Question about Philips 32PF7421D 32 in. LCD HDTV
Phillips 32PFL5522D/05 We need to find out what size bolts or screws we need to fix the table stand to our television, can you help?
welcomejee
  • 10594 Answers
SOURCE: I need a copy of the user manual for 32PFL5522D
Click Philips Support and download free copy of required user manual.
Posted on Mar 13, 2009
guru_dev
  • 315 Answers
SOURCE: cannot find table top stand to buy for philips lcd television
you can try on of these: http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1311&_nkw=tv+stand&_sacat=See-All-Categories
Posted on Jun 15, 2009
  • 16 Answers
SOURCE: NEED TO PURCHASE BOLTS TO MOUNT TV TO STAND AND DO
MEASURE THE FRIGGIN HOLE YOU DIMWIT
Posted on Jul 07, 2010
welcomejee
  • 10594 Answers
SOURCE: Need screw size to attach
Stand screws are shown in below image taken from service manual and part number is as follows..
STAND SCREW KIT A91F2UH ... 1ESA19986, replacement part number is 1ESA21715 and available in PartStore.com for $3.59
Hope this will help.
Thanks.
Posted on May 08, 2011
vis_ver_01
  • 4 Answers
SOURCE: Philips 5522 LCD 32PFL5522D/05 Can't get
You wont be able to receive ceefax / teletext after the digital switch over. As they were a Analogue service. what you need to do now is use the "Red Button" "Interactive" services as they now incorporate the new type of teletext. If you don't get them you will need to retune the set. if that doesn't work I advise contact Philips Support
Posted on Jul 19, 2011
I lost the screws of my table top stand of my toshiba tv model 32cl00u2 where can i find replacements
Take the part of the stand where the screws go in and go to a home improvement store. Check there for the proper thread pitch and length of the screw/bolt. If they don't have the correct screws, go to a local hardware store since they usually carry a wider assortment of screws/bolts, plus they usually can tell you which is the best for your problem.
Also, I believe that character after "32c..." is an L. Listed here it could almost pass off as the numeric one.
A good idea since screws/bolts are rather inexpensive, buy the parts you need that look like they are the correct length. This way you only make 1 (one) return trip to the store to return the unused screws/bolts.
Oct 19, 2014 | Televison & Video
What size screws do I need for the table top stand?
Google the model number searching for user manual or if you have the manual look in the front pages. One page should have the contents that came in the box and the assembly instructions. Screw sizes will be there.
Aug 22, 2014 | Magnavox 32MF301B/F7 32 in. LCD TV
Philips tv stand
Contact the authorized dealer for Philips. They can assist you.
Jan 28, 2014 | Televison & Video
Phillips 32pfl5522d/05 signal problem
Call your tvs manufacturer with all the serial numbers and such easily available. They should be able to either answer your question or tell you who can. Good luck. -SB
Feb 01, 2012 | Televison & Video
What size mounting screw do you use for a 47" phillips flatscreen tv to mount to a tv stand
Dear michellew467,
Welcome, and thank you for using FixYa!
I used M8 - Metric 8 bolts on mine. I was able to pick them up at Home Depot.
Have a great evening!
Sep 09, 2011 | Televison & Video
Haw to remove the base from sharp LCD TV 56 in
I find this guide about how to remove the Base of an LG LCD TV. Things You'll Need:
* Table or other flat surface
* Soft cloth or towel
* Phillips screwdriver
Instructions:
1 Unplug your LG LCD TV from its power supply and unhook any other cables from the TV.
2 Lay a towel or a soft cloth onto a table or another flat, supportive surface.
3 Lay the LG LCD TV face down on the towel, which will protect the screen from being damaged.
4 Use the Phillips screwdriver to remove the four bolts that hold the base in place. The bolts are located in the center of the TV near the bottom.
5 Slide the stand out from the bottom of the TV.
6 Press the protection cover, which is supplied with the TV, into the spot on the TV where you removed the base until you hear it click into place.
7 Re-insert the four bolts you removed into the holes on the back of the TV and tighten them with the Phillips screwdriver.
I hope this help; remember to rate this answer. Good luck.
Sep 30, 2010 | Sharp LC-32SB24U 32 in. LCD TV
I need the screw size for 4 scews to re-attach a Sony Bravio 40" LCD to the stand
I assume that its Sony KDL-40S2000 model and it needs following size screws to attache its table stand..
PART NUMBER.. 258060201.. SCREW, +PSW M4X12
Available in Part Store.
Hope that info will help you.
Thanks.
Nov 15, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
I need screws for an Olevia LT37HVS tv stand
Most of these sets us either a M4 or M6, around 22mm. this is close to a 2" long 1/4-20 screw, but in metric.
Home depot or radio shack, or just about any place that sells TVs these days ought to have them.
At radio shack, a wall mount comes with the following screws to fit all TVs:
  • 4 x Phillips screw (M4 x 10 mm)
  • 4 x Phillips screw (M4 x 20 mm)
  • 4 x Phillips screw (M6 x 12 mm)
  • 4 x Phillips screw (M6 x 20 mm)
  • 4 x Phillips screw (M6 x 30 mm)
  • 5 x Phillips screw (M5 x 6 mm)
Only caveat is don't go with a screw substantially longer than what is needed.
Oct 23, 2009 | Olevia LT37HVS 37 in. LCD HDTV
My tv is showing multi coloured snow how can i fix it a 42inch and modle number is 32pfl5522d/05 please help
what you mean you have cable or dish?
is the pix the same way in video hdmi or thur
video 1 2 3 if it is you have a bad panel'
because of the t.con chip
Aug 12, 2009 | Televison & Video
Fasten 32'' insignia plasma model ns-pdp32-09 to wall mount
I think it is probably a metric bolt. Maybe a 10 or 12 MM. There aren't many if any consumer electronics manufactured in the US anymore, and most use metric screws and bolts. Check one of the bolts from that table stand to see what it is. That will tell you if it is metric or standard.
Best of luck.
Jan 30, 2009 | Televison & Video
Philips 32PF7421D 32 in. LCD HDTV Logo
61 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
