Question about JVC Cybercam GR-DVP7 Mini DV Digital Camcorder
Cleaning the camera
I am trying to clean my camera (cause it shows black lines across the screen when I record or play a tape). I bought a cleaner specified for my type of camera and it won't accept the tape.It says "Unit in safegaurd mode. Eject and reinsert tape." What do I do?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 60 Answers
Hi, just insert a brand new dv tape and let it record for 10 min.. rewind back to 5 min and start playing and do a repeated ff and rw you can see the black lines slowly going off.. all the best my friend sreejith
Posted on Jul 12, 2007
I have a Canon ZR90A and started noticing horizontal gray lines displaying across the screen when it plays back. What is causing this?
The most common cause of horizontal lines during playback is dirty heads/tape path. If you have a head cleaner tape, try playing it for about 5 to 10 seconds and then try your tape again. Repeat as necessary. Try not to run the head cleaner for long periods of time because you may wear down your heads quicker (cleaning cassette is somewhat abrasive). If you do not own a head cleaning tape, I highly recommend purchasing one. Sony (in my opinion) makes the best miniDV head cleaning cassette. We use this brand in our repair shop and they last for years. I have posted a link to the particular tape I am speaking of. Your local camera/camcorder shop may have these for sale.
http://www.amazon.com/Sony-DVM12CLD-MiniDV-Cleaning-Cassette/dp/B0000632H7
Hope this helps you.
www.austintelstarservices.com
Sep 12, 2010 | Canon Video Cameras
Grey lines
I have had this problem myself, and it is nothing more than a head cleaning issue, from my experience. Sometimes, when a head cleaner will not work, the camera requires proper maintenance. The problem arises through long pauses, and over time. A suggestion for better use perhaps, would be to not pause tape for too long when playing back. Based on personal experiences.
Jul 04, 2009 | Sony Handycam DCR-HC30E Mini DV Digital...
Lines across screen on playback.
A Q-tip should never be used to clean a video head.  Unfortunately they can pull the tiny head out of alignment.  I believe this is your problem and the repaid may be more costly than a new purchase.
Nov 25, 2008 | Panasonic Palmcorder PV-DV351 Mini DV...
Lines on my JVC mini dv recorder
Please use Mini DV Video head cleaning cassette as it seems video head is dirty / clogged in camera.
Oct 24, 2008 | JVC GR-D295U Mini DV Digital Camcorder
I have a Panasonic NV-GS75 and have recorded on it. On trying to play back it has black lines across the view and is stilted. What do I do to rectify this?
You would need to use the head cleaning tape which came with the camcorder to fix this. The heads are dirty however if they were dirty during recording, try playing back another recording and if it works, the tape might be dirty. i wouldn't recommend using that tape.
Aug 28, 2008 | Panasonic Cameras
Help With My Digital Video Camera!
You try it with proper connection using a new or working wire if you have used a vcr to play back.
Play the tape with any other camera.Bcoz your monitor may be fault.
Play the head cleaning tape in the camera, and try
May be the recording head of your camera is clogged
Mar 29, 2008 | Photography
Display shows a set of black bars
tape guides are out of adjustment, need to have brought in for service.
Jan 29, 2008 | JVC GR-D270 Mini DV Digital Camcorder
Canon camocorder thick gray lines on ever recording
Supreemwun,
Canon support was of no help. They ****! To fix the problem this is what I figured out.
  1. Before you start filming what you want record or just advance the tape 10 secs or so.
  2. Record/ video whatever you planned.
  3. Now when the thick grey lines come up on play back don't freak out.
  4. Simply rewind the tape to the beginning and record briefly in the blank portion at the beginning (careful not to tape too long as to tape over your intended recording).
  5. Rewind and play the thick grey lines should now be gone.
How did I figure this out just a fluke. No cleaning, no spray pretty simple. At first did not understand it but it works EVERYTIME for me. I'll deal with it until I get around to buying a new HD video camera and it won't be a Canon. Hope this helps.
Jan 13, 2008 | Canon ZR100 Mini DV Digital Camcorder
On playback, the video has gray lines across it
Someone here recommended on another post to put the lense cap on & videotape the blackness in a quiet room for 5-10 mins. I tried this as a last resort & it worked. When I played back the tape, no more skipping or gray lines. I had 4-5 SOLID gray lines with skipping video & audio in between on every tape I put in. The person who helped me solve this said: "the speed isn't linked with the last time you recorded on it. Frames have an A/B part to them. If A is hitting B instead of A, a line appears. I would try the head cleaner first, then blacken your used tape (keep lens cap on and record in a quiet room) and try that."
My camera is a Canon zr80 digital camcorder. (Called Canon, they had me reset it & then recommended sending it in).
Dec 28, 2007 | Sony Handycam DCR-HC21 Mini DV Digital...
Will not record or play back.
the head may be dirty, try cleaning the head with a cleaner tape and try recording again.
Oct 23, 2007 | Sony Handycam DCR-TRV340 Digital Camcorder
JVC Cybercam GR-DVP7 Mini DV Digital Camcorder Logo
138 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
