Question about Pitco Frialator SG14 Deep Fryer
How to fix open probe warning on fryer - Pitco Frialator SG14 Deep Fryer
Why does my fryer says shorted probe
You need to replace the thermostat probe. That probe controls your heat and prevents it from over heating or not heating so if its out it has no way of being able to do so so it stays off. I couldn't find part but call manufacturer and provide serial number and they will get you everything you need and even help with any small questions.
Aug 26, 2014 | Vulcan Hart 2GR45DF LP - 45-50-lb Fryer w/...
Probe is open? Message on screen
It means that the temp probe has no resistance and should be replaced.
Oct 13, 2013 | Kitchen Appliances - Others
Sg14 deep fryer turns on with a loud continous beep and led says "PROB"
Hi there.
The computer board of your fryer does not recognize a Temperature Probe connection.Try to check Temperature probe wiring if properly fitted on connector.
Regards.
Aug 20, 2011 | Pitco Frialator SG14 Deep Fryer
"PROB" shows when fryer is
Computerboard will display "PROB" error when it could not sense resistance reading from the temperature probe sensor (temperature probe sensor is either open circuit or short circuited). Check first the temperature probe connectors, tighten loosely fitted connectors on wiring harness and computer board, then check if the wires are not damaged. Disconnect the temperature probe and check the resistance using an ohm meter. If the reading is either zero or infinite, you have to replace the temp probe.
Dec 18, 2010 | Pitco Frialator SG14 Deep Fryer
Break away power cord 3 liter stainless steel deep fryer`
Keep the connections clean where the plug meets the probes. You may have to prop up the plug so that it won't fall off or disconnect. Unfortunately, this is a poorly designed model and should have never gotten a UL label.
Jan 25, 2009 | Bravetti Kitchen Appliances - Others
Prob code
THIS SOUNDS LIKE A THERMASTAT PROBLEM!
Dec 08, 2008 | Frymaster Dean EH1721 Deep Fryer
Probe failer
Probe ,indicates that the board is having issue interpreting the signals coming from the probe. I recommend you have a qualified professional evaulate the the unit for the best results.
Nov 28, 2008 | Frymaster Dean 2424G Deep Fryer
The fryer was working normal. Then the temperature light went out and the fyer is not coming on whe I flip the off an on switch
The first thing you need to check for is a high temperature limit cutout switch. It will be located near the gas valve but on the right side it wil have a cover that will snap open. it is about the size of 4" X 1 1/2". Once you get it open puch the button in you shoul dhere a click. When you hear the click you are reset. Once you turn the fryer back on use a temp probe or a type K thermocouple w/ a meter to check temp. if it starts over riding temp shut the unit off and replace the t-stat and the t/l cutout switch.
Thanks
Jul 20, 2008 | Garland AF-5025 Deep Fryer
Error message
I have the same problem. It is caused by the thermister thermal probe going bad (open circuit). Delonghi wont sell you the probe which probably costa about $2, they want to sell you a new control panel for $93. You can replace it with another thermister and it works but it will probably be out of calibration.
Jul 19, 2008 | DeLonghi D14527DZ Dual Zone Deep Fryer
Looking for a thermostat unit for the Imperial IFS-40 serie : 05159306 what's the part number??
If you have a manual thermostat,(inside door, knob) your part is
#1175 OPERATING THERMOSTAT (HERMETICALLY SEALED REED SWITCH)
If you need the Hi-limit t-stat --
#1177 HI-LIMIT SWITCH
If you have digital control, with digital temperature control, the unit uses a probe.
#1094 FRYER CONTROLLER TEMPERATURE PROBE
Good luck, Mike
Jun 06, 2008 | Imperial IFS40 Deep Fryer
Pitco Frialator SG14 Deep Fryer Logo
157 people viewed this question
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Treefrog15
Treefrog15
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
