Question about Mitsubishi WT-42313 42" Rear Projection HDTV-Ready Television
Picture is not crisp
Ever since we purchased our tv, we have not gotten a crisp picture. It seems that there is always a haze around the picture. We do not have cable, but have attached an HD Tuner and HD antena. Neither fixed the problem. Any suggestions?
    Scholar:
  • 150 Answers
Did you purchase new? Convergence may be off, try the menu and look for a convergence adjustment.
Posted on Jul 09, 2007
SOURCE:
I have a hitachi ultravision and the picture giggles and there seem to be a green haze around objects in the picture
you can have that adjusted and re aligned but a new LED TV is the way to go. less space and power and better picture. easy to move. sorry
Nov 16, 2014 | Hitachi Televison & Video
Recently purchased a Sony Bravia KDL37EX403 1080p 100HZ flat screen tv. The picture seems to be poorly defined, almost pixelated around the edges of figures and letters - sport is almost unwatchable with...
Your old TV was most likely a SD (Standard Definition) TV. SD signals look better on SD TV sets than they do on HD TV sets. This is normal. If you will, imagine having a tiny wallet photo reprinted as an 8"x10" photo. The image would be grainy and not have the crispness of the original. This is the same principle. Your SD source is being blown up to fill an HD screen. Once you add HD to your programming, the old TV will be forgotten. I hope this was helpful.
Jun 12, 2010 | Televison & Video
White haze and very unclear picture. Seems the
Search for "coolant change projection tv", there are several good links including where to buy the coolant. I did mine yesterday and it's like having a new TV again, all for about $20 and 3 hours time.
Nov 11, 2009 | Philips 43PP9202 43" Rear Projection...
Picture has a red "haze"
the color in my tv is a little faded when theres dark scenes on cant really see picture. Red and Blue really fade into picture
Feb 21, 2009 | Philips Magnavox 9P6034C 60" Rear...
New Samsung LN40A550 LCD TV: picture is not crisp.
If you play with blu-Ray with HDMI, you will see the amazing picture quality.
I guaranty.
Jan 27, 2009 | Samsung LN40A550 LCD TV
Philips/Magnavox - Model 9P6444C105 - "Yellow-ish Haze" on Screen
You can get the entire coolant replacement kit at the following link. which contains 48 ounces of coolant and an instructional CD that explains the process step by step with pictures. Its listed under their repair kit catagory.
Here is the link.
http://servicemanuals.vstore.ca/
Jul 28, 2008 | Philips 64PP9901 64 in. Rear Projection...
UNABLE TO BRIGHTEN PICTURE
Your CRT coolant needs to be changed. Thats whats giving you the dim picture. You can also clean the projection mirror on the inside this often helps. But the coolant will need to be changed to get back the bright crisp picture. Hope this helps.
Jan 20, 2008 | Philips Magnavox 9P6034C 60" Rear...
Red picture cannot adust with convergence
You have bad CRT Fluid, the green and Blue tube need the fluid changed. This is a messy and possibly dangerous to the tv proposition, you will want to call someone to change the fluid, you will probably spend $450+ for the repair, but it should look pretty good when done, possibly better than it has looked in years.
May 27, 2007 | Philips 9P5034C 50" Rear Projection...
Zenith D60WLCD with blue haze over entire picture
throw the set away!the part required to repair the set is the optical engine.Zenith made alot of these sets with defective engine assemblies in wich the lcd filters burn,which cannot be replaced.The labor is also silly.Theunitrequires a complete teardown for replacment.You could buy a very nice new set for the repair bill
Feb 20, 2007 | Zenith D60WLCD 60" Rear Projection...
Mitsubishi WT-42313 42" Rear Projection HDTV-Ready Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
