Question about Sony BRAVIA KDL-40S2010 40 in. LCD Television
Turn the tv off. atfer 5mites or so start to hear cracking noises. is this a problem?
  • brianbuy May 11, 2010
    these tv's tend to get warm and plastic expands. i think what you are hearing is the cabinet contracting as it cools.
  • 126 Answers
Spot on. The ABS on the plastic determines the strength of it. A low rating will undoubtely mean a crack when cooling down.
Posted on Jan 31, 2009
    Sergeant:
    Champion:
  • 267 Answers
BRIAN IS CORRECT. NO IT IS NOT COMPONENTS. YOUR OK.
Posted on Jan 30, 2009
    Problem Solver:
  • 10 Answers
I agree with Brian that it possibly could be the plastic cabinet contracting. On the other hand not hearing the sound you describe, it might also be normal energy discharge of elecronic components upon powering down.
Cracking noise of Lexicon MC12HD
replace your hdmi cable between tv and preamp...lemme know if it works.
Feb 17, 2014 | Lexicon Audio Players & Recorders
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
Vizio GV47L not turning on after a pop noise
check your power board, most likely that's the part that is causing the problem.
Feb 09, 2009 | Vizio GV47LF Television
Tv turns it self off after only 2-3 seconds and makes crack noise
Since the set is less than 1 year old, it should still be under warranty. Request warranty service.
The noise you are hearing is probably arcing inside the set on the power supply board. Continuing to attempt to turn on the set will only make things worse. Please request warranty service as this is unusual for a TV that new.
Dan
Jan 16, 2009 | LG 50PB4D 50 in. Plasma HDTV
My TV is making cracking noise
Its the plastic cassing making the noise. If you press the tv together along the edges you will here a crack. Samsung and others did not use 99 cent padding between the plastic and the metal you need cushion padding. Its like not using a gasket or seal. Its a simple fix but the tv companies say its expansion.
Oct 30, 2008 | RCA 14F512T 14" TV
Rear screen tv
replaced flyback transformer
Sep 17, 2008 | RCA F36650 36" TV
Won't Power Up
pretty sure your bulb has blown
Dec 27, 2007 | Toshiba 44NHM84 44" TV
Cracking and poping with Yamaha surround sound system
Das TV make cracking and poping noise when you unhook it from receiver?
Sep 30, 2007 | Sony STR-DE197 Receiver
TV screen went black, sound OK
check cold solder vertical circuit
Nov 21, 2006 | JVC AV-27530 27" TV
Sony BRAVIA KDL-40S2010 40 in. LCD Television Logo
51 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
