require servicing as the control board may also be at fault.
Dec 24, 2010 | Panasonic NN-S753 Microwave Oven
Microwave seems to run, but won't heat.
We have a similar problem! It sounds like a problem with the microswitch inside the unit that the door is suppose to engage when closed. If not engaged properly, it will not cook. We had the switch replaced last March but it has started acting up again. We can press in on the door and/or lift it slightly and it will cook. Try putting time on the counter and hit start. It the word "cook" appears then try moving the door slightly and see if the turntable starts turning. If not, then you may have a more serious problem. Good luck!
Oct 09, 2009 | Frigidaire FMV156DC Microwave Oven
Hinari microwave doesn't cook
hello mam
i am having the solution for this problem check the lock terminals for loose connection and if its working and check the magnetron which produses the heat inside the microwave.
Sep 25, 2009 | Microwave Ovens
Egg cookers
I found the instructions
Sprinkle a few grains of salt on bottom of egg cooker. (Salt attracts microwaves and is necessary to help cook bottom of egg)
Break egg into egg cooker.
One egg in micro at a time.
Will fork piece yolk and white to bottom of cooker, three times. _ This is very important.
Line up notches on egg cooker lid and cup then twist until locked
Micro on High for 30 seconds
Let stand 10 seconds
If bottom of egg is not cooked turn egg over with a spoon and microwave on high for another 10 to 20 second or until cooked.
Dec 16, 2008 | Microwave Ovens
Microwave not turning on after egg explosion
repair door target wont accept return or repair under warranty due to damage by owner
Jun 16, 2017 | Danby DMW1153 Microwave Oven
Microwave works for 30 seconds and then turns off
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 23, 2008 | Microwave Ovens
Sharp R-408J Microwave Oven Logo
407 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Ekse
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
