Question about Teac AG-680 Receiver
My teac ag-680 fuse keep blowing everytime i replace it and plug the reciever up
Turn the volume up receiver popped off took the cover off to find that the 250v 6.3amp fuse was blowed replaced it with the same fuse plugged the reciver up did not touch nothing fuse blow again repeated the process three times same result so i just want to no what esle could it be
    Problem Solver:
  • 13 Answers
Are short in the audio output transistors may have been short since a channel 2 or maybe 4, also open resistance check carefully and change them after you put a 75w bulb in series 100w or where is the fuse clearly, you have to remove the fuse when you put the focus if all is well will turn on only a small incandescent and amplifier work well you put audio speakers and there will, if everything is well put the fuse back and ready.
Posted on Sep 07, 2013
4 Suggested Answers
Orbixx
  • 133 Answers
SOURCE: teac ag-d9320 5.1 receiver fuse
Make sure the fuse you put in matches the power requirement of the device you're installing the fuse into, putting a fuse that does not handle the current will cause this, but do not overshoot as this may fry your device - it must match. If you know it's matched, then the device you're installing the fuse into may be faulty in such a way that it is drawing the wrong amount of power. This can be due to the power supply on the unit.
Posted on Sep 07, 2007
  • 39 Answers
SOURCE: keeps blowing fuse.
Dissconnect ALL speakers from back of unit then try to turn on.
If it works you have a speaker short.
If not, you have a more serious problem.
DO NOT replace the fuse with anything else but what was specified, as it can cause a fire!
Posted on Jun 14, 2009
  • 7 Answers
SOURCE: fuse blows everytime i turn it on
the blue coloured varacter in your power supply circuit needs to be changed
Posted on Jul 12, 2009
One of the 2 fuse inside keep blowing
When a fuse trips, there is something wrong. Unless you find the component that causes this (or the shortage) you won't be able to use the receiver again.
To diagnose this I need to hook up the device to some gear, so I can't give a correct diagnose over the net. Sorry.
Jan 27, 2015 | Teac AG-680 Receiver
What size fuse go in a teac ag-680 receiver
IT SHOULD SAY ON THE MOTHER BOARD WHERE THE FUSE IS
Jan 14, 2013 | Teac AG-680 Receiver
Need User's manual for Teac AG-680 Receiver
http://www.commentcamarche.net/notices/teac-ag-790a-4760/
http://www.manualnguide.com/dl/17908/
Jul 05, 2011 | Teac AG-680 Receiver
Teac ag-d9100 center and surround speakers are not working , very very low volume.. the others all work fine. Anybody know where to start troubleshooting. Its not a fuse that I can see , at least that i...
You have to enable them and turn the volume on them up separately with the speaker config, level trim, and up/down select buttons on the remote. You can also adjust the rear speaker delay time or just hit the test tone button and adjust the volume on each speaker separately as it goes through them one at a time...
Jun 01, 2010 | Teac AG-D9100 Receiver
Keeps blowing fuse.
Jun 14, 2009 | Teac AG-V8600
Fuse blows everytime i turn it on
Mar 30, 2009 | Teac AG-V3050 Receiver
I have a teac AG D8900 Digital Home Theater. My subwoofer seems to be dead. No lights come on the front of Sub Woofer even though it's plugged in. I tried changing outlets. The wire from speaker to...
I have the same-just talked to TEAC last week, if fuses(two 5 amp glass ones inside housing-just remove screws on back after un-plugging 120v power) on the LSR-1008 subwoofer are blown, it may be failed relays. I replaced my fuses, both blew w/in 5 seconds. Called TEAC today, relays are NOT available alone and are solder connected; however, complete new circuit board is plug in, part #APE000515-0001 at $47.69 plus shipping. Verify #s and price with TEAC, but now I must decide if it's important to keep this sub, or if another at around 60$ on Ebay is a better bet. Good luck!
Dec 26, 2008 | Teac AG-D8900 Receiver
AG-790 teac
Same problem here. My first receiver was doing this, sent it back, and the second did it again. So I remembered an article regarding remotes and florecent lights. I covered up the remote sensor on the face of the receiver and so far no problem. A piece of tape about 1" square was used and so far no problems. jeffspeakers@aol.com
Sep 04, 2008 | Teac AG-790 Receiver
Lost manuel for teac ag d9100 reciever
you can download a manual for $9.99 from User-Manuals.com....I did this today and the manual is identical to the original it seems
Jul 11, 2008 | Teac AG-D9100 Receiver
Teac AG-680 Receiver Logo
121 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
