Question about Yamaha Televison & Video
Got Samsung LED TV. IT only send audio out thru PCM. I have 4 years old Yahama receiver. I connected it to Samsung last night thru optical cable -no HDMI in Yamaha. I get broken voise (intermittent). As PCM light blinks as the audio gets broken. Can you PLEASE tell if a) cable problem? I trieed another cable it is not sending light at all. b) is this a format incompatibility. I appreciate your help and guidance.
  • 6 Answers
SOURCE: PS3 connection to Yamaha HTR-6130 Av Receiver
URNOTME is right. HDMI is great and all, but wish i would have spent a few more dollars on a unit that supports switching. htr-6130 does pass-through, so you have to use seperate audio connections. really there is no use running HDMI into the receiver and then into the receiver and THEN to the tv. just go straight to the tv, then run your audio either optical (best) or coaxial.
Posted on Jan 23, 2009
SOURCE: Picture sound blackout (blink) when cable box/receiver HDMI used
Onkyo service told me, the second timethat I called them, that there is a known HDMI handshake issue with Motorola and Atlanta Scientific cable boxes. The only solution, and it was a solution, is to connect the box through the HDMI 1 port ONLY. All the other (2,3,4) result in blinking/dropping of signal. I did this, changed the cable/satelilte setting to HDMI 1 and all is well.
Posted on Apr 19, 2009
  • 127 Answers
SOURCE: Hi I have a Yamaha yht 292 surround sound system
As per HTR-6230 specifications (http://www.yamaha.com/yec/products/productdetail.html?CNTID=5028494&CTID=5000400&ATRID=1020&DETYP=ATTRIBUTE) the HDMI function is only "audio-passthru", which means your receiver is not able to get the audio from HDMI cable, it can only pass it forward to TV. You would need a receiver with "HDMI switch" to be able to listen to audio via HDMI cable. You can find such receiver by looking if it supports TrueHD audio (which can be transferred ONLY via HDMI cable).
With your current receiver, you can connect it to the Blue-ray player via Optical SPDIF cable. I have checked the specs and both receiver and BD player supports optical connection.
Posted on Mar 02, 2010
  • 127 Answers
SOURCE: Intermittant Audio with Yamaha RX-V465 only from cable box
I have the same receiver... You can try pressing the Option button and choosing Signal Info to see what audio signal the receiver sees and if that changes over time. Maybe the cable box is not outputting according to specifications... TV can live with that, but receiver maybe can't.
You can also try to connect the cable box via SPDIF cable (optical or coax) to see if it helps or not.
SOURCE: samsung LED UE46B7020 tv wont play sound through my HT-C5500
press the top right hand button on the remote for the ht-c5500 untill its display reads "D.IN" (Digital Input)
Posted on Jun 30, 2010
For audio from my samsung led tv to my samsung av receiver must i use an optical cable connection?
There should be setting menu on tv whereby you can select RCA or optical.samsung units have automatic selectivity when you use optical cables so they will gives instant output when switched on....make sure you pull off the plastic ends covers ,they only go in one way into the connection ports.if you only have RCA leads you may have to set up the output audio on tv menu.
Jan 19, 2015 | RCA Audio Players & Recorders
No Audio
cant use both hdmi and opti outs try sum setting in blue ray but u nee dto plug all blue ray dish directto samsung hdmi then 1 master digital out form tv to sterio digital i n ok tell samsung your output also
Jan 20, 2008 | Sony STR-DG510 Receiver
Tring to connect my samsung tv to my samsung home cinema and having problems
Hi,here is my simple solution...
to listen your TV on your Stereo system thru your
samsung home cinema receiver,
** you need to connect "Audio Output " RCA jacks or "Optic cable output" of your TV
** to "AUX input " or "TV" OR "Any input" of your receiver ( except Phone ) or "Optic Cable input"
** than just switch to respective mode on
samsung home cinema RECEIVER corresponding your RCA or Optic connection..
There you go..Your TV sound is on the
samsung home cinema Receiver..By this means whatever you watch on the TV (TV tuner, satellite , Xbox ..etc.) ,it's sound will come thru your stereo..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 25, 2011 | Samsung Audio Players & Recorders
I want to connect the home theater system (Sony DZ-810) with Sony LCD TV and also with receiver of the satellite also with Xbox and I want the home theater works as the speakers of the TV without...
