Question about Arrow Ct50k Professional Cordless Staple Gun Lithium Io
Arrow CT50 how to load the staples?
It shoots but does not staple
mikeymiddles
  • 58 Answers
SOURCE: piece of staple stuck in the trigger section of arrow t-50p
First, remove the magazine pusher / spring and any staples loaded in the magazine.  Then try firing the gun to clear the staple.  Use a small jeweler's screwdriver and small needle nose pliers to get the staple out.  Reload and test.       These are relatively inexpensive staple guns.  If the problem persists it might be less trouble to replace the gun.     Best of luck and I hope this solution works for you.   Michael Mittelsdorf
Posted on Jan 11, 2009
smartr10U
  • 1305 Answers
SOURCE: How to load Arrow T25 Staple Gun
at the back end of the handle, there is a retainer spring loaded clip. Push it in, then push it downward toward the base of the stapler, the clip should then release the spring, pull the rod with the spring completely out, slide a row of staple in where the rod came out, ONLY ONE ROW, then insert the rod with the spring back in and push it firmly in, and lift it upward to engage the lock. and fire away... Hope this gets your working
Posted on Jun 08, 2009
  • 384 Answers
SOURCE: How do I load the staples in this staple gun?
Push in and down the silver color piece at the end of the gun. Pull piece and spring out. Load staples, end down. Reassemble.
Posted on Jul 07, 2009
  • 94 Answers
SOURCE: How to load Staples ?
at the rear of gun there is a small door, press in and down at the same time , it should come out ,there is a spring attached to it as well.
Posted on Apr 25, 2010
farmerbear
  • 490 Answers
SOURCE: Just purchased t27 arrow staple
That stapler takes a jt21 staple. some fill from the bottom when the plunger is in the drawn back position and some fill from the rear with plunger removed. If the plunger is attached, then it fills from the bottom. Hope this helps:)
Posted on Aug 24, 2010
Arrow CT50 stapler I am looking for a staple gun which I could use for upholstery, It would need to drive staples into extremely hard wood. Thanks
Sorry we do not have that information. I suggest you contact a local Auto Trim shop and ask them what they use.
May 17, 2017 | Arrow Tools & Hardware - Others
How to shoot staples out of a trutac staple gun
Hello, there. The TruTac (TT50) is a bottom load staple gun. This video on the TruTac (TT50 and TT21) may help to answer this and other questions: http://bit.ly/1Xv7jeZ. Once the staples are loaded, keep the tool flush with the surface while stapling. If you have any more questions or need more detailed instructions, please contact us at customercare@arrowfastener.com. Thank you!
Jun 07, 2015 | Arrow Fastener Staple. TruTac Forward...
Will not shoot staples
i got a trutac arrow stap[le gun but it will not shoot staples out
Oct 26, 2013 | Arrow Fastener Staple. TruTac Forward...
Loading staples into a Stanley sharpshooter staplegun
There are 4 staplers in the Stanley SharpShooter family. You drop the staples on top of the "slide out loader," then slide it into the gun. See models and staple sizes below:
TR150HL Stanley Sharpshooter
  • Stanley SharpShooter TRA700 series or Arrow T-50 heavy duty staples
TR150 SharpShooter
PHT150C SharpShooter Heavy Duty Hammer Tracker
  • TRA700 series or Arrow T-50 heavy duty staples (1/4"-3/8")
TR250 SharpShooter Plus Heavy Duty Staple/Brad Nail Gun
  • Stanley SharpShooter TRA700 series or Arrow T-50 heavy duty staples and 1/2", 9/16" and 5/8" Brads
More information on the Stanley SharpShooter and a quick loading demo can be found here: http://www.expotv.com/videos/reviews/12/134/StanleyTR150HLSharpShooterHeavyDuty/185661
Sep 11, 2012 | Stanley Proto Stanley TR150HL SharpShooter...
I have the Arrow CT50 stapler, it won't drive the staple, light works makes a sound like it wants to drive staple but don't. I have adjusted the power to all the way + and the battery shows 4 green lights....
It sounds like the battery is failing low battery voltage equals loss of power. The batteries used in this type of tool are the cheapest ones out there to keep the cost of the tool low, and have a very short lifespan, it is not the number of times used but how old they are that is the main factor
Feb 28, 2011 | Arrow Ct50k Professional Cordless Staple...
My t 50 does not shoot staples although chamber is loaded
Hi, Dayne here
Well, it might sound too easy, but did you check for jambed staples. I also lightly oil all mine. Sometimes the actual plunger that drives the staple will break internally.
Thanks
Dec 12, 2010 | Arrow T50P ARROW STAPLE GUN
The info on the gun says it will shoot many different staples, but it will only take 3/8 staples and I need to use 1/2 staples to do the job.
The T50P stapler uses T50 staples of various lengths, including 3/8, 7/16, and 1/2. Is it possible that the 1/2 inch staples you are trying to use are not T50? All T50 staples are the same width and should fit your stapler. There are several other widths of staples that are not T50, although T50 is the most common.
Nov 29, 2010 | Arrow T50P ARROW STAPLE GUN
Arrow staple gun will not shoot it seems it is locked into place
You likely have i staple jamed in it see if you can get something that fits into the end where the staples come out and pull the bent staples out this is common even on bigger models
Nov 23, 2010 | Arrow T50P ARROW STAPLE GUN
Directions for Arrow JT-21 staple gun
The jt 21 is that little red one, I have one in my shooting box, only takes the jt staples, and operates just like any staple gun. Feed it from the back.
Feb 20, 2010 | Hand Tools
Has staples loaded but does not shoot staple. I pulled out the follower and cannot tell if there is a jam, but looking at the "output" of the stapler seems to have a staple...
I think you just answered your own question. I have had one single staple stuck at the "output" where the staple shoot out and it drove me insane for a few until I slowed my roll, took a deep breath and said, I have got to be smarter than a piece of metal here, and took a calm slow looksy. Sure enough, it was one loan staple causing a backup of the rest. I have also had issues with overloading staples which eventually makes the spring pushup rod become less forceful as it pushes the staples up for firing. Not an issue until you get towards the last dozen staples or so, which can also lead to the last staple not quite getting that millimeter push ahead, to shoot out correctly. These staple guns are like babies. Have to treat them nice and pamper them and heaven forbid you ever drop that stapler cause if dropped more than likely it will never quite be the same again. Telecom Tech 16 years.
Jun 17, 2009 | Arrow T25 Staple Gun
Arrow Ct50k Professional Cordless Staple Gun Lithium Io Logo
87 people viewed this question
Top Arrow Tools & Hardware - Others Experts
JOHN LAPIER
Paul Sikkema
Paul Sikkema
Are you an Arrow Tool and Hardware - Other Expert? Answer questions, earn points and help others
