Question about LG DLE2512W Electric Dryer
Replaced dryer drum. too tight to turn
Is there a lubricant for the felt edges?
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: When drum spins it makes
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Posted on Sep 12, 2010
Frigidaire affinity front load dryer
You need an upper felt and a rear drum bearing. If you buy the felt make sure you get the special adhesive to install it. The squeal maybe part of this or it could be the rear drum bearing. You can learn how to replace the rear drum bearing here in the article I wrote. http://gomestic.com/do-it-yourself/how-to-replace-a-frigidaire-dryer-rear-drum-bearing/
Jan 29, 2014 | Dryers
Hi, I have a Beko DRCT70W tumble dryer and the belt keeps breaking. I've replaced it twice in the last month, so I think there must be another fault with the dryer which is causing this. The drum...
hi folks the beko tumble dryers have a felt seal that runs along the front of the drum that wears through causing load on the drum, belt and motor causing the belt to melt and snap, replace the felt you will have no more issues, i got mine off of ebay pretty cheap
Feb 08, 2011 | Dryers
Clothes get tuck on the front edge and discolors
it most probably needs to have the felt cushion on the front of the drum replaced.
Jul 09, 2010 | Kenmore 83042 Electric Dryer
Clothes getting stuck in front of dryer the model wasn't listed below mode is LDE8404ACE
If your clothes are getting stuck in the front of the dryer, it could mean more than one thing.
Your front felt seal is faulty, broken, or out of position.
After years of use, the front felt seal on the dryers break down,come loose, or become faulty. It is also sometimes caused by wear in the drum rollers, and this causes the felt seal to become worn.
You will need to replace the front felt seal and possibly the drum rollers.
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum, felt seal and belt. It is a good time to check and replace the felt seal. You could stop there but I recommend that you do the following:
Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots, if they are worn or have flat spots on them replace them.
If the drum rollers don't have flat spots on them and is not worn, then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Nov 14, 2009 | Maytag PYE2300AY Electric Dryer
My dryer makes a scraping noise when the bowl
You may have two problems:
1...The felt seal around the door is faulty,broken, or out of place.This will cause the problem of zippers,buttons, etc. to get caught between the door and the drum
2...Drum rollers, this causes squeaks,and thump type of noises.
Your problem sounds like drum rollers have flat spots on them or in need of lubrication and the felt seal between the door and drum maybe faulty.
Remove the electrical box that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt,and felt seal.
Check your felt seal at this time to see if you can reinstall it or you may have to replace it.
Remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise and the problem of getting clothes caught in between the door and drum.
Good Luck,
I hope this helps
Oct 29, 2009 | Frigidaire Dryers
Replaced felt seal.now dryer drum rolls with a bump
Check the placement of your new felt seal to make sure nothing has shifted or has gotten out of place, if it is ok then your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine, Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
If they don't then they probably only need lubrication. Lubricate the shaft of the roller with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve you noise problem.
Good Luck,
I hope this helps
Oct 14, 2009 | GE DVLR223 Dryers
We purchased part 280114 (rear drum seal) and we
Hi, If this a whirlpool make, The felt side gets the glue. The edge that is sown tight on the edge gets glued to the tub. Make sure that you do not push the seal to far unto the drum so the flap on the seal hangs against the edge of the drum.
If you look at the back side of this seal you will notice a threading closer to one side and not the other. The thread (felt side) closest to the edge is the one that gets glued to the drum.
Please let me know if this helps you or if I can assist you further.
Vic
Jul 17, 2009 | Dryers
Frigidaire electric dryer catches clothes at the edge of the drum
If the clothes catch on the drum edge the felt seal is worn out , and the squeak could be the bearing the drum rest on or the belt tentioner , it may need oiled , you can buy the felt seal replacement kits online and they are not hard to install.
Hope this helps.
Phil
Apr 10, 2009 | Frigidaire FDE436RE Dryer
Clothes are getting caught on edges of drum
you need to replace the felt on the dryer
Dec 19, 2008 | Dryers
Kenmore dryer drum felt
if i remember seam closest to edge goes toward center of drum ..should have been instructions in bag
Aug 01, 2008 | Dryers
LG DLE2512W Electric Dryer Logo
47 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
