Question about Refrigerators
My 4 year old Whirlpool WRID45TS Refrigerator has started dripping underneath the freezer (through the vent) into the fridge below. Is there a problem with the frost free drain pipe? How do I fix it?
  • Vicki Aug 14, 2013
    Have you fixed the problem with your leaking fridge.As i have the exact same model with the exact same issue,
  • 1462 Answers
SOURCE: Whirlpool side by side refrigerator not defrosting.
take back panel off inside freezer. check continuity thro heater and thermal fuse in series with heater
Posted on Nov 17, 2008
SOURCE: WATER DRIPS DOWN FROM INSIDE TOP REFRIGERATOR BELOW FREEZER
Not an original solution - but a good one. Remove panels at the back of the freezer compartment to expose the heater unit or heater wire that defrosts the freezer coils and wrap a solid copper wire gently around the heater/ heater wire and place the loose end in the drain. This will conduct heat to the freezer drain and help keep it open. I did see a manufactured part in one of the appliance parts websites but it did not match my unit.
Posted on Jun 09, 2009
SOURCE: Hotpoint FFS70S fridge drain pipe blocks with frost
I have the same problem. Engineer said most likely problem with insulation and since pipe is moulded onto the back, it cannot be fixed easily. Defrosting is a temporary solution only. Luckily I kept extended warranty going, they are going to replace it with a new one.
Posted on Aug 15, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Is there a way to disable the frost-free feature on amana freezer
Unplug your refrigerator and open the rear panel in the back of freezer. Disconnect one whire on one end of the defrost heater. Tape the wire up and you'll be good to go no defrost. Sea Breeze
Posted on Aug 19, 2009
  • 7 Answers
SOURCE: My frost free refrigerator has frost even with
your freezer is getting frost because the door is not closing all the way. Make the necessary adjustments to the door so that it gets a good seal and the frost should stop
Posted on Nov 05, 2009
Top freezer whirlpool refrigerator condensation water leaking/dripping
there is a drain in the freezer that sum time get Clogged the drain is located below the evaporator coil you have to remove the evaporator cover to unclog it make sure the refrigerator is unplugged before trying this you can't unclog the freezer drain without removing parts
Sep 10, 2013 | Refrigerators
Sub Zero dripping noise from freezer when cycles off
Is this noise periodically or every time the fridge cycles off? Does it sound like water dripping on a hot surface?
Sub Zero Repair Tucson
Dec 05, 2012 | Sub-Zero 650 / O Bottom Freezer...
Maytag side by side fridge not connected to any water source stand alone system except electricity. approximately 500 ml puddle of water underneath vents are clean but unsure where water is coming from...
This is what it sounds like to me. The defrost system melts away the frost in the cooling coils every 6 or 8 hours. This water goes into a tray at the bottom of the freezer compartment. there is a drain spout in the bottom of the tray. The water then goes through that into a plastic drip pan. This sits behind the vent below the doors. While the fridge is running, the water evaporates out into the the room. If the pan is missing, or cracked for some reason, the water goes onto the floor.
And that's were the water is coming from. The Fridge is not broken.
With the model number of the fridge, probably located on a placard inside the fresh food compartment, or possibly the freezer compartment, you can order a new drip pan from a parts supply house for something like $25.00 The easiest thing to do would be to put in it's place an inexpensive aluminum pan of sorts. that usually will do the trick and save money.
I hope this helps,
Happy New Year,
Mark
Jan 01, 2011 | Maytag MSD2758G Side by Side Refrigerator
Water is dripping inside the unit coming from the vent below the freezer.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 21, 2010 | Whirlpool Refrigerators
Water is dripping from a vent inside the top of the fridge section of the refrigerator. Model is a whirlpool wrx42rwh6
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Aug 29, 2010 | Whirlpool Refrigerators
Whirlpool refrigerator is not cooliing refrigerator half not sure evaporator fan working model et1mhkxmb08
If the fan is working, then there is likely ice build-up in the vent between fridge and freezer. If you remove the farthest rear panel in the freezer and then pull the venting in the fridge and clean out all the ice, then the air can flow to the fridge again. It is also recommended to keep coils and compressor free of dust and make sure the drain hose is allowing water to drain into the drip tray in the back bottom of the unit.
Jul 11, 2010 | Whirlpool Refrigerators
The things in the freezer are not frozen and there is ice in the milk in the refrigerator. It a 6 year old Whirlpool side by side.
You possibly have a 2 part problem. Do a 12 defrost and make sure the product in the fridge is not near the auger (cold inlet vent into the fridge). Fridge gets its frost from the freezer compartment.
Nov 13, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a 3 yr old side-by-side. The freezer is freezing ice cream solid even though it's turned all the way down. Food in the bottom two drawers on the refigerator side are freezing. Water has dripped...
Hi, this problem is going to be with the running thermostat. (cold Control). It has gone bad and stays open which in turn will keep the compressor running continually and will cause the fridge to get colder and freeze food. It can normally be located in the control panel inside the fridge (it is the control that has wires, the other is the damper). Locate the thermostat and replace it. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Oct 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water in bottom of fridge
Thanks to all who spent money or shared their experience to have somebody do this repair, and I really mean it.
I have a Whirlpool TopLoad Fridge (not a side by side).
Things you'll need
30 minutes
Small socket for cardboard panel on lower back and panel inside freezer
Bicycle Pump
4 Towels
Hair Dryer
1. Take everything out of freezer
2. Turn dials off in fridge for both compartments
3. Pull fridge out so you can get behind it and unplug it
4. Be vigilant of ice maker line if installed
5. Pull cardboard panel off on back
On the left side you should see the back of the skinny drip pan and a small line. That line goes from the freezer and is most likely clogged.
6. Blow dry the back of the freezer enough so the ice is thawed at the bottom of the back panel.
7. Remove the two screws on the back panel. You may just be able to pull it toward you enough to get behind it. You'll see the coils and fan, and underneath these you may see some ice sheets and there should be a hole. That is the drain line that is clogged. I heated up some water and poured it over the drain to thaw the line. You may want to remove the crisper drawers and put some towels down there to catch the overflow. Once the ice is thawed enough at the drain. Go to the back of the fridge and place the end of the bicycle pump at the bottom of the drain hose. Apply pressure to get a good seal but keep pumping. You may have to go back and forth between pumping and thawing, but you'll know it is clear when you hear air going into the freezer and then the wonderful moment when water drips into the drip pan as advertised!
Keep those fridges less full so that the door stays sealed and keep the seal clean and also keep your doors from having too much stuff so the weight of the door doesn't pull away.
Okay, put it back together, turn everything on and be careful of your cord and lines when pushing the fridge back. Thank the Lord ours has wheels and man,was it cruddy underneath. Vacuum those coils underneath the fridge too for proper air circulation.
Blessings to you!
tay
Sep 15, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerators Logo
88 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
