Set goes turns on and off randomly
The set started turning itsself on and off randomly for about a month. I plugged into a different power strip that seemed to help. Now the TV just shut down and does nothing. No click when you try to power-up via remote or on-off button on TV
  • john Pgh Jan 23, 2009
    This is a Sony KV-27-FS100 Chassie BA5D
  • john Pgh Jan 30, 2009
    Thanks for the response, I did further research and determined that the power stip used to connect to the TV was faulty and had a short. Much cheaper than having the TV repaired
    Problem Solver:
  • 10 Answers
Use the remote to go through the menus, there are many TVs’ that have a remote on function that will turn on the device with a power up. So, if you have any power interruption no matter how short, the device will turn on. Go through the menus and turn this function off.
Posted on Jan 30, 2009
When I turn on my Sony TV, ti stays on about 30 seconds then shuts off, What do you think is wrong?
Do a Power Reset.
1. Turn off TV.
2. Unplug the power cord of the TV from the electrical outlet.
3. Let the TV remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.)
5. Turn on the TV.
If issue persists after doing the steps, reset the TV to factory default settings.
1. Turn on the TV.
2. Using the supplied remote, press and hold the UP arrow button.
3. While holding the UP arrow button press the POWER button on the TV itself.
4. When the TV goes off, release the POWER and UP arrow button.
5. The TV will turn on by itself and the initial setup screen will be displayed. Just follow the on-screen prompts to finish the setup.
Sony KDL 46V5100 random shut off 15 20 sec
Feb 25, 2016 | Sony Televison & Video
My LG 42LV4400 has a red light in the bottom left corner but it will not turn on.
2 month and already quit? OK: first thing to do is to unplug TV off the power strip or wall outlet. Wait for a few minutes and plug the set back into the power source. Try to turn on the set manually, by touching sensors or buttons on control panel. some TVs have push buttons, some touch sensors. If your TV was set to "auto power on" mode, then don't touch anything after plugging set in. That's the only action you can do to "revive" the set. If you will be able to turn set on manually and "free standing" without any external connections, except power cord, check your remote control unit. 95% of consumers turn on their sets via "clickers". In case of complete failure, you might have month or 10 month left of factory warranty, depend on price you paid. Use it a.s.a.p! If needed. There is no magic button to heal broken circuitry.
Good luck,
Feb 19, 2012 | LG 42LC2D 42 in. LCD HDTV
9 months ago our Mitsub WS-65611 starting turning
The part number you indicate is the STK-393-110 convergence IC that this set uses--it is possible it is bad again--if properly installed it should not have failed for at least 5 years.
When the set shuts off, on the front of the set engage the self check feature this set has: when the power light goes off ON THE FRONT OF THE TV press both the MENU and INPUT buttons at the same time and hold them for at least 5 seconds and then release both buttons.
The power light should blink a two digit error code: for example--2 blinks, a pause and 2 blinks--this is the most common and it will repeat the code several times.
Let me know what you find---I am here to help people.
If this information helps you, rate this solution as I do this here for FREE.
Nov 16, 2009 | Televison & Video
My computer will not turn on. My niece turned off my power strip and now my pc will not boot back up.
try putting the computer plug in a different wall plug sounds like you have a worn out plug causeing your problem.
Oct 05, 2009 | E-Machines eMachines Desktop PC
Dell 3100MP just powers off
check the heating of your laptop. it more heat chek your fan or cfu fan, if work properly.. shuting down is a lot of cause. over heating, fan not work properly case over heating... processor.. or board..
Jun 19, 2009 | Dell 3100MP Multimedia Projector
Power Outage
The power supply, or one of the scan amplifiers has some damage. The set will require shop service.
More than likely the set was going to fail anyways... Turning off the power source to a TV should not do any kind of damage.
Jerry G.
Apr 29, 2008 | Toshiba 27A44 27" TV
my tv starts turning a red color and then turns off by itsself then i have to unplug it to turn it back on every 5 mintues or so.
Nov 14, 2007 | Toshiba 46H84 46" Rear Projection...
Cannot load vhs tape
Try turning off hte power at the socket, often the machine will re set itsself when you plug the power back in.
Nov 11, 2007 | GoVideo Go Video DVD/VCR Combo
Televison & Video Logo
73 people viewed this question
Top Televison & Video Experts
