Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
How to replace bi baffle DC07
How to replace FDC seal DC07
My problem is with the bin canister I have two dysons one loses suction but the problem is with the bin assembly as when i swap them over the problem is solved. I have replaced the base bin seal...
Sorry to hear you're having difficulties with your DC07. If you feel the cyclone assembly needs to be repaired or replaced, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Jul 07, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My dyson dc07 has too much suction and grips the carpet. Can you suggest a solution?
Remove the sole plate, inside it there is a rubber seal all the way around. Its like a piece of string. Remove it and refit the sole plate. This will allow a little air to pass around the sole plate that otherwise wouldn't have done. This will reduce the suction.
Feb 05, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Can anyone explain how to grease the bearings on a Dyson DC14 vacuum and if theres a how to video or picture website that is available for reference??
Not sure what you mean when you say "grease the bearings". I am not aware of any bearings that can, or indeed ever need, greasing in any model of Dyson. The motor bearings are sealed for life and if noisey ths can only be properly cured by a replacement motor. The clutch is a sealed mechanism so again, if noisey must be replaced. Finally, the brush or beater bar bearings at each end are plastic on metal, so should'nt produce any noise anyway.
However, if you do want to dismantle your machine have a look at www.dysonmendic.com and look at the DC07 section (the DC07 is very similar to the DC14), this will give you a lot of information on how to dismantle your machine.
Mar 25, 2010 | Vacuums
Broken trap door on dirt bin, can I just replace the door or do I need the whole bin
I have the same problem, and found the "trap door" available at http://platinumvacuum.com/dyson-dc07-bin-base-assembly-904279-10.html Since the part number is shown there, you may be able to find it elsewhere more easily using that. I will keep looking elsewhere myself.
Jan 27, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Seems like the belt may be getting old and not picking up as much as it used to.
Belts need to be replaced periodically. If the belt is worn it will not pick up the way it should. You can get DC07 replacement belts here:
Replacement belts for DC07 w/ clutch system
Replacement belts for DC07 w/out clutch system
Oct 30, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Seems to have poor suction
try this take some duct tape place it where the cannister and the seal meets then vacuum. if that not it you my have a clog.
May 08, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Bar on my Dyson wont turn
If its a standard DC07 you can check the belt by loosening the pegs on the sole plate with a coin. Once this is taken off you can inspect the belt.
If you have an All Floors model/Green DC07 then the drive belt is a sealed unit which cannot be replaced and must be fixed by an engineer.
Dec 29, 2007 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Seals leaking
Hi.
If you live in the UK I can help you.
http://dysonmanuals.inc.io/
Chris.
Nov 03, 2007 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
32 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
