Question about Craftsman Garden
I need a piston stop for a craftsman finish nailer part number4573.00 sears states they are not being made anymore do other nail guns use the same part
2 Suggested Answers
SOURCE: i need a piston stop
same thing here, I believe it was made by porta cable looked at their nailer, looks the same trying to get that part should be around $14 plus shipping
Posted on Oct 19, 2010
I am not familiar with nail guns but if there is a place to put a piston stop, can you use a piece of rope instead? I have used rope to stop the piston on chainsaws I have fixed where my piston stop tools wouldn't work
Jan 14, 2013 | Craftsman Garden
My bostich1664FN was working fine,then it stopped shooting nails.How can I troubleshoot this problem. Thanks John
Here are some easy tests.
Assuming that the gun is firing normally however no nails are ejected. Remove the head of the gun and check if the piston is not returning to top of cylinder (piston needs to return to top for nail to enter into positon under the driver). Piston not returning to top indicates, bent driver or worn oring on piston. Repair /replace as needed. If driver/oring looks good, pull out the cylinder and look for check band in place around series of holes on lower part of cylinder and bumper should not be cracked. Lube all orings with silicone paste lube. Good luck
Sep 06, 2011 | Stanley Bostitch SB1664FN 16 Gauge...
Craftsman evolv braid nailer leaks air around the trigger when i try to nail. it does not nail sears no. 00915206000 mfg no. 42081 (for kit) on gun model:6G28/F50
Air leaking from trigger when trying to nail indicates that the headvalve is stuck or headvalve orings are dry and allowing air to pass. Remove the head and pull out the headvalve piston. Examine orings for cuts or broken (replace as needed if orings worn and cannot make seal). If headvalve was stuck/dry, lube with plenty of silicone paste lube (sold at Lowes in the plumbing dept. ). Should be good to go. Good luck
Jun 30, 2011 | Craftsman 184060184070184080 Brad Nailer...
I have a craftsman 16 gauge finish nailer, model 918441. it is not advancing the nails. not certain how to adjust. cannot find the manual. is the manual available on line?
Assuming that the nails are correct for gun (16g nails measure .055) and feeder is actually applying pressure to nails (feel spring pressure as you close clip), most likely problem is driver is not returning to top of cylinder. This is caused by low pressure to gun, bent driver, lower bumper missing pieces/cracked, worn oring on piston or lack of lubrication. Remove cylinder and examine condition of lower bumper, replace if broken/cracked; check outer cylinder for check valve in place (usually small band or oring covering series of ventholes) ; replace piston oring as needed, make sure driver not bent. Parts available at sears web site. Good luck
Sep 08, 2010 | Craftsman Tools & Hardware - Others
I need a piston stop part#4357.00 craftsman 16 gauge finish nailer model # 351.183210, im told by sears part is not available, any other finish nailer with the same part?
Jul 29, 2010 | Craftsman Garden
Paslode nail guns won't shoot
piston is probably jammed
This happens sometimes try holding it up against a board with the trigger depressed and then inset the battery.
The goal is to try to force the firing sequence to get the piston back to the right position with corded units this is simply done by attaching the air hose with the trigger pulled this causes air to rush into the gun chamber pushing the piston back and firing a nail out.
The cause of this is a misfire or jammed nail that stopped the piston in the wrong location so air will not build in the chamber correctly.
Hope that helps
Feb 18, 2010 | RTO Paslode 902000 IM250 Ii Cordless 16...
My Sears Craftsman 18 gauge brad nailer won't nail unless I release the nails from supply, remove the front cover, slide up I think it's called a striker, then replace the cover, re-set the supply and...
Your driver is not returning. Depending on the model that you have there could be a couple of problems. The most likely is that your piston stop is crumbled and some of your seals are worn or damaged. Whether or not you can fix the nailer depends on if the parts are available from Sears Parts Dept. If you would like some more information about fixing your nailer please post which model it is that you are trying to fix and I can see if the parts are available. I will post the information back to you.
Oct 12, 2009 | Tools & Hardware - Others
Need to identify my Craftsman rooding coil nailer.
chrck the devilbiss or porter cable web sites your answer probly lies there.hope this helps
Jul 16, 2009 | Air Tools & Compressors
Mastercraft Brad nailer piston always fires damaging finish but nail gets randomly shot. Thought it was a indent before nail shot to indent nail since it mostley shoots nails after second shot but lately...
The dial on the top of the gun is most likely the depth adjustment for the nails, this should solve the driver damaging the work piece. Make sure the nails are the correct guage for the nailer you have.
Apr 13, 2009 | Tools & Hardware - Others
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
