Question about Garden
I ran my husquavarna for 10 minutes on plain gas.It wont start.Is it permanently damaged.
    President:
  • 2,692 Answers
Check the compression . A quick check is to ground the spark plug lead , then put you finger tightly on the sparkplug hole while pulling the rope. If it pushes your finger off of the hole and you cannot stop if from doing so, it is ok. If it doen't then you wil have to replace the rings and maybe hone the cylinder walls. dependant upon the wear(damage).
Posted on Jan 24, 2009
What is the spark plug gap setting on a husquavarna chainsaw
Have you looked in the gas tank for a broken gas line? They become brittle and break. Very common.
Mar 09, 2013 | Husqvarna Garden
Husqvarna lawn tractor drive belt slips after mowing for 10 minuits then i have to wait for about 5 minuits then it runs
The drive belt needs to be replaced, the old one is worn to the point that it will eventually snap.
Jun 16, 2012 | Toshiba Satellite C655-S5086 Notebook PC
I ran out of gas and i put gas in it and now it wont start i thought it might have froze but i have it in garage with heater now it starts but i have 2 pedal it 2 keep it running then it dies and wont...
If it ran out of gas, there are two possible easy fixes. One is that the fuel filter is plugged up by junk from the bottom of the tank. The other is that water floats on top of gas and now your lines are a mix of fuel and water. I would change the filter and put water remover in the tank. Make sure there is a least 10 gallons of fresh fuel in the truck. If neither of these work, the pump may have been damaged as it uses the fuel to keep it cool.
Feb 23, 2011 | 2001 Ford Explorer Sport Trac
1994 cutlass supreme I ran out of gas. After i put gas in it it
if you let car run out of gas.it over heat fuel pump some times it damages it.it wont start again.
Jul 23, 2009 | 1994 Oldsmobile Cutlass Supreme
2000 Alero ran out of gas and now wont start
you might have a clogged fuel filter when you run a car out of gas it sucks all the junk out of the bottom of the talk and the filter will catch all of that
Jul 15, 2009 | 2001 Oldsmobile Alero
Car wont start
It is very bad to let your car run out of gas. You may need to give it exessive amount of gas when starting it.
Apr 23, 2009 | 1996 Oldsmobile LSS
Husqvarna 65021 RS lawn mower, > 1 year old will not start
yea i think you scratched the cylinder. if there is not oil at any point then the engine will damage itself. and it wont have good compression. unless you want to attempt to rebuild the engine i would scrap it.
Apr 09, 2009 | Garden
My campbell and housfield 60 gal wont run.. help
10 AMP CIRCUIT SOUNDS WEAK. WIRE MAY BE TOO SMALL. ARE YOU SURE ITS NOT WIRED FOR 220 VOLTS AND YOUR RUNNING IT ON 110. START CAPACITOR COULD BE BAD BUT TYPICALLY WOULD LEAK OIL-LIKE FLUID IF IT WAS DAMAGED. CUTTING OFF AND ON CONTINOUSLY COULD BE THE PRESSURE SWITCH IS DAMAGED. SOUNDS MORE LIKE WRONG VOLTAGE. THERE ISNT A LOW OIL PROTECTION DEVICE.?
Feb 04, 2009 | Campbell Hausfeld 26 - Gallon Air...
Garden Logo
93 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
