Question about Samsung 933HD+1 19 in. TV
FACTORY RESET/SAMSUNG 933HD
NEED TO RETUNE 933HD/FACTORY RESET
My Samsung 933hd turns itself on and changes Chanel
Sounds like firmware is corrupted. If so a firmware update is necessary. An other possibility is faulty front panel control board. Any defective microswitches at it might have damaged [strucked] or so. Check it too. Do a hard reset to this set, and check. In most cases, a software bug will be corrected if any. Contact any service technician. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Nov 19, 2015 | Samsung 933HD 19 in. LCD TV
I am trying to retune my mother-in-law's tv, and don't have a manual. If I go into the menu, and try and open the "Satellite dish" icon - it won't let me. The curser just goes past it.
Sometimes, the manufacturer removes the user manual from their website in the case of older device models. If this is the case with the Samsung 933HD, you can find a backup here:
Samsung Syncmaster 933HD manual
Jan 28, 2014 | Samsung 933HD 19 in. LCD TV
Samsung 933hd tv. . .once i plugged it it turns on and it gives the sound but the whole screen turns white. . .any suggestions?
The screen turns white because defective T-Con. Mostly 19 inch model doesn't have PCB T-Con. My suggestions is , call samsung cervice center.
Mar 14, 2011 | Samsung 933HD 19 in. LCD TV
NEED A OWNERS MANUAL
http://www.nodevice.com/user_manual/samsung/monitors1/933hd.html
Jan 28, 2011 | Samsung 933HD 19 in. LCD TV
My samsung television has no signal now that the change over has happend how do i retune it to get the channels back
enter the menu and look for installtion then choose first time install and it will reset the tv back to factory settings and retune it
Nov 06, 2009 | Televison & Video
How to do a manual channel tune on a Samsung 933HD TV
in every remote there is a button that leads u to the digital setup. you have 2 options in it. manual or automatic. go for automatic. rest is done automatically. good luck!
Nov 01, 2009 | Televison & Video
Problem retuning syncmaster 933hd tv
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit
http://tvretune.co.uk/productmanuals
Oct 01, 2009 | LG W2353V-PF 23' LCD Monitor
Re-tune Samsung 933HD - doesnt say in manual
Hello :)
Please check the "troubleshooting" part of the manual.
Hope you will find a solution here.
https://manualsbrain.com/en/manuals/1762134/?page=62
Aug 09, 2017 | Computers & Internet
Channel search on samsung 933HD tv
Go to d.menu on your remote, scroll down to the second icon (the satellite dish) and press auto store. It'll scan for any freeview channels available
Dec 19, 2008 | Televison & Video
Samsung 933HD+1 19 in. TV Logo
125 people viewed this question
Henry  Thomas
Henry Thomas
