Question about Tumi Leather Cover for iPad
How to remove tumi ipad 3 case - Tumi Leather Cover for iPad
I have iPad two and cannot get it to swipe open it said change passcode I did and now I can't get in it
When you enter the wrong password in to your iPad 6 times in a row, you will see a message on the screen saying "iPad is locked" and recommending you to attempt it later. In the event that you attempt too often, your iPad many show the message letting you know "iPad is disabled connect with iTunes".
Try not to stress, we can work it out. So on the off chance that you overlooked iPad screen arrow password, this post will show you how to remove passcode from iPad easily.
Unless you made a backup before you overlooked your password, there isn't an approach to spare your iPhone information. You'll have to restore your gadget, which erases the greater part of your information and settings. The following guide provides you three methods to remove password from iPhone:
1. On the off chance you've adjusted with iTunes, use iTunes.
2. In case you're marked into iCloud and Find My iPhone is empowered, utilize iCloud.
3. In the event that you don't utilize iCloud and you can't match up or interface with iTunes, utilize recovery mode.
http://www.leawo.org/tutorial/how-to-remove-passcode-from-iphone.html
Mar 21, 2017 | Apple iPad Tablets & eReaders
Tip
How to Remove Songs from iPad in 3 Ways
Part 1. Delete Individual Songs from iPad
Step 1. Launch the Music app on your iPad.
Step 2. Tap "Songs" on the bottom to see all of the music on the device. Choose the individual track you want to delete and slide your finger to the left across the songs.
Step 3. Tap on the red "Delete" button to remove music from your iPad.
Part 2. Delete All Songs from iPad
Step 1. Go to the iPad's homepage and tap on "Settings" icon.
Step 2. Tap "General" > Select "Usage" > Choose "Music." The iPad will display how much space is taken up by music on your device.
Step 3. Tap "Edit" button on the top-right > Tap the red icon next to All Music > Tap on "Delete" to remove all songs from iPad.
Part 3. Delete Selected Songs from iPad with AnyTrans
AnyTrans is an all-around iOS files manager that made to transfer and manage all your iPhone, iPad, and iPod content, such as, music, videos, photos, contacts, notes, messages, apps, etc. You can freely add or delete songs from your iPad with AnyTrans.
Step 1. Download and install AnyTrans on your computer. Run it, and connect your iPad to computer.
Step 2. On the homepage of AnyTrans > Click "Audio" > Select "Music".
Step 3. Highlight the songs you want to delete and click the trash icon on the top-right of this window to delete the unwanted songs.
Resource from: How to Delete Music from iPad
How to Delete Music from iPad in Three Ways
on Feb 11, 2015 | Apple iPad Tablets & eReaders
Volume icon appears in the middle of my iPad 3 screen and won't stay off.
Do you have a case on the iPad? Sometimes an ill-fitting case can trigger the buttons by itself. If there is any lint or dirt between the case and the iPad, it can cause the same issue. If you have headphones with a volume controller on the cable - check that that is not being pressed by accident. You can also check to see if there is any lint caught inside the headphone hole. Sometimes that can cause a little electrical short and trigger funny behavior on the iPad. If none of those solve your problem, take it to the apple store, it could just be a faulty switch.
Apr 30, 2014 | Apple iPad 16 GB 3G Tablet PC
How do i change the battery on a ipad generation 3
You have to remove the digitizer with a heat gun then remove the LCD disconnect all ribbon cables from mainboard remove mainboard to disconnect the three batteries. 2_3_2014_8_45_18_am.png
Feb 03, 2014 | Tablets & eReaders
My targus versavu keyboard case for my Ipad 3 is charged but I can't type
Thank you!!! I held the home key and power button until the Apple logo appeared and now it connects to the key pad.
Mar 11, 2013 | Tablets & eReaders
IPad 3 Printing
You can download hp eprint from appstore.Works with variety of printers.
Aug 09, 2012 | Apple iPad (16 GB) WiFi Tablet PC
How to delete photos from the Ipad
If to have the iPad before the camera was added, you have the original iPad. If you synced the photos from your computer, you have to delete the photos by syncing with iTunes again, but you have to "uncheck" the albums or folders that you want to remove.
1.Connect the iPad to the computer and launch iTunes.
2.Click on the iPad name on the left side under devices.
3.Click on the Photos Tab on the right.
4.Uncheck all of the albums or folders that you want to delete from the iPad under the Sync Photos from heading.
5.If you want to delete all of the photos - uncheck the Sync Photos From heading
6.Click on Apply in the lower right corner of iTunes
Done.
If it can't work, you can refer to the article about Delete photos from iPad.
Good Luck!
Jun 25, 2012 | Apple iPad (16 GB) WiFi Tablet PC
Forgtton unlock code on ipad2
hard reset the device
OK, you have noticed the strange behavior of your iPad / iPad 2 or even new iPad 3. It tends to freeze for about a few seconds every minute or is running too slow or something else. This is probably the best time for the hard reset of the tablet. To make things easy follow simple sequence:
  1. Make sure your iPad /iPad 2 / iPad 3 battery is charged above 20% (we would recommend at least 50 - 60 %). If you are not sure charge you tablet for at least 40 minutes.
  2. Make sure your Apple tablet is in Power On state.
  3. Watching the shining screen of iconic tablet with apps' icons on it press and hold down the Wake/Sleep and the Home buttons simultaneously, ignore the red slide "to power off", just keep both buttons holding until the Apple logo appears. This logo is the signal that the hard reset has succeeded. Be patient, some times the hard restart of iPad may take up to 10 - 15 minutes. But such a long restart is a rare case.
Be sure that hard reset retains all data and settings on iPad, it doesn't delete anything. If you want to start over and delete all personal data from iPad you should use iPad Recovery Mode.
Jun 19, 2012 | Tablets & eReaders
Keyboard Case For My New iPad?
I think you should go with zagg keyboard case . The case is the best seller and award winning also there are many other extra benefits of this product. To read real reviews on ipad cases click here to visit .
May 30, 2012 | Apple iPad Tablets & eReaders
How can i watch wmv clips on my IPAD ?
iPad can't play WMV video directly, you can install a VLC player on your iPad, which can player most of the videos. Or you can convert WMV to iPad supported format(MP4 ,MOV), here i recommend a free converter for you, Aneesoft free wmv video converter which can help you solve this issue.
Thanks for your interest in fixya please do be considerate to leave positive feedback and ratings for me if you feel my answer have helped you. Thank you.
Jun 15, 2010 | Apple iPad 32 GB WiFi Tablet PC
Tumi Leather Cover for iPad Logo
78 people viewed this question
Top Tumi Tablets & eReaders Experts
Are you a Tumi Tablet and eReader Expert? Answer questions, earn points and help others