If you want to listen your TV on your Stereo system thru your receiver,
** than just switch to respective mode on RECEIVER corresponding your RCA or Optic connection...
There you go..Your TV sound is on the Receiver..By this means whatever you watch on the
TV (
tuner, satellite , Xbox ) ,it's sound will come thru your stereo..
Hope this helps!
Apr 02, 2011 | Sony DAV-DZ810 Theater System
How to connect and set up my DENON AVR-3300 to my LG tv. Waht connections on amp and tv do I use?
  • if you want to listen your TV on your Stereo system thru your receiver, AVR-3300 ** you need to connect "Audio Output " RCA jacks or "Optic cable output" of your TV
AVR-3300 RECEIVER corresponding your RCA or Optic connection...
AVR-3300
Receiver..By this means whatever you watch on the TV (tuner, satellite , Xbox ) ,it's sound will come thru your stereo..
  • Hope this helps!
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :)
Mar 28, 2011 | Denon AVR-3300 Receiver
I have a harmon kardon avr 120 and a samsung blu ray player.the audio is connected through the optical cable. the receiver however is only playing 2 channel audio. but my direct tv, which is also...
Check that the player's Dolby / DTS is enabled. Sometimes it is defaulted in the player to 2.0 / Stereo PCM. What model Samsung? Those Harman receivers are old favorites of mine...
Jan 06, 2011 | Harman Kardon AVR 120 Receiver
Technics SA-DX940 Digital optical audio input
When you say you have sound from the BD prior to disc load... where (TV and/or receiver)? Initial wake-up audio is usually 2-channel.
Describe the optical audio connection input to the receiver and any other audio paths that are attached.
Do you have other multichannel sources you could use to test this, like a cable TV box?
There's an obscure setting in the receiver called PCM Fix (on Page 21). Give that a look.
Jun 07, 2010 | Technics SA-DX940
What is the correct wiring connection using hdmi and optical cables from a lcd tv to yamaha yht292
If you tv has a hdmi input, connect it to the Yahama receiver hdmi output (out). If you are using a satellite receiver, digital converter, or a cable box with hdmi output(s), connect them to the Yahama hdmi input (in) for video and audio signals. If the above box(es) do not have hdmi capabilities, then connect the box(es) to the Yahama with either component (preferred), svideo, or yellow RCA compsite video jack (least preferred) for the video signal. For audio, connect the box(es) with optical or coax (preferred) or left-right-center-front-rear patch cords.
It really all depends on what outputs are available on the boxes and/or signal source(s).
Hope this helps,
Rhais
Sep 19, 2009 | Yamaha YHT-390 Theater System
Does the pioneer sx315 receiver work with the samsung led?
From memory, this amp does not have HDMI.
If this is the case, use an optical fibre cable for your connections.(Audio)
And if you want every thing to run through your amp you will also need to use component video cables (red/green/blue)
I would suggest the following.
Blue Ray to TV with HDMI.
HD Reciever to TV with HDMI.
TV AUDIO OUT to AMP with Optical Fibre.
This way, whatever is displayed on the tv, the sound will come throught the amp.
Hope this helps.
Sep 05, 2009 | Pioneer Audio Players & Recorders
8' Optical Cable from TV to Receiver and Signal is Breaking Up
Before you buy anything try checking the AUDIO Settings in the Menu of Each Device (Mostly TV) and see if they are set to PCM or BITSTREAM. HDMI is mostly set to PCM while Optical is generally Bitstream. The TV may be set to the opposite of what it needs to be. I would try to get PCM to work first cause it is Better, If not then set what you can to Bitstream and it should pass. Also check in TV Menu for SOUND OUT or AUDIO OUT or SPEAKERS. Some TV's have a problem passing Audio through when they are already Outputting them to it's own Speakers! I Hope this Helps out!
Apr 11, 2009 | Yamaha HTR-6130 Receiver
Televison & Video Logo
Top Yamaha Televison & Video Experts
Larry Stiles
Larry Stiles
 Grubhead
Grubhead
Are you a Yamaha Televison and Video Expert? Answer questions, earn points and help others
