Question about Haier HWR06XC5 Wall/Window Air Conditioner
Ac ices over
I have a haier thru window ac unit and it has recently started to freeze over behind the filter.
    Novelist:
  • 159 Answers
First you need to make sure the filter is clean to allow good air flow through the evaporator. If the filter is clean make sure the evaporator is not plugged up with dust and lint. If all that is ok your problem is the a/c BTU's is to big for the size room you have the a/c in and it is getting the room too cold. If that happens the evaporator will ice up and will not cool the room.
Posted on Jul 12, 2007
SOURCE:
Freezing up inside my a/c unit
Often that is a sign it is low on refrigerant. It can also be due to low air flow due to either a dirty filter or dirt obstructing the fins (coils) behind the filter.
Jul 23, 2012 | Haier 5,000-BTU Mechanical Window Air...
My unit wasnt working right so i took the front cover off and it is covered in ice.
Two things generally cause this problem. High outside humidity and a clogged air in take filter. Allow the unit to thaw completely, remove the air intake filter and clean it. Allow the filter to completely dry, before reinstalling. Never operate the AC unit without the filter in place.In addition. the unit may not have enough downward tilt at the rear. Generally 1/4" to 1/2" is required. so water will flow to the rear of the unit to the drain hole.
Hope this helps and thanks for choosing FixYa.
Jul 29, 2011 | Haier HWR08XC1 Thru-Wall/Window Air...
My window ac unit keeps cycling off, before it gets to the assigned temperature. Help
What may be at issue is evaporator icing. Some units cycle the compressor, others control the refrigerant to keep the evaporator temp just above freezing. If allowed to continue the evaporator would freeze over and air flow would stop....
Check and see if that is the case...
Jul 20, 2011 | Haier HWR06XC6 Wall/Window Air Conditioner
My haier a/c window unit is spitting water through the vent
Thermal transfer-the unit is creating condensation.
Jun 03, 2009 | Haier Heating & Cooling
check the filter located behind the front panel it usually snaps out also make sure the drain holes on the out side bottom of unit are not stopped up and that the unit is leaned back slightly for drainage freezing is a sign of low air flow or low on freon the coil actually gets colder when freon starts to leak out hope this helps with your problem
May 15, 2009 | Haier hwr10xc6 Air Conditioner
Wall ac unit keeps freezing up inside.
Do not run it on maximum cool and fan on low. Freezes up all the time this way.
May 01, 2009 | Heating & Cooling
Fidgerdare electrtolux air conditioner
have you brought it down for a general cleaning on the 3 year period? if not then that's what it needs now.
the coil is freezing up because of dirt accumulation on the coil. even there is a filter, still with in 3 years it could have accumulated to decrease the airflow thru the coil and freeze it up.
tnx 4 using fixya,
drcool
Sep 07, 2008 | Frigidaire FAC124 wall/Window Air...
Haier ESA 3185 AC won't cool; makes escalating loud vibrating noise near front panel/ filter
Have someone check the run capacitor of this unit. If the run capacitor is bad over shorted it can cause the unit to run and short cycle on a current overdraw. This makes for an electrical imbalance in the compressor motor. Next step is the compressor is faulty.
May 16, 2008 | Haier ESA3245 Thru-Wall/Window Air...
Haier HWR06XC5 Wall/Window Air Conditioner Logo
272 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Dan Apthorp
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
