Question about SanDisk Sansa e200 MP3 Player
Need a replacement LCD screen
My Sansa fell :-( and now it's showing in what looks like a 16 colour resolution. i need a replacement screen .. help please
    Problem Solver:
  • 4 Answers
Well, It looks like either you'll have to live with the screen, or contact Sansa's support and they will replace the entire thing. They are usually helpful about it. There's nothing really that you can do yourself though, sorry.
Posted on Jul 09, 2007
Uninstalation of monitor driver HP2509 stopped monitor to display.shows blank screen in vista desktop
The monitor driver only tells the video card which video resolutions are supported by the monitor. The video card is probably set to the wrong resolution. You can boot into safe mode, set the screen resolution to one the monitor supports, and you should be good to go. You don't actually "need" a monitor driver.
Mar 29, 2013 | HP 2509M 25 Widescreen LCD Monitor -...
Toshiba Satellite displays a 16-bit color resolution after I replaced the video cable, what is causing this?
Click Start/Control Panel and look for Display or Appearance and Personalization. Open the Display, then click the Settings Tab. You can change the color from 16 Bit and you can adjust the resolution.
You can also get to the display by clicking on a blank area on the desktop and select Properties.
Apr 29, 2012 | Computers & Internet
Bad resolution, colour and picture quality even on menu
tcon board or lcd screen defective.try to replace tcon board first on back of the lcd sscreen
Nov 16, 2011 | Sony BRAVIA KDL-40V3000 Television
Cannot get full screen picture
Full screen resolution depends on the source signal that you feed to your LCD TV. Most often, the signal come in 16:9 screen size, which sometimes show big black portion on both top and bottom of screen. To maximizes screen display, you can adjust the screen size of your LCD TV through remote control, this features are available in most LCD TV. you will have the option to choose Full Screen Mode, 16:9 screen resolution or many others to choose from (most case about 3 to 4 screen size.
Jul 03, 2011 | Dynex DX-L32-10A 32" LCD HDTV
I've got a dell computer and i'm trying to swap the crt screen to a packard bell lcd screen and it wont display is there a driver i have to get or are they just not compatable
It probably a mismatch between resolution, colour depth and refresh rates. Before you disconnect the CRT change the resolution to 640x480 and 16 colours with a 60Hz refresh. Then connect the LCD and adjust the settings
Aug 29, 2009 | Dell Dimension 4600 PC Desktop
LCD monitor have Vertical lines and black colour become greenish
normally the 19" resolution can support up to 1280*1024, but if it comes with vertical lines in full screen, it might indicate the panel is no longer to work and probably it's time to replace new one.
Aug 12, 2009 | Neovo S 19 19 in. Flat Panel LCD Monitor
Black colour displaying become greenish and narrow vertical lines
Most LCD monitors have a default refresh rate of 60 Hz. Older monitors also have limited resolution. Please check your display settings and ensure you're not using a refresh rate higher than 60, or a resolution higher than what it supports. If either one is the case, you're lucky the LCD still works.
Aug 12, 2009 | Computers & Internet
My screen has gone massive and the colours have gone negative. help me?.................. x
That sounds like your video card has gone back into VGA mode, 16 colours and a screen resolution of 640 x 480.
Go into the display settings and try setting the resolution to something like 1024 x 768 and the colour to 32 bit (16 million colours).
If the adjustment cannot be made, it is likely you have a graphics card driver issue. Find out what graphics card or chip you have and download a new driver from the manufacturers website.
Hope this helps.
Andy
Jun 26, 2008 | Computers & Internet
Resolution 16-10
Your resolution is based on your video cards capabilities. If your still using the original on-board, integrated video I doubt if you'll be able to reach such resolution. Open control panel, open Display. Click the Settings Tab. You will notice Screen resolution & there is a slide bar. Sliding the bar to More will increase the resolution. You'll see what the max is for your video card. As to your LCD monitor it's max resolution is capable of reaching 1680x1050. Keep in mind the word " capable ".
If you need that kind of resoluton you'll need to find a AGP video card that can go that high.
Please vote.....
Jan 30, 2008 | Computers & Internet
Philips Brilliance 170P
Resolution should be 1280x1024.
Colours 16 bit.
Motherboard drivers installed.
Redo the graphics driver installation by completely removing the current one, and then use the install-CD for the graphics card. The installation could take place while you are in VGA-mode - press F8 during first BIOS-screen - to avoid disturbance.
Dec 21, 2007 | Philips 170P 17" LCD Monitor
SanDisk Sansa e200 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
